Good luck with the build. |
What kind of throws are you getting on ailerons? I'm ready to cut the servos in but took some quick measurements and with the longest servo arm, I look to get about 20* of aileron with endpoints at 100%. Are you using extended arms on the ailerons? JC |
I used standard arms. I wanted to follow the designer’s recommendations as much as possible. As you can see, I probably have around 20 degrees throw. (I did not measure) It does not look like much compared to some of my 3D monsters I have but, Those are barn doors with 20 degrees!! They are massive ailerons. If I do need more throw then I can easly install extended arms to gain it. I will report back soon, I am going to fly later today.
Maiden
Got her in the air this morning. CG at 100mm. Electronics are:
Turnigy C3530-1100 motor w/12x6 APC prop Hobbywing 40A ESC w/5v UBEC Hitech HS65MG's all the way around Spyder 1800mh 3S 25c battery Spektrum AR6100e receiver (DX8 trans.) Don't have a weight yet. Don't even have throw measurements either. I just set everything and went for it. First flight she wanted to pitch up badly. I thought "I've got everything as far forward as it will go...". Landed and realized my elevator linkage was off. Back to the bench. Also lost wheel nut on front LG. First change, lock nuts on wheels and remove pants. Done. Couldn't get the ailerons to level properly so did some changing there as well. Had to move battery and ESC all the way forward to get to balance at 100mm CG. Here are the changes I made: -Got rid of the non adjustable aileron control linkage. Replaced with adjustable. -Replaced the kevlar thread on the rudder control with a proper lightweight cable and adjustable arm mounts. Just recycled from an old plane. May go back to the kevlar thread for weight. Just got impatient on trying to make the adjuster. -Added spacers between landing gear and wheel. Wheel wanted to rub on wheel pants mount. Ended up getting rid of wheel pants. They'll just get knocked off anyway. Kept spacers though. -Cut elevator control arm rod shorter in order to get elevator servo to fit behind wind and clear aileron. Used an adjustable nut to secure control rod to servo arm instead of both "Z" bars. Kept "Z" bar on elevator control horn but cut the other one off and just glued straight piece of wire into carbon rod. -Added 1.55mm spacer plate behind left side of motor mount to give right thrust offset. Seems to be enough so far. Other things I'd like to do: -Add thin plywood for servo mounts. Clean up servo installation. -Stiffen the rudder and vertical stabilizer. I noticed quite a bit of wiggle while flying but it really didn't affect the plane as far as I could tell. Maybe even reinforce the rudder hinge in the foam. -pre cut the pocket for the rudder servo before gluing the top half of the fuselage. This would allow easier placement in the middle of the fuse. -Add longer servo arms for the ailerons. Could use some more throw but we'll see. It flies great as it is. It's a good flier. It's slower on moves than a balsa plane, but that's to be expected. It's my first EPP plane so I'm getting used to it. It floats through all of the moves instead of instant snaps. It's a great plane for learning 3D as a beginner and will be great for relaxed flying for an experienced 3D pilot. The moves are big and slow. Easy to pull out of a situation. Gives you time. I'm very happy with the Sbach. ![]() ![]() ![]() Here are some pics of my setup |
I'm thinking 35* at least for good 3D and 45* is even more desirable. Maybe I'm wrong but my gut says it needs it. I will convert to adjustable aileron and elevator linkages as well. Anxiously awaiting your flight report. Your thoughts on all throws and CG? JC |
Pre-Maiden.....
I think I got everything done and ready for my Maiden flight. The Only thing I need Now at this moment if for the rain to stop.
![]() But till then I took some time to get a few "Pre-Maiden Flight" pictures. Wanted to share my set up with anyone interested before I Pummel this beautiful maching to the ground like how Iv been doing to my 44" and 32" TH planes . AnyHow, Enjoy! And Thank You Shawn, cdee, parksinatree and of course, Twisted Realm. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
| Thread Tools | |
| Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! | aerofundan | 3D Foamies | 320 | May 22, 2013 01:25 AM |
| Discussion NEW Twisted Hobbys/ParkAero RC Factory 31" Sbach 342 | Greengiant | 3D Foamies | 130 | Jan 24, 2013 01:49 PM |
| Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! | cbriggs11 | 3D Foamies | 76 | Aug 30, 2012 12:08 AM |
| Discussion NEW RC Factory-Park Aero/Twisted Hobbys 31" Sbach 342 | Greengiant | 3D Flying | 0 | Nov 04, 2011 11:34 AM |
| Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. | hercdriver7777 | 3D Foamies | 97 | Oct 19, 2011 06:34 AM |
