Espritmodel.com Heli Air
Old Jul 21, 2012, 12:01 PM
jamboF4's Avatar
Joined Oct 2010
Esprit "Albatross" 3.2
Greetings. Being new to big sailplanes, there's almost no limit to what I don't know. I have had great dealings with the products offered by
Esprit Models, but I don't know the first thing about their sailplane offerings. I'm interested in their Albatross 3 Sport Classic (e-powered). Does anybody have any feedback / recommendations / alternatives for a Radian-Pro-upgrade-dude?
Thanks in advance.
J
jamboF4 is offline Find More Posts by jamboF4
Old Jul 22, 2012, 11:53 AM
Machete don't text
motor12's Avatar
United States, TX, Austin
Joined Jan 2010
I also am a Radian Pro guy looking to go bigger. looking at the Albatros 2.4S/E
motor12 is offline Find More Posts by motor12
Old Jul 23, 2012, 03:09 PM
Joined Apr 2012
I don't have direct experience with the Albatross but I have yet to see a negative review on any of the Esprit line of sailplanes. Probably the worst that I've seen is that the instructions for the gliders made by TopModel cz, like the Albatross, leave a bit to be desired.
peterlngh is offline Find More Posts by peterlngh
Old Jul 24, 2012, 08:13 AM
jamboF4's Avatar
Joined Oct 2010
I concur. Looked at the manual and it's more like a blueprint. I am going to let the Esprit Models builders make mine. I'm starting to amass the bits and pieces and was surprised see that Esprit's parts prices are VERY competitive with just about any RC supply house. Good on 'em! Just waiting on the 3M to be stocked. Fortunately, I live close enough to go get it, instead of shipping. Stay tuned.
Old Jul 24, 2012, 02:19 PM
AMA 7224 LSF 1832 SAM NFFS
Leadchucker's Avatar
Joined Sep 2008
Originally Posted by peterlngh View Post
........ Probably the worst that I've seen is that the instructions for the gliders made by TopModel cz, like the Albatross, leave a bit to be desired.
Only your first Top Model non instruction manual will leave you staring blankly into the distance, the second you will do standing on your head. Even if you've built a few models the light weight methods of doing things in a Top Model plane will take some adjusting. You would think it's not going to work especailly if you have been flying heavier power stuff but, work it does and quite well. All the Top Model planes I've built,flown and seen are well executed with good fit and finishes. Don't be afraid to buy one if you are thinking about it, they are good stuff and Esprit is a absolute top shelf outfit to deal with.
At least there some paperwork with the Top Model series, the Pulsars come in a heavy box wrapped in foam liners and bubble pack....that's it. Don't even let you know who makes them let alone a manual. You soon sort it out after sleepless nights and much mumbling to yourself and when finished you wonder what all the worry was about.
Leadchucker is offline Find More Posts by Leadchucker
Latest blog entry: 1940 Megow Models Super Quaker
Old Jul 24, 2012, 02:27 PM
jamboF4's Avatar
Joined Oct 2010
Well, I'm feeling better about Esprit building for me. I just hope their Albatros 3.2 shows up in stock soon. Thanks for the inputs guys.
Old Jul 24, 2012, 04:09 PM
Joined Apr 2012
I'm not too concerned, Leadchucker, but I felt it important to mention the "semi-formal" instructions from TopModel. After 40 years of this stuff I can generally figure things out. I used to frequently buy kits at garage and estate sales and they might have had parts, instructions, and even plans missing. My biggest blunder was a U-control Fokker DVII that came without plans or instructions. I used the slots in the leading edge to position the ribs for the bottom wing and then, when I went to start the top wing, discovered that all I had left were half-ribs. Oops! I should have realized there was a good reason that the trailing edge had half as many slots as the leading edge.
On the other hand, a simple set of instructions avoids what I like to call "Step 37-B". That's when you get to the end of a build where one has been guided through the most mundane aspects of gluing bits of wood together to be faced with the final step that goes something like: Shape and sand all surfaces, cover model, hinge control surfaces, install control surfaces, install engine and radio. Balance and go flying.
It would not be uncommon for me to frame up the whole thing in a week or two and then spend months struggling with all the little quirks they didn't see fit to mention in the manual. I also built a couple of Lanier "ARFs" that generally took more effort and money to finish than a comparable box of sticks!
I don't see the same type of things in the TopModel instructions because the level of prefabrication is much greater than in the ancient past. Although, I will be creating a bit of work when I pick up a TopModel ARC (I'm leaning towards the Avia V-tail but will change my mind a few-hundred times) for my fall/winter project. I like covering, I like using my own color scheme, and I have 40 years of accumulated bits of covering that I would like to use up.
