Old Jul 20, 2012, 11:32 PM
LRFitch is offline
Find More Posts by LRFitch
Pasco Tri Cities, Washington, United States
Joined Aug 2004
Source for a vacuum switch
Guys,
I'd like to add a vacuum-sensing switch that can turn the vacuum pump on and off at a selected vacuum level that I can set. I know many folks use such an approach, but don't know of a place I can buy one. ANy help will be appreciated.
Larry
LRFitch is offline Find More Posts by LRFitch
Old Jul 20, 2012, 11:52 PM
AUSELECTRIC is offline
Find More Posts by AUSELECTRIC
Joined Nov 2004
Originally Posted by LRFitch View Post
Guys,
Larry
I have used the one from www.joewoodworker.com and they work well
Only have 2 issues.
1 - Postage cost to Australia
2 - I have snapped the plastic thread over tightening.
AUSELECTRIC is offline Find More Posts by AUSELECTRIC
Old Jul 20, 2012, 11:55 PM
Underthetire is offline
Find More Posts by Underthetire
Underthetire's Avatar
United States, CA, Brentwood
Joined Jun 2012
Mcmaster-carr
Underthetire is offline Find More Posts by Underthetire
Old Jul 21, 2012, 12:27 AM
jkettu is offline
Find More Posts by jkettu
Joensuu, Finland
Joined Mar 2002
Guys,
I'd like to add a vacuum-sensing switch that can turn the vacuum pump on and off at a selected vacuum level that I can set. I know many folks use such an approach...
...and then there are those who don't like the pumping effect of fluctuating vacuum level and use a continuous run pump with adjustable bleeder valve. To each their own, both ways seem to produce acceptable parts.
jkettu is offline Find More Posts by jkettu
Old Jul 21, 2012, 12:37 AM
Joined Jun 2012
I have used a variable freq drive coupled to a vacuum transducer to eliminate the pulsing. It simply slows the pump down once the desired vacuum is met, and increases when needed. Probably not a hobby type solution as it was on a 3 phase LARGE industrial system and was not cheap to build.
Old Jul 21, 2012, 11:46 AM
killercando is online now
Find More Posts by killercando
Certifiable User
killercando's Avatar
United States, WA, North Bend
Joined Mar 2011
Hi Larry - The joe woodworker switch works good for the price. Seems like the nicest nice setup is a an air tank for a reservoir with a switch to control the pump and a vacuum regulator on the inlet. Then you can pull a steady vacuum at the workpiece and have the pump cycle as little as possible. Mcmastercarr has a regulator for about $56 http://www.mcmaster.com/#vacuum-regulators/=ii4vp3 .
killercando is online now Find More Posts by killercando
Old Jul 21, 2012, 01:58 PM
MarkRebuck is offline
Find More Posts by MarkRebuck
Joined Oct 2006
I just went thru this over the last few days. I bought a vacuum switch off ebay ( http://www.ebay.com/itm/250821538795 ), then built my system something like this: http://www.markrebuck.com/pics/uncla...vacswitch.jpeg
I'm using an old 5 gallon portable air compressor tank as my reservoir.
Not sure if I saved any money purchasing the switch off ebay, but I wanted to be able to control the hysteresis range, and the other switches I've seen (e.g. http://www.acpsales.com/VacuumSwitch.html or http://www.veneersupplies.com/produc...er-18-NPT.html ) tend to have a preset hysteresis range.
MarkRebuck is offline Find More Posts by MarkRebuck
Old Jul 21, 2012, 07:03 PM
LRFitch is offline
Joined Aug 2004
Thanks for the response
Guys,
Thanks for the ideas a links. Mark, I take it one of the contacts on the vacuum switch is N.O. and one N.C.? I had the same thoughts in mind, but was going to use a 120vac relay so I don't have to provide 12VDC from some source. Radio Shack has one that is rated for 10amps switched that should do the trick.
