Old Jul 25, 2012, 06:32 AM
Gravitycheat is offline
Find More Posts by Gravitycheat
Don't give in to gravity
Gravitycheat's Avatar
USA, FL, Palm Harbor
Joined Dec 2009
Originally Posted by JC Spohr View Post
Nice job!
JC
Originally Posted by toolman18 View Post
Shawn,
Very good job on the build pics, Everything is very clear and understandable. Great Job!!!! I wasnt going to say anything but maybe you should shave your arms.
Originally Posted by cdee View Post
what JC said +1... looks really nice Gravity!!
cdee
Thanks guys. If it flys any where near as good as it is building. We should have a winner here.
It's funny...i would get on a build roll and forget tot take pics and then have to go back and shoot photos. LOL
For those that may be starting the build and are not aware. My build photos are here: http://www.rcgroups.com/forums/showthread.php?t=1694231
Hope they are helpful
Gravitycheat is offline Find More Posts by Gravitycheat
Old Jul 25, 2012, 09:33 AM
AirHermit is offline
Find More Posts by AirHermit
Fly Low!!!! No Sked.
AirHermit's Avatar
Joined Oct 2011
Looking great!
So far looks like i followd instructions pretty good. Thanks for posting pictures.
I'm keeping a close eye on the tail and pull pull assembly. I want to make sure i do mines correctly.
AirHermit is offline Find More Posts by AirHermit
Old Jul 25, 2012, 10:51 AM
Joined Dec 2009
Originally Posted by AirHermit View Post
Looking great!
I'm hoping to get to that later today. If time allows. Very happy so far with how it's going together.
There are a few areas where the instructions are not very clear or they have not been updated since enhancements have been made. I have contacted Brad at TH and RC Factory and they are working on updating the instructions.
The discrepancies are nothing major, just a little confusing. I am trying to address these areas of the build and make notes as I go. If you follow both the kit diagram and the build thread photos and narrative’s, you should do just fine. If you still have any questions, feel free to PM me. And I’ll be more than happy to help.
Shawn
Old Jul 25, 2012, 03:17 PM
toolman18 is offline
Find More Posts by toolman18
toolman18's Avatar
United States, TX, Portland
Joined Apr 2008
Originally Posted by Gravitycheat View Post
I just shaved them this morning
Now thats funny right there!
toolman18 is offline Find More Posts by toolman18
Old Jul 25, 2012, 03:22 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
My Build Progress
Thus far, this thing has built incredibly straight and accurate.
I am using Ron_Dog's "Coke Method" to build this plane but so far the Coke cans have mostly been used for weight.
I checked the "dry" alignment to the fuse before I glued the horizontal stab last night. It was exactly correct due to the keying built into the pieces. I wasn't expecting that. Typically, you can have some variation but this one is dead on because of RCF's production methods.
I glued it up and rechecked the alignment measurements - dead on.
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Jul 25, 2012, 03:25 PM
Sixinarow is offline
Find More Posts by Sixinarow
Addicted
United States, CO, Parker
Joined Dec 2011
What is so difficult about it? I don't have one but the directions look pretty simple.
Sixinarow is offline Find More Posts by Sixinarow
Old Jul 25, 2012, 03:48 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
It's not difficult, just unfamiliar to most.
Proper tension is the thing that scares most people.
I have a method for making the strings easily re-adjustable as does Hercdriver7777.
I'll share mine here as my build progresses and I suspect Shawn will address this as well.
JC
Old Jul 25, 2012, 04:06 PM
Joined Dec 2009
JC
I'll be using herc's method for the Pull Pull cable adjustments. Very clever method
Also i have an important build note. Make sure to install the motor mount prior to installing the top fuse section. It is one of the enhancements they did but apparently they did not change the instructions ( unless I missed it) I also believe that using tooth picks or using anchoring tabs as they mentioned is no longer necessary as I did not receive any in my kit.
I used plenty of Welders to adhere the mount to the surrounding EPP.
Old Jul 25, 2012, 06:23 PM
AirHermit's Avatar
Joined Oct 2011
Originally Posted by sixinarow View Post
...i don't have one.....
Anyways, im glad im waiting to see how the pull pull part is done.
Seems to be a tecnique or two out there.
And x1 on the motor mount, make sure its
Intalled just befor the top fuse.
Old Jul 25, 2012, 06:49 PM
Joined Dec 2009
Just posted my pull pull. Amazingly simple adjustment device.
Old Jul 25, 2012, 07:10 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
Use this Diagram Sheet for your build. It shows the updates.
The build instruction sheet appears to be for version 1.0 of this plane. The Czech version "Datasheet" diagram appears to be updated (although page 1 is in Czech) .
My understanding is that a new English version is in the works and should be available very soon.
http://www.rc-factory.cz/ke-stazeni/dokument-529-3.pdf
NOTE - the CG is 110mm now instead of 125mm
Okay - time for supper and then back to my build.
JC
Old Jul 25, 2012, 07:38 PM
Joined Dec 2009
JC
Thanks for posting this. This is the updated diagram. In fact the link to the old one has been removed by RCF. I will insert a link to this diagram in the first thread post. RCF is indeed working on new updated instructions to go along with it.
In the mean time though. If anyone has any questions on the build don't Hesitate to ask. Lots of helpful people here that are willing to help.
Old Jul 25, 2012, 09:13 PM
kenelder is online now
Find More Posts by kenelder
kenelder's Avatar
USA, FL, St Petersburg
Joined Dec 2003
nice gator.
kenelder is online now Find More Posts by kenelder
Old Jul 26, 2012, 01:08 AM
AirHermit's Avatar
Joined Oct 2011
http://www.rcgroups.com/forums/attac...mentid=5036502
Seems oh so simple but I would have never thought of this little device.
And its adjustable! Sweet! So glad i waited.
Thanks Gravity'.
Old Jul 26, 2012, 05:41 AM
Joined Dec 2009
Thanks Gravity'.
I would love to take credit for the device but.... the credit goes to Hercdriver7777 (chris) who has done many of these build threads. Thanks Chris!
Sorry for the terrible picture. I'll post a new one today.
Originally Posted by kenelder View Post
nice gator.
If you like Welders eating gators!
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 08:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion NEW Twisted Hobbys/ParkAero RC Factory 31" Sbach 342 Greengiant 3D Foamies 130 Jan 24, 2013 01:49 PM
Discussion NEW RC Factory-Park Aero/Twisted Hobbys 31" Sbach 342 Greengiant 3D Flying 0 Nov 04, 2011 11:34 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
