Old Oct 03, 2012, 01:07 PM
jsflyrv is offline
Find More Posts by jsflyrv
Team Armattan
USA, OR, Hillsboro
Joined Feb 2011
What you have is fine as long as there are hole patterns to accept 45mm boards.
PM me a price and I will paypal to you.
jsflyrv is offline Find More Posts by jsflyrv
Old Oct 03, 2012, 01:12 PM
Dialfonzo is offline
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
I can put slots on the bottom.. Or another thing.
45mm are present on both top and bottom.
Top have also 30.5mm.
Let me check the material it use.
Top and bottom in 1mm or all 1.5mm?
Dialfonzo is offline Find More Posts by Dialfonzo
Old Oct 03, 2012, 01:52 PM
jsflyrv is offline
Team Armattan
USA, OR, Hillsboro
Joined Feb 2011
I would like 1.5mm, it adds more weight but with the motors i will use it will be fine.
Old Oct 03, 2012, 01:56 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Perfect..
Old Oct 03, 2012, 06:05 PM
dybbob is offline
Find More Posts by dybbob
United States, MI, Dansville
Joined Oct 2012
email sent for a dji 450 kit.
bob
dybbob is offline Find More Posts by dybbob
Old Oct 05, 2012, 12:59 AM
$tryk3r is offline
Find More Posts by $tryk3r
Joined Feb 2009
I just wanna thank Flyhigh300 for hooking me up with the spider upgrade for my dji quadcopter!! I'll post pics once I have it built. Can't wait to order my vtail one.
$tryk3r is offline Find More Posts by $tryk3r
Old Oct 05, 2012, 01:15 AM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
Buy , buy and buy guys. He is working a a project he needs to finish!
DoctorAudio is offline Find More Posts by DoctorAudio
Old Oct 05, 2012, 03:18 AM
biz18434 is offline
Find More Posts by biz18434
United States, FL, Pensacola
Joined Feb 2012
Are you selling this?
Hello, are you selling the DiaLFonZo-MiniSpyder-Assembly? If you are selling how much will it cost and where can i get one?
Description:
biz18434 is offline Find More Posts by biz18434
Old Oct 05, 2012, 03:42 AM
Milwaukie , Oregon
Joined Feb 2003
He is working on cutting I think two, maybe this weekend!
Old Oct 05, 2012, 05:43 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Attachment 5208032
Yes..
I have to change the motor mount a bit to accomodate the motor for "jsflyrv" setup.
Then i will cut it and look if everything is right..
Old Oct 05, 2012, 07:59 AM
mikob2d is offline
Find More Posts by mikob2d
Joined Jul 2012
Hi,
There is a quick-and-dirty pictures of my "in progress" APM2 Quad with the DJI-SpyderQuad frame.
Major difficulty encountered was for mounting the APM2.
APM2 use a rectangle form factor, so mounting holes was front of the holes cutted in the frame's bottom plate.
I had to cut a loarger copper board that fit 4.5x4.5 square holes.
Then i used the APM2 case to fix it on double sided glue foam.
This results in a no space left after using vertical 3pin headers between the two plates, but it fits !
I actually added a pitch-only gimbal in the front of the frame, instead of using backplate to do gopro mounting that is not on the pictures.
I'll be back here after some PID tuning to post a video of the quad
mikob2d is offline Find More Posts by mikob2d
Old Oct 05, 2012, 08:07 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Nice..
You didn't have the space up front under the top plate to put the APM2 ?
Looking forward to see the Pan gimbal.
I will make one for sure.. if only i could buy some time on eBay...
Here is a modification i have done for the RoundBoom version.
If it work good i might transfer the change to that as well
Old Oct 05, 2012, 08:26 AM
mikob2d is offline
Joined Jul 2012
Nice..
Désolé je te répond rapidement en francais, je viendrai "traduire" ma réponse dès que je peux ^^' (Je lis très bien l'anglais, même technique, mais pour écrire c'est autre chose...)
J'ai bien réussi a faire tenir circuit de distrib + plaque d'adaptation + APM2 + cable servo (pluggué verticalement, le seul d'ailleurs, les autres sont sur des connecteurs coudés donc moins de soucis), mais il reste 0 mm de libre
Ceci est dû a la plaque d'adaptation qu'il faut surrelever pour pas qu'elle ne touche le circuit de distribution ainsi qu'a la mousse double face.
En pouvant fixer directement l'APM2 on aurait pas de soucis ! (il suffit de ne pas percer les trous autour des emplacements de fixation en 4.5cm x 4.5
Je te ferais un petit croquis et des photos plus détaillées, si tu veux changer la bottom plate en conséquence
Old Oct 05, 2012, 08:29 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Oui ce serait aprécié..
Old Oct 05, 2012, 09:23 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Discussion DiaLFonZo-Copter Crazy2Fly Quadcopter 340mm Dialfonzo Multirotor Talk 87 Feb 07, 2016 06:41 AM
New Product DiaLFonZo-Copter Boom Block Dialfonzo Multirotor Talk 88 Mar 21, 2014 05:34 AM
Build Log Unrealistic's HEXorcism 600 - Luis & DiaLFonZo-Copter unrealistic Multirotor Talk 47 Oct 23, 2012 04:09 AM
New Product DiaLFonZo-Copter - MicroTrinity Quad Dialfonzo Multirotor Talk 6 Jul 09, 2012 08:26 PM