Old Jul 21, 2012, 08:09 PM
Joined Oct 2006
@LRFitch Easiest way to explain how the vacuum switch I bought works is to look at the datasheet from http://www.barksdale.com/en/products...1h-d2h-series/ . I bought a D2H-18SS. It is basically two independent SPDT switches in the same housing. It was important that I bought a switch with two set points so I could implement variable hysteresis. Internally, the vacuum switch is just a metal dome near two switches. The dome expands (pressure) or contracts (vacuum) to make/break contact with the switches. So the N.O and N.C contacts for each switch change if you are doing pressure instead of vacuum. It was easy to set every up given the documentation.
The relay I used was a 12V automotive relay that I had in my parts bin. My vacuum pump is a converted 12V electric bicycle pump (e.g. http://www.instructables.com/id/conv...ressor-into-a/ ) and I had a 12V supply from a converted PC power supply, so it all just worked out for me. I think any relay that works with your pump will do the trick though.
Not sure I saved any $ over buying a switch/relay from an online vacuum bagging supplier, but I had fun figuring out how to wire my circuit to do what I wanted.
Old Jul 22, 2012, 09:49 AM
LRFitch is offline
Joined Aug 2004
Thanks Again Mark
Mark,
The 12V relay makes perfect sense with a 12V pump. I think I'm now on the right track. Thanks for the help.
Larry
Old Jul 22, 2012, 01:54 PM
V1VrV2 is offline
Find More Posts by V1VrV2
Mongo like wind. Wind Good.
V1VrV2's Avatar
Joined Apr 2004
Here's a vacuum regulator I got from Boeing's surplus outlet when they were still open. It regulates vacuum pressure without bleed. The pump/reservoir simply turns on and off between an adjusted pump vacuum of 23" to 26" Hg. Vacuum can be precisely regulated from 0 - up to 30" Hg.
V1VrV2 is offline Find More Posts by V1VrV2
Old Jul 22, 2012, 04:50 PM
tdkamila is offline
Find More Posts by tdkamila
Joined Feb 2006
I burned one out because I was using line voltage without a relay. I needed it NOW so I bought a distributor vacuum actuator and built my own. It has worked fine for the last few years.
Tom
tdkamila is offline Find More Posts by tdkamila
Old Jul 22, 2012, 08:05 PM
flyboypeter is offline
Find More Posts by flyboypeter
Peewee Paraparaumu New Zealand
New Zealand
Joined Sep 2004
vacuum switch
http://www.poweraire.com/vacuum-swit...6_234_303.html
This is the one I have used.
best Peewee
flyboypeter is offline Find More Posts by flyboypeter
Old Jul 22, 2012, 10:14 PM
sorenlaf is offline
Find More Posts by sorenlaf
United States, CA, Hayward
Joined Jul 2008
ACP (Advanced Composite Products) has one.
$41
About half way down the page:
http://www.acpsales.com/Vacuum-Bagging-Fittings.html
I don't know if it's a good price or not. It seems kind of high, but perhaps that's just what they cost. I've generally been happy dealing with ACP, but this is not something I've comparison shopped.
--Soren
Guys,
Larry
sorenlaf is offline Find More Posts by sorenlaf
Old Jul 27, 2012, 12:42 PM
razortoe is offline
Find More Posts by razortoe
Keep it Simple Stupid
razortoe's Avatar
United States, NC, Raleigh
Joined Jul 2011
I too am using a D2H-18SS though I'm not sure why relay is needed? Maybe I'm not remembering my part # right, but it's rated at least 15A. I tried figuring out how to wire two switches to set high-low point but gave up. Instead my setup just uses two adjustable timers and a switch to select the side. The D2H-18SS has 5/16" hex adjusting nuts, so I mounted it at 45* and ran 5/16" drivers through my console. This lets me adjust the settings as needed. With the flick of a switch I can choose one of two pressure settings. It's worked out nicely so far. Care to share how you wired yours up so you can select hi/low points?
razortoe is offline Find More Posts by razortoe
Discussion Vacuum switch AUSELECTRIC Australia 0 Apr 20, 2012 08:34 AM
Vacuum baggin w/out a vacuum source raptor22 Composites Fabrication 27 Mar 07, 2005 01:05 AM
