Tn
Joined Jan 2011
Sorry for the delay
I built the top wing in the usual way. But I did find that the right wing panel, center rib to second rib, was to far apart which would have caused the strut mounts out of line with all the others. I set the plane back up in the jig to set the top wing incidence right. I made the struts from 1/8 lite ply, the same as the strut mount ribs in the wings. With the wing set in the jig, I clamped tne struts in plane, and one by one drilled and then reclamped them together. I then took it apart threaded the hyoles, and harden the screw threads with thin ca. Pat |
Tn
Joined Jan 2011
Then I started to make a cowl. I glued up some soft 1/4", 3/16", 1/8". I then rough carved it to shape, and then wet some 1/16" and rubberband it around a can, and left over night. I then wraped it around it with some bands, let it dry over night. I'm using Elmer's wood glue on this. I then glued some 1/64 x 5/16 wide ply band to the inside for strength.
I then made three mounts from balsa, and thin ca soaked them, and then mounted the cowl. Center hole is still to small, but I will enlargen that later. Pat |
Tn
Joined Jan 2011
We did have a dog, but had to put her down last year. She thought she was cat though, just a bigger cat. |
| Thread Tools | |
| For Sale Proctor Nieuport 28 Silk and Randolph Dope Finish | LCS | Aircraft - Fuel - Airplanes (FS/W) | 9 | Jul 29, 2012 12:20 PM |
| For Sale Maxford Nieuport 28 | daylight99 | Aircraft - Electric - Airplanes (FS/W) | 3 | Jul 09, 2012 09:16 PM |
| Wanted cowl 4 proctor nieuport 28 | paddles1961 | Aircraft - Fuel - Airplanes (FS/W) | 1 | Jul 08, 2012 09:44 PM |
| Discussion AerodromeRC 6th scale Nieuport 28 | Bengtson | Scale Electric Planes | 2 | Jun 28, 2012 08:07 PM |
| Sold Maxford Nieuport 28 EP 40 | daylight99 | Aircraft - Electric - Airplanes (FS/W) | 4 | Mar 21, 2012 09:10 AM |
