This thread is privately moderated by Adrian_M, who may elect to delete unwanted replies.
Old Jul 18, 2012, 11:55 PM
Adrian_M is offline
Find More Posts by Adrian_M
Auckland - New Zealand
Joined Dec 2010
Multi Wii config
here is my config my little quad definitely doesn't fly as good as it did before I actually crashed it today and bent a motor shaft as i was descending fast i gave it some throttle and it wobbled and turned itself upside down and crashed
Adrian_M is offline Find More Posts by Adrian_M
Reply With Quote  (Disabled)
Old Jul 19, 2012, 12:07 AM
Adrian_M is offline
Joined Dec 2010
i noticed you did an electric boat conversion here are a couple of my electric boats
http://www.youtube.com/results?searc...ac.xogsqihiSL0
Old Jul 19, 2012, 12:33 AM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
KV?2200
Dimension?Φ18mm x 17.5mm (excluding shaft)
Weight?16.1g/0.57oz (not including connectors)
Diameter of shaft?Φ2mm
Length of front shaft?8mm
Resistance: 0.52 Ω
Max efficiency currency: 2A to 6A, >70%
Max working currency: 8.5A
IO: 0.5A/10V
You can show them guys that 6 inch peop will get you all the power out of that motor on 3S.
Unless you over ampping it. So really you can use any prop theat does not go over 8 amps.
Prop recommendation:
3S/10V, GWS 5030HD, 16500RPM, 5.5A, thrust 272g
2S/7V, GWS 7035HD, 10150RPM, 5.6A, thrust 215g
Also you P on you roll and picth should be more lower like 1.9 to 2.9
DoctorAudio is offline Find More Posts by DoctorAudio
Old Jul 19, 2012, 03:19 AM
Adrian_M is offline
Joined Dec 2010
Originally Posted by DoctorAudio View Post
KV?2200
Resistance: 0.52 Ω
IO: 0.5A/10V
yep that's the motors I have
Old Jul 19, 2012, 11:42 AM
Milwaukie , Oregon
Joined Feb 2003
Just watch the amps.
Hopefully you have a amp meter?
Old Jul 19, 2012, 11:52 AM
Milwaukie , Oregon
Joined Feb 2003
But I am pretty sure you need to turn down your P for sure.
It is to high!
A smaller quad responds faster. I have seen one with a 1.8 P.
Old Jul 19, 2012, 02:50 PM
Milwaukie , Oregon
Joined Feb 2003
Yes your motors. are 2200 kv.
For Sale Quadrino Multi Wii Flight Controller $95 FREE SHIPPING kjcffmedic Aircraft - Electric - Multirotor (FS/W) 1 Jul 09, 2012 08:36 PM
Sold citris multi wii se / baro/ mag quadcopter007fpv Aircraft - Electric - Multirotor (FS/W) 1 May 08, 2012 01:42 PM
Sold multi wii blue tooth quadcopter007fpv Aircraft - Electric - Multirotor (FS/W) 0 May 08, 2012 03:05 AM
For Sale multi wii stuff... tigar Aircraft - Electric - Multirotor (FS/W) 1 May 02, 2012 02:43 PM
Help! Multi Wii board Camelboy Multirotor Talk 15 Feb 26, 2012 07:50 AM
