This thread is privately moderated by typicalaimster, who may elect to delete unwanted replies.
Old Oct 10, 2012, 07:01 PM
Mike Freas is offline
Find More Posts by Mike Freas
KK4NOP
Mike Freas's Avatar
United States, MD, Lusby
Joined Aug 2005
Originally Posted by DesJardins View Post
Little range test I did, only FPV flight #4 for me
http://youtu.be/KyWJ1EzfGq8
setup?
Mike Freas is offline Find More Posts by Mike Freas
Old Oct 10, 2012, 07:16 PM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
Originally Posted by glassdogangle View Post
This is why you should never, ever fly FPV in foggy conditions. Unless you are me, then you may do it again sometime...
http://www.youtube.com/watch?v=gwjG7...zVv3-KUDOnJPhQ
Originally Posted by Deltadeville View Post
Originally Posted by SENTRY 62 View Post
Try this on for size. Click to 12:40 (my 1st landing attempt ) and then hang on to the end. I had fog starting at 6" off the deck. I also have no AHI.
https://vimeo.com/29731146
gundamnitpete is offline Find More Posts by gundamnitpete
Old Oct 10, 2012, 07:20 PM
DesJardins is offline
Find More Posts by DesJardins
DesJardins's Avatar
United States, AZ
Joined Oct 2012
Originally Posted by Mike Freas View Post
setup?
DJI Flame Wheel F450 Quad Multi-Rotor stock frame
Stock equipment:
DJI 30Amp OPTO ESC's
DJI Naza-M flight controller
DJI Naza assistant @
Software (v1.8) Firmware (2.02)
DJI Naza GPS compass @
(X -3cm , Y +6cm , Z -10cm)
Upgrades:
T-motors (MT-2212-16) "900Kv"
Graupner (10x5) E-props #1326
"Quadrocopter" Prop adapters (8mm-5mm)
Scorpion battery straps (Small)
Radio gear:
Spektrum DX8 DSMx transmitter
Spektrum AR7010 DSMx receiver
Spektrum DSMx satellite
Battery pack:
Pulse 3S 2250mAh 45C
FPV gear:
GoPro Hero2
ImmersionRC GoPro HD A/V cable
ImmersionRC 600mW 5.8GHz Tx
ImmersionRC 3S 460mAh 35C Tx lipo
ImmersionRC "EZOSD" (NOT INSTALLED YET)
5.8 GHz Circular Wireless Omni Skew Planar Wheel Tx/Rx Antenna set
Fat Shark Dominator goggles & 5.8GHz Rx module
DesJardins is offline Find More Posts by DesJardins
Old Oct 11, 2012, 01:21 AM
Pass1 is offline
Find More Posts by Pass1
Pass1's Avatar
Saudi Arabia, Makkah Province, Thuwal
Joined Aug 2012
Originally Posted by Helidaho View Post
Some video with my new Sony Action Cam filming at 720p and 120fps, made for some nice slo-mo action!
http://www.youtube.com/watch?v=7JngzUalHF0
Paul
How do you make such nice long sweeping banked turns?
Pass1 is offline Find More Posts by Pass1
Old Oct 11, 2012, 09:01 AM
slowjett is online now
Find More Posts by slowjett
-NEFPV-
United States, MA, Sturbridge
Joined Jun 2008
A good mix of Yaw and Roll when turning I assume.
slowjett is online now Find More Posts by slowjett
Old Oct 11, 2012, 09:17 AM
squishy654 is offline
Find More Posts by squishy654
squishy654's Avatar
United States, CA, Sacramento
Joined Jun 2010
1km FPV quad flight...
900 metre FPV quad flight (4 min 56 sec)
squishy654 is offline Find More Posts by squishy654
Old Oct 11, 2012, 09:18 AM
rcmonster99 is offline
Find More Posts by rcmonster99
Houba ! Houba !!
rcmonster99's Avatar
United Kingdom, England, Milton Keynes
Joined Sep 2003
I was at the edge of my seat all the time. great adventure !! could you do the same video from the ground recorder to see how you used the OSD ?
Originally Posted by Barn-E-Stormer View Post
I wish there was someone near me to fly FPV with.
rcmonster99 is offline Find More Posts by rcmonster99
Old Oct 11, 2012, 10:37 AM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
You mean fly it like a plane
My Tri flys like this but usually ends in the tree or something
chanyote66 is offline Find More Posts by chanyote66
Black Baron is offline
Find More Posts by Black Baron
Black Baron's Avatar
United Kingdom
Joined Aug 2011
My second day of FPV flight with my DJI Naza Quadcopter.
