Old Jul 21, 2012, 05:37 AM
Wiciman is offline
Find More Posts by Wiciman
Joined Jul 2012
Bixler / Sky Surfer V1 motor loose during flight - help!
Today, during my first loop tests with my Bixler / Sky Surfer RTF, the motor started to behave funny in the sky, emitting a rattling noise. I landed the bird and realized that the two screws holding the motor in the mount were loose (one of them had completely fallen out from its threads and rolled around inside the fuselage).
Luckily the motor was still intact in its bay...
Has anyone encountered the same problem?
I tried putting some Loctite (screw adhesive/hold lubricant) on the screws but it seems almost impossible to re-fit the screws with a screwdriver. The screw mount is not aligned horisontally in the airflow space and it is difficult to fit (even a long) screwdriver in there to get to the screws.
Do I need to cut the foam? How hard do I dare tighten the screws? The engine bay mount seem to be made out of balsa, so i'm guessing "go easy"?
Wiciman is offline Find More Posts by Wiciman
Old Jul 21, 2012, 04:03 PM
Koo is offline
Koo
Find More Posts by Koo
Koo
A semi-advanced FPV newbie
Koo's Avatar
United States, OH, Oxford
Joined Mar 2012
I had to take those screws off because my motor mount got loose after a crash. I recommend you adding some hot glue with some wood to make sure that this doesn't happen to you.
As for your problem, you don't need to cut any foam off. Just have a screwdriver that has a small shaft, and start screwing the screws in. You will have a small angle and you have to alternate from one screw to the other quite often in order to get them in. Took me about 5 minutes to get both of them in. Not fast but it works
Koo is offline Find More Posts by Koo
Old Jul 22, 2012, 12:51 PM
Wiciman is offline
Joined Jul 2012
Thanx but where exactly did you put the wood?
Sold Sky Surfer v1 (aka Bixler)...Kit for FPV. wamdue Aircraft - Electric - Airplanes (FS/W) 2 Jul 19, 2012 09:37 PM
Question Why does my Dji naza keeps falling out of the sky! Percalotor - Quad_Addict Multirotor Talk 8 Jul 17, 2012 07:51 PM
Discussion Sky Surfer plane help with ESC I think videorov Electric Plane Talk 2 Jul 07, 2012 12:13 PM
Question Sky Surfer V1 Propeller markhodges78 Electric Plane Talk 4 Jun 28, 2012 05:44 PM
Sold Sky Surfer (V1) new kit + FPV pod(s) Eagle-Eye Aircraft - Electric - Airplanes (FS/W) 2 Jun 01, 2012 08:11 AM
