Old Jul 20, 2012, 08:02 AM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
Gordon I assume you mean this one?
My DR1 flys fine at full throttle but at the small indoor hall we have it is positively embarrassing on low throttle. I have heard Russian tractors that make less mechanical racket.
Does the pinion supplied with Bob's gearbox fit the existing Triplane motor? If so I'm ordering one!
Or should I get Bob's complete set up with motor here?
http://www.bsdmicrorc.com/index.php?productID=968
Thanks, John
Originally Posted by Gordon Johnson View Post
I retrofit a BSD ball bearing 7mm gearbox with a long-can 7mm motor in my Dr.1. It's quiet and develops 18% more thrust for almost exactly the same weight.
Gordon
jj604 is online now Find More Posts by jj604
Old Jul 20, 2012, 01:55 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
I did a thread on the conversion
http://www.rcgroups.com/forums/showthread.php?t=1557088
I was working with Bob on this solution before the Dr.1 was available and shipping. The horizontal mount screws onto a standard BSD gearbox, then cut away foam in the Dr.1. There may be other ways to mount and shoehorn this gearbox into a Flyzone plane. But, this way works.
The complete gearbox setup from Bob is probably the way to go since it's got the Horizontal piece, the long-can motor, and everything needed including the longer prop shaft to get it out through the cowl.
Everyone who sees my Dr.1 fly comments on how quiet it is.
The pinion on BSD's gearbox will fit the Flyzone 7mm motor. The problem is the Flyzone motor is a really hot wind motor. That's why it has a 5.5:1 gear ratio and a smaller than 5x3 prop (which are appropriate for that wind). You don't want to run the Flyzone motor in a lower gear 4:1 gearbox and a larger prop. It would kill that motor.
The long can motor is not quite as hot a wind as the Flyzone motor, and its larger size means it can swing a slightly larger prop when used with the lower 4:1 gearing in the BSD gearbox. I calculated motor constants for the long-can motor the Flyzone motor and compared static tests etc before the Dr.1 was shipping to figure this all out. Since all the Flyzone micro planes so far have used the same motor/gearbox/prop I new the lay of the land before the Dr.1 was available and had this solution ready.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Jul 20, 2012, 02:55 PM
speedy01 is offline
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Originally Posted by RayRangel View Post
Based on experience with Dr1 and Albatros:
Minus:
Fuse is glued together, no repair access
"Based on experience", invest in some Naphtha (Lighter Fluid) if you think you'll need to work inside the fuselage. Run a bead along the seam with a QTip as you gently pry the fuselage apart starting at an end. Very, very easy...but the cowling may be a challenge.
Gene K
speedy01 is offline Find More Posts by speedy01
Old Jul 20, 2012, 04:37 PM
RayRangel is offline
Find More Posts by RayRangel
United States, GA, Centerville
Joined Mar 2012
Thanks Speedy, I'll do that. Do you recommend I glue it back together or tape ala Champ?
RayRangel is offline Find More Posts by RayRangel
Old Jul 20, 2012, 04:49 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Thanks, Gordon. That's very useful. Looks like Bob is about to get an order.
John
Gordon
Old Jul 25, 2012, 11:02 PM
matthew954 is offline
Find More Posts by matthew954
matthew954's Avatar
Joined Oct 2005
I had gotten a DR1 about a month and a half ago, but have only flown her once. She flew great. I have the Nieuport on the top of my list. I've had a big year for micros lol. Got a Mosquito, Mustang, DR1, T28. Next up is the Nieuport lol.
matthew954 is offline Find More Posts by matthew954
Old Aug 31, 2012, 02:12 PM
BlazingStar is offline
Find More Posts by BlazingStar
-=BS=-
BlazingStar's Avatar
Thousand Oaks, CA
Joined Jul 2009
It's time to resurrect this thread.
I have mine on order and expecting it next week.
Looks awesome!!
BlazingStar is offline Find More Posts by BlazingStar
Old Aug 31, 2012, 02:56 PM
D Johnson is offline
Find More Posts by D Johnson
Just some guy
D Johnson's Avatar
Joined Aug 2006
They are now in stock.
DJ
D Johnson is offline Find More Posts by D Johnson
Old Aug 31, 2012, 04:41 PM
Pouncer is offline
Find More Posts by Pouncer
Wanton construction
Pouncer's Avatar
Stockholm Sweden
Joined Sep 2006
DJ
Cool, I've ordered it in spare parts, minus details such as dummy pilot/m'gun and pushrods, came out at $40 + shipping, very reasonble IMO.
Hope it flies as well as the Dr I and the Albatros!
Pouncer is offline Find More Posts by Pouncer
Old Aug 31, 2012, 10:58 PM
jwman is offline
Find More Posts by jwman
Chillicothe, OH
Joined Mar 2008
Parts on order from Tower. Have a AR6400 ready to drop into it
jwman is offline Find More Posts by jwman
Old Sep 01, 2012, 12:08 PM
Just some guy
D Johnson's Avatar
Joined Aug 2006
Pouncer you will not be disapointed. It does require a bunch of right thrust.
Old Sep 02, 2012, 06:16 PM
Pouncer is offline
Wanton construction
Pouncer's Avatar
Stockholm Sweden
Joined Sep 2006
Thanks for the tip, on the Dr I and the Albatros I stuck to the side thrust as well I could make out from the mold, I trust I can do the same in the Nieuport?
It does look like a bigger plane than its predecessors, partly because the pilot figurine is a bit small, but the wheels look on the small side as well?
Not a complaint, just a remark; the Dr I has a number of departures from scale but they all contribute to its beautiful flight characteristics.
Looking forward to this!
Old Sep 02, 2012, 10:54 PM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
I hope to see a few of these up at the NEAT Fair as Fokker fodder during the Dawn Patrol each morning!
Dave-- Are you bringing one?
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Sep 04, 2012, 01:48 PM
Just some guy
D Johnson's Avatar
Joined Aug 2006
We should have some with us.
DJ
Old Sep 04, 2012, 04:16 PM
-=BS=-
Thousand Oaks, CA
Joined Jul 2009
Oh boy....
Dawn patrol here I come....
Discussion Another Micro Nieuport & Tissue Printing Tutorial mtflyr Scratchbuilt Indoor and Micro Models 236 Apr 07, 2016 03:32 PM
Discussion Start of Another Micro Nieuport-11 mtflyr Scratchbuilt Indoor and Micro Models 50 Nov 08, 2015 09:43 PM
Question Flyzone micro super cub zamjohn Micro Ready-to-Fly 3 Sep 28, 2012 09:05 PM
Discussion Flyzone Micro Nieuport 17 wattman Micro Ready-to-Fly 18 Sep 15, 2012 04:44 PM
