Old Jul 19, 2012, 03:03 PM
mayday1 is offline
Find More Posts by mayday1
rancho san antonio, CA
Joined Sep 2005
spektrum satellite receiver protocol?
I don't have a logic analyzer but I want to know what spektrum satellite
receivers send out normally when not in bind mode.
I have a spektrum dsm2 satellite, a dsmX satellite, and a hobbyking orange satellite.
All these seem to work properly when connected to a spektrum full receiver.
But when I connect them to a Tarot zyxs gyro, each satellite behaves very differently. The spektrum dsmx satellite seems to be 100% functional with
the zyxs gyro, the spektrum dsm2 satellite doesn't seem to work at all (none
of the channels respond to the transmitter stick movement), and the hobbyking
satellite kind of works (channels respond to TX stick movement, but the channels
seem to be scrambled).
I've read that the satellites simply put out 16bytes of data per frame
(2 bytes of RX/TX specific info, 2 bytes of channel data repeated 7 times
for the 7 channels). The fact that each Rx behaves differently seem to indicate
each satellite sends data either in different order, or with slightly different baudrate?
Does anyone know how these receiver differ in the bytes stream that they
send out?
thanks
mayday1 is offline Find More Posts by mayday1
Old Oct 05, 2012, 02:06 AM
spaaarky21 is offline
Find More Posts by spaaarky21
Helicopter Baron
spaaarky21's Avatar
United States, CO, Golden
Joined Feb 2012
Honestly, if someone knew enough about all of them to spell out the differences in detail, I imagine they would probably be more involved in the forums for a specific programming/hardware project, like ArduCopter for example. There are a lot of projects out there from people who want to read directly from satellites and community-based quadcopter projects are good examples. Try looking for results related to Arduino and a specific project like ArduCopter. Googling "arduino spektrum satellite" bought up some results that look promising at first glance.
spaaarky21 is offline Find More Posts by spaaarky21
Old Oct 05, 2012, 03:24 AM
David T is offline
Find More Posts by David T
UK
Joined Aug 2000
Hi. Does each 2 bytes contains a channel number and channel position? That would be more important than assuming a channel sequence. And do you know if you are using 10 and 11bit data?
Regards, David.
David T is offline Find More Posts by David T
Sold Orange Rx R100 Spektrum 2.4 Satellite Receiver nybeechpilot Aircraft - General - Radio Equipment (FS/W) 2 Jun 25, 2012 06:40 PM
Sold Spektrum AR6210 DSMX receivers with satellites NEW! HD Hucker Aircraft - General - Radio Equipment (FS/W) 0 Jun 23, 2012 08:30 PM
Sold SOLD Spektrum DSM2 AR7100 with satellite remote receiver SOLD jgpncll Aircraft - General - Radio Equipment (FS/W) 0 Jun 19, 2012 09:31 PM
Sold Spektrum AR 9000 DSM2 Receiver with two Satellites bluelevel Aircraft - General - Radio Equipment (FS/W) 1 Jun 18, 2012 05:22 PM
Sold NIB Spektrum AR7010 7-channel receiver w/ satellite TheCure Aircraft - General - Radio Equipment (FS/W) 1 Jun 15, 2012 09:27 PM
