Old Jul 18, 2012, 08:14 PM
mtflyr is offline
Find More Posts by mtflyr
Centreville,VA,USA
Joined Apr 2001
Start of Another Micro Nieuport-11
In what may be the one of the last in my series of my micro Nieuports I'm starting a 12.5" WS Nieuport-11. Well matbe a 28 somewhere down the road.
Speedy01,Gene sized it up for me and I plan to use Vapor e-gear.
Included a few pic's of some of my Micro WWI birds including my 14"WS NP-11
I'll have to post the video on it.
Pete
mtflyr is offline Find More Posts by mtflyr
Old Jul 18, 2012, 09:26 PM
Yellow Baron is offline
Find More Posts by Yellow Baron
Back in the game.
Yellow Baron's Avatar
3" from insanity, 2' from the computer ,Richford, Tioga county, Southern Tier, New York, U.S., North American Continent, Northern hemisphere, Earth, The Sol System, Milkyway Galaxy, The Universe, The Current Dimension, Your Selected Realm of Reality.
Joined Dec 2006
What templates are you using? Are the others (except the other nieuport and the sopwith tripe) flyzone conversions?
Yellow Baron is offline Find More Posts by Yellow Baron
Old Jul 19, 2012, 07:56 AM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
One DR-I is a scratch build, the Sopwith Triplane is Jin's kit, the Nieuport-11 is scratch the Albatros and other DR-I's are FZ's
The paper plans are from ECards paper models.
Pete
Old Jul 20, 2012, 03:25 PM
NEWBEFLYER is offline
Find More Posts by NEWBEFLYER
Crazy Canuck
NEWBEFLYER's Avatar
United States, VA, Woodbridge
Joined Apr 2007
So after this what WWI plane are you thinking of next? Ever thought of maybe a Gotha bomber? That would be a nice addition to the German fleet as it will have a strong escort force to protect it from those nasty Nieuports.
NEWBEFLYER is offline Find More Posts by NEWBEFLYER
Old Jul 20, 2012, 03:36 PM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
No bombers for me just the scouts. Maybe an E-III
However, I'd like to get Zeppelin paper plan size it to 1:24 scale and have Jin work up a laser cut 1mm Depron foam kit with some sort of helium bag inside and a couple of micro motors and props.
Now that would be cool
Pete
Old Jul 21, 2012, 10:37 AM
Groovechampion is offline
Find More Posts by Groovechampion
Micro enthusiast
Groovechampion's Avatar
Australia, SA, Adelaide
Joined Aug 2011
Pete, these works of art mate!
Groovechampion is offline Find More Posts by Groovechampion
Old Jul 22, 2012, 10:12 AM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Thanks Nath, but not hardly.
I enjoy the history of these plane and of those who flew them and the fun of building and flying them. Anyone can do these paper to Depron foam conversions. It is easy once you get the hang of it. They also can look pretty good and fly good too.
Got some of the control surfaces done just going with rudder and elevator. This NP-11 has a 12.5" WS and I'm using Vaport e-gear that my friend Speedy01/Gene gave me to play with. My goal is to try and keep it to the same overall weight of the Vapor 12grs or so +- though the weights starting to add up
Note: The motor mount is 2mm Depron foam with sanded clear light plastic, the LG axle joint is 1/32 ply with sanded clear light plastic this gives these areas extra strength without too much extra weight.
Pete
Old Jul 24, 2012, 07:55 AM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Installed the motor/gearbox, brick and painted the prop. Ready for the push rods.
I'll see how she flys before adding a fake LeRhone.
Pete
Old Jul 25, 2012, 08:14 AM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Got the push rods in, finished the LG and made the wheels. Thought I'd add some crushed aluminum tubes to the fuselage to help strengthen the LG positions. The wheels are 2mm Depron with 1/32 Ply back and brass tube. CF rod connector and wire axle for suspension.
Next add the bottom wing, fuselage bottom then the top wing and make the Lewis Gun.
Raoul Lufbery stopped by to oversee the construction of his NP-11
Pete
Old Jul 25, 2012, 08:34 AM
speedy01 is offline
Find More Posts by speedy01
Gulf Breeze, FL
Joined Jul 2006
Originally Posted by mtflyr View Post
... crushed aluminum tubes to the fuselage to help strengthen the LG positions.
Nice!
Raoul Lufbery stopped by ....
He he.
Gene K
speedy01 is offline Find More Posts by speedy01
Old Jul 26, 2012, 08:11 AM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Got the bottom wing, LG and tail skid on. Top wing fitted but not attached yet as the struts are not finished. So far everything's going together really well.
Weight is adding up though and I'm at a total weight of 16 grs now with every thing on the scale.... I'm not sure how the Vapor motor/gearbox and prop will work with this bird.
If there's not enough power I will go with a BSD 7mm motor and gearbox.
After reviewing colors and documents on Luf's NP-11 N1256 it appears that the undersurface of this bird was more likely blue based on it's number so that's what I'm going with.
Got some color on bottom surfaces, bottom wing French roundels, and worked on all the top wing struts.
So far he just stands there and has said nothing a man of few words...
Pete
Old Jul 26, 2012, 06:48 PM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Got the top wing on and ready for the first test flight. Seems like there's plenty of power to fly it and she glide tested very good.
AUW so far with an 80 Mh battery 19grs I will mostlikey be up to 21 grs when finished with Lewis gun pilot and all paint. I think it should be a very good flyer.
My good buddy Speedy01 (Gene) helped me out again and worked up the proper tail data for this bird so I could make up a tissue decal. I just put it on with water to see how it looks, I'll put them on after I paint it.
Pete
Old Jul 26, 2012, 08:03 PM
RCAddict16 is offline
Find More Posts by RCAddict16
United States, VA, Ashburn
Joined Apr 2012
Looks nice! Are you going to give it a gun and mini tail wires?
RCAddict16 is offline Find More Posts by RCAddict16
Reply With Quote  (Disabled)
Old Jul 26, 2012, 09:50 PM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Thanks RC.
Yes, a Nieuport -11 would not be right with out a Lewis gun and flying wires. Check out my two previous 14"WS Nieuport=11's in this forum.
I still have lots of detail to do yet but hope to test fly tomorrow first.
Pete
Old Jul 26, 2012, 11:46 PM
Stenz28 is offline
Find More Posts by Stenz28
Utah
Joined Sep 2009
I'm making a guillows BF109 (505) and I'm loving the threads I've found here!
Do you think I could use the guts from a crashed ember 2 for power?
I've been flying helis, but it seems I don't have the knack, and the bigger I go the worse I get!
I think I'll order some foam, as I've been making paper airplanes and things for a while! (http://www.rcgroups.com/forums/showthread.php?t=1309681)
I have guts from an MSR and also a CX3.
Thanks and
SUBSCRIBED!
Will
Stenz28 is offline Find More Posts by Stenz28
Discussion Another Micro Nieuport & Tissue Printing Tutorial mtflyr Scratchbuilt Indoor and Micro Models 235 Dec 12, 2013 06:04 PM
Sold Proctor Nieuport 11 Kit ted99 Aircraft - Fuel - Airplanes (FS/W) 2 Jun 29, 2012 10:01 PM
Sold Micro Invent Peanut Scale Nieuport 11 Tim Wolff Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 8 Feb 27, 2011 07:07 PM
Question Looking for a micro Nieuport 11 kit helipilot Scratchbuilt Indoor and Micro Models 6 Sep 21, 2009 10:45 AM
Sold peanut scale Nieuport 11 micro invent Flying glass Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Mar 16, 2008 05:39 PM