Old Jul 31, 2012, 10:27 AM
Michael Heer's Avatar
Stockton, Ca. USA
Joined Apr 2001
I just finished writing a mini review of the Esprit Model Pulsar 4E that a friend bought. It should be posted here in LiftZone soon. He went with the Esprit Model recommendations of geared NueMotor, spinner and folding prop. They matched up great with the Pulsar 4E. The main assembly is mounting and wiring the servos. My friend Kirk made his own harnesses from bulk wire and Dean Mini Connectors. I have in the past made my own harnesses and used pre-made servo extensions as well. The lack of instructions can be daunting on the first construction but if you go with the recommended motor set-up you can have confidence that it will be properly powered and will be able to balance on the recommend C/G.
I am hoping to do a review of an Albatross Electric and if I do I will do an extensive build and cover programing basics for a full house glider. I have my fingers crossed about the possible review. Michael Heer
Old Jul 31, 2012, 12:16 PM
Joined May 2010
Albatros 3E
Let's make it harder. Coming Soon New Modern Albatros 3S/E
Zb/Esprit Model
Esprit Model is offline Find More Posts by Esprit Model
Site Sponsor
Old Jul 31, 2012, 03:24 PM
Stockton, Ca. USA
Joined Apr 2001
Very pretty! Mike H
Old Aug 01, 2012, 06:45 AM
Electric Glider Nut
timography's Avatar
Australia, WA, Perth
Joined Feb 2012
I agree with Leadchucker. I've built a TopModel Avia 2.5m e-glider. The first glance at the instructions will have you saying "what the...?" but once you actually get into the build they are really quite good. After all, a picture is worth a thousand words, right?
The Avia turned out to be a phenomenal glider, I love every second it's in the air, such a graceful plane to fly; after graduating from about 100 hours spent on a Radian Pro and a Multiplex Cularis.
Any TopModel kit (sold by Esprit) is going to be worth it. Take a big breath and go for it - you won't be dissapointed!
timography is offline Find More Posts by timography
Old Aug 01, 2012, 03:52 PM
Valdosta, GA
Joined May 2006
Also, there's usually a build thread on most of the Top Model planes. If not, look for a similar model like the Grafas - many of the techniques are similar. The Top Model plans are easier to follow if you can find a good build thread with pictures.
efowlerpreston is offline Find More Posts by efowlerpreston
Old Aug 01, 2012, 10:18 PM
Joined Apr 2012
Are you still there, timography? If so; may I ask what motor you are using in your Avia? The Avia is very high on my short list of future sailplanes.
Thanks!
Old Aug 02, 2012, 08:34 AM
Electric Glider Nut
timography's Avatar
Joined Feb 2012
Thanks!
Hey - I'm here
I used the recommended MVVS 2.5/1120 outrunner - a beautifully made motor by the way - along with the recommended 10x6 carbon folder prop. That, teamed with an OS OCA-150 (50amp) speedy seems to work really well. I chose the OS speedy as it has a big fat beefy 3A BEC and I'm not running a separate receiver pack for all those 6 servo's. Oh, I'm using a 3S 2200mAH 30C pack.
So, a 30 second motor run gets me about 70 degree climb, not quite vertical, but still pretty brisk up to an altitude of between 650-700ft, which makes it absolutely perfect for its intended F5J task. I've got Spektrum telemetry on board with an altimeter so I know my altitude at all times; which is handy...
Old Aug 02, 2012, 09:04 AM
Joined Apr 2012
Thanks, Tim. They are beautiful motors but I'm not sure if the budget will stretch that far. Still, it's good to know that they are recommending adequate power for a good climb and, if I do end up deciding on the Avia, I don't want to use a motor that disappoints.
Discussion Kit for Esprit Pulsar 3.2 or similar? Piper J3 Thermal 2 Nov 23, 2011 12:23 PM
Question Kit for Esprit Pulsar 3.2 or similar? Piper J3 Electric Sailplanes 1 Nov 22, 2011 08:43 PM
Sold Mega 22/30/2 MEC 3:1 gearbox Phoenix 60esc and Esprit Mount RyanPSU21 Aircraft - Electric - Power Systems (FS/W) 6 May 11, 2006 03:43 PM
Albatross! Albatross! Albatross! kosmonot Dynamic Soaring 0 Sep 12, 2004 12:23 AM