I wanted to go out over the sea and over the cliffs but I'm still getting use to flying a quad and its a little un-nerving knowing if it drops from the sky it could be gone for ever, maybe next time I will be more brave
Quadcopter FPV fun at the seaside - DJI Naza Flamewheel (11 min 11 sec)
Black Baron is offline Find More Posts by Black Baron
Old Oct 11, 2012, 02:08 PM
Pass1 is offline
Pass1's Avatar
Joined Aug 2012
(setting the scene: I am new to flying)
I try mixing yaw and roll, but I seem to either end up going backwards at the end of it, or come to a stop.
Do I still need to be pitching forwards throughout the turn?
Thanks!
<video removed>
Did you crop the video? I am impressed that you managed to keep the blades out of the picture!
Ciao!
Old Oct 11, 2012, 03:29 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Yes. With a multi-rotor you have to hold some forward pitch angle to maintain speed
against airframe drag, including through turns. A pure yaw input will do nothing
but rotate the craft around its yaw axis while maintaining the same attitude
relative to the direction of travel (continue going the same direction, but
camera pointed somewhere else), so you generally need a roll input to
lean the craft in the direction you want to turn, and a coordinated yaw
input to point the craft in the new direction of travel.
Unlike a full scale aircraft, you can't complete a turn without using both inputs.
He pulls off "long banked turns" mainly by flying very fast. The bank angle itself
is a simple function of gravity, speed and turn radius (same as on a fixed wing aircraft/bicycle/motorcycle
/snowboard.. etc) http://www.pilotfriend.com/calcs/cal...calculator.htm
The props are above the camera and thus above the horizon. Notice that when hovering in
place the horizon is not visible at all which means he's got the GoPro itself angled way down
thus can't see the props either. It's not a view you'd want to fly through, because you can't see
where you're going, especially if going fast.
ian
Daemon is online now Find More Posts by Daemon
Old Oct 11, 2012, 04:39 PM
guipedroso is offline
Find More Posts by guipedroso
guipedroso's Avatar
Brasil, PR, Curitiba
Joined Apr 2010
Mission 2 - Rocket Lauching (3 min 48 sec)
guipedroso is offline Find More Posts by guipedroso
Old Oct 11, 2012, 06:34 PM
Berkie is offline
Find More Posts by Berkie
Great Southern Land
Berkie's Avatar
Australia, VIC, Melbourne
Joined Feb 2007
Originally Posted by Japanx View Post
I did my best to transmit the perceptions of an exteme FPV session through a PC screen.
A super carbon reinforced Skywalker, 1450kv motor, 2x3000 4S batts and assited by the Rvosd and my loved Dragonlink.
I hope you enjoy.
http://youtu.be/kU2D5oZw1fA
Japanx.
Rated SS (Stunning Stuff!)
Kev
Berkie is offline Find More Posts by Berkie
Old Oct 12, 2012, 01:22 AM
Japanx is offline
Find More Posts by Japanx
Spain, CT, Molins de Rei
Joined Mar 2012
I hope you enjoy.
Japanx.
Kev
Wow! Thank you very much. I'm planning more SS flights for today... lets see what can i do
Japanx.
Japanx is offline Find More Posts by Japanx
Old Oct 12, 2012, 02:47 AM
aoq is offline
aoq
Find More Posts by aoq
aoq
United Arab Emirates, Ras al Khaimah, Al Riffa
Joined May 2012
This is my second FPV video cruising around the coast with a beautiful sunset view, did some low level flying, passing between buildings and entering a flamingo natural lagoon. Hope you enjoy.
FPV Sunset & Flamingo (14 min 35 sec)
Equipment:
ezUHF
Immersion 600mw 5.8ghz (5.8ghz cloverleaf antenna)
GoPro 2
Fatshark Predator
Skywalker
aoq is offline Find More Posts by aoq
Gallery FPV Videos For those that want to see what FPV flying is like check this out [Part 5] typicalaimster FPV Talk 9686 Jul 19, 2012 11:13 AM
Gallery FPV Videos For those that want to see what FPV flying is like check this out [Part 4] helirap1 FPV Talk 10416 Dec 08, 2010 11:52 AM
Gallery FPV Videos For those that want to see what FPV flying is like check this out [Part 3] VRflyer FPV Talk 1575 Dec 24, 2008 05:13 PM
Gallery FPV Videos For those that want to see what FPV flying is like check this out [Part 2] Impulze FPV Talk 723 Mar 30, 2008 09:42 PM
Discussion FPV Videos, For those that want to see what FPV flying is like, check these out !!! JettPilot FPV Talk 511 Oct 14, 2007 12:18 PM
