Old Sep 01, 2012, 08:04 PM
Subdave is offline
Find More Posts by Subdave
Semi-Official Tinkerer
Subdave's Avatar
Rochester NY
Joined Mar 2005
O man!
You are going to make me start mine arn't you!
Ship!
That looks cool! Dave.
Subdave is offline Find More Posts by Subdave
Old Sep 01, 2012, 11:28 PM
CaptDH is online now
Find More Posts by CaptDH
GET BACK IN THE SHOP!!!!!!
CaptDH's Avatar
United States, CA, Avalon
Joined Oct 2002
Get going Dave... Paul is catching up to me........I told him to post some images...You too.
D
CaptDH is online now Find More Posts by CaptDH
Old Sep 06, 2012, 09:20 PM
Sea_Horse is online now
Find More Posts by Sea_Horse
Sea_Horse's Avatar
United States, NY, Gates-North Gates
Joined Nov 2005
D, progress so far...
Sea_Horse is online now Find More Posts by Sea_Horse
Old Sep 07, 2012, 06:52 PM
CaptDH's Avatar
Joined Oct 2002
Seahorse,
Images didn't make it in...
D
Old Sep 07, 2012, 09:39 PM
Subdave is offline
Subdave's Avatar
Rochester NY
Joined Mar 2005
I can see them.
Old Sep 08, 2012, 01:32 AM
CaptDH's Avatar
Joined Oct 2002
Must have been blocked at work. I see them now. Nice work!!! I finally got the steering done so we are almost ready for a sea trial. Used the basic rc airplane stuff but do have a reversing water cooled ESC coming this week. It should keep the heat down a bit better than the aircraft one but I might need to run a pump to get water through there. I also like the idea of some sort of reverse. Should be interesting to see what it does backing up...
D
Old Sep 12, 2012, 11:00 PM
CaptDH's Avatar
Joined Oct 2002
Got the paint on the motor section and the pilot house.
Did my superglue welds to the proper areas.
Added exhaust pipes and all lighting to the cabin.
Skateboard grip tape for non-skid.
The entire boat is running on an 11.1 volt lipo. Love the way the side spreader lights look. Plan to have the running and spots on a separate channel.
D
Old Sep 12, 2012, 11:33 PM
capntroy is offline
Find More Posts by capntroy
Keep a Steady Strain....
capntroy's Avatar
Orange County, CA
Joined Nov 2007
Really nice job on the paint Darrin!
capntroy is offline Find More Posts by capntroy
Old Sep 13, 2012, 11:20 AM
Sea_Horse's Avatar
Joined Nov 2005
Excellent Darrin !
now i'm way behind you , what did you use for the side lights?
Old Sep 13, 2012, 04:19 PM
CaptDH's Avatar
Joined Oct 2002
They are a Robbe part. (ROB1375) Had them in storage for years and put my new 12 volt 3mm LED's inside..
D
http://www.cornwallmodelboats.co.uk/...eck-lamps.html
Old Sep 13, 2012, 06:18 PM
Sea_Horse's Avatar
Joined Nov 2005
Thanks Darrin, here's another link:
http://www.harbormodels.com/Harborma...3-lighting.htm
Old Sep 16, 2012, 10:05 AM
Subdave is offline
Subdave's Avatar
Rochester NY
Joined Mar 2005
I sorted out the motor and prop for mine.
I have a 6x4 Master Airscrew three blade prop. MAO640T
The motor is a Turnigy 2830-800 outrunner.
I pressed the motor shaft through the bell so I could mount the motor like a radial engine.
It is physically larger than your motor so I am not sure how it will look with the dummy motor.
It does run very smooth and the prop is quiet.
I had to open the prop hub to 5 MM in the drill press to fit the motor adapter.
Seahorse is using the same motor and prop.
I would post a photo but the iPad will not do it and my laptop in in repair.
Dave.
Old Sep 16, 2012, 11:52 AM
Subdave is offline
Subdave's Avatar
Rochester NY
Joined Mar 2005
Here is a photo.
Old Sep 17, 2012, 02:11 PM
Subdave is offline
Subdave's Avatar
Rochester NY
Joined Mar 2005
Did either of you two notice there is a crescent snapped cutout in the transome that the prop spins down into.
I bet it lowers the thrust angle down closer to the CG.
The higher the prop is the more it would want to push the bow down.
Just a theory on my part but mine will have the cutout.
Dave.
Old Sep 17, 2012, 04:10 PM
CaptDH's Avatar
Joined Oct 2002
I thought about putting it in but went against it based on how I mounted the deck. You will also need to shorten or recess the cage too. Should look nice..
D
Question 25" Comet Coast Guard Waco JSW-1 RayRangel Scratchbuilt Indoor and Micro Models 23 May 03, 2015 04:04 PM
Discussion Twister US Coast Guard RTF Co-Axial Electric Helicopter centaur1126 Coaxial Helicopters 4 Jun 20, 2012 10:07 PM
Sold Billings US Coast Guard Boat no.100 NIB hampboats Boats (FS/W) 1 May 03, 2012 11:54 AM
Sold US Coast Guard 110' Tug Plans RCBoater Boats (FS/W) 1 Apr 08, 2012 10:17 PM
