Old Jul 20, 2012, 09:10 AM
jrb is offline
jrb
Find More Posts by jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Neg Post Isolation Radio Shack 25 amp PSU
Im getting a 2nd Radio Shack 25 amp PSU (22-510: 13.8V DC 25A Switching Power Supply) and plan to use them in series to power my iC3010B.
Has anyone done a Neg Post Isolation conversion?
TIA,
Jim
jrb is offline Find More Posts by jrb
Old Jul 20, 2012, 09:36 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Given that this is a dc power supply and not a computer power supply are you sure that the dc neg is connected to ground? I'm not sure if ALL dc power supplies are setup that way. Be easy enough to check with a multimeter.
grimbeaver is offline Find More Posts by grimbeaver
Old Jul 20, 2012, 10:08 AM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
I planned that to be the 1st thing I would do; I'll check my MasTech too.
Old Jul 20, 2012, 03:25 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
The MasTech lets you know right up front!
And, the Radio Shack rings out to the case being ground & the negative post being isolated -- floating.
With the RS on I can plug the connect the charger (iC3010B) w/o issue; unlike on my biggest PC PSU -- needs to be connected then powered up.
Is that typical of PC & Server PSUs?
Old Jul 20, 2012, 04:37 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
Likely, yes. Most PC and server supplies have sophisticated short circuit, overcurrent, overvoltage, and undervoltage protection that is lacking in many consumer grade supplies.
Plugging a charger into a server supply that is up and running can engage the overcurrent protection circuitry. It's for this reason that it's always wisest to first connect the charger to the power supply and then power up the supply, as previously discussed.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Jul 20, 2012, 06:17 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Guess that will keep the local club from getting some from Feather.
They were thinking 4 -- two 12s & a 24.
Old Jul 20, 2012, 07:45 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
I have both IBM and Dell server power supplies which can be powered up without any load attached and then the load ,charger(s) connected without any issues.
I would suggest contacting Feather and having him give you the first hand low down on the ones your club is considering.
Charles
Old Jul 20, 2012, 08:28 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Will do Charles; thanks once again -- con-grats!
Old Jul 20, 2012, 08:57 PM
So. Cal.
Depends on the particular PS and the input capacitance of the charger in question. I have some HP and IBM supplies that never experience shutdown when connecting a charger and others that nearly always experience a current fault upon connection.
The easy solution here is to simply connect the charger prior to turning on the supply or to use a current-limiting power-up resistor to charge the input capacitors if the PS has to be on all of the time.
Mark
Old Jul 21, 2012, 07:28 AM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Mark
Thanks Mark!
Can you think of a way we could incorporate a resistor into a club's charging station?
TIA,
Jim
Old Jul 21, 2012, 10:29 AM
So. Cal.
Some ideas....
http://www.rcgroups.com/forums/showthread.php?t=759403
http://scriptasylum.com/rc_speed/nospark.html
Mark
Old Jul 26, 2012, 04:18 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Just tested my two Radio Shack 25amp switching supplies in series might be a bit short compared to the 652 I got out of the MasTech: 23.5a, 27.2v, 643w, consumed 752w @ 6.3amps.
Measured 0 vdc & 0 vac between the cases.
Old Jul 27, 2012, 07:19 PM
jrb is offline
jrb
jrb
Member
jrb's Avatar
Edina, MN, USA
Joined Oct 1999
Just enough:
Sold Radio Shack 12 volt Power Supplies 15 Amp & 3 Amp like new!!! unclegeorge Aircraft - Electric - Batteries & Chargers (FS/W) 0 Mar 29, 2012 12:38 PM
Wanted 40 amp power supply or 25 amp radio shack Kevdawg Aircraft - Electric - Batteries & Chargers (FS/W) 1 Sep 29, 2008 09:02 AM
25Amp PSU $60 at Radio Shack!!! Peter Khor Batteries and Chargers 64 Apr 17, 2003 04:55 PM
$60 Limited Time >> 25 Amp DC PS at Radio Shack vkmaynard Aircraft - Electric - Airplanes (FS/W) 12 Jan 21, 2003 05:48 AM
$60 Limited Time >> 25 Amp DC PS at Radio Shack vkmaynard Electric Heli Talk 12 Jan 20, 2003 09:05 PM
