Old Jan 24, 2013, 09:39 AM
Tom Eutsler is offline
Find More Posts by Tom Eutsler
Tom Eutsler's Avatar
Asheville,NC
Joined Jun 2002
LG spread eagle
[QUOTE=Gravitycheat;23913193]
Originally Posted by Mike Smart View Post
I would say uptime4downtime has it about right, the Telink Yak is a model that you always want to have handy.
I find the undercarriage a bit low on the SBach and it spreads too much on landing, wheres the Telink undercarriages are a lot more durable.
Mike[/QUOTE
By Under carriage I assume you mean the landing gear. We have a modification we do to our landing gears which keeps them from spreading. We install a piece of line ( I use braided fishing line but any line that won’t stretch to much, would work) and install it from axel nut to axel nut. You could also drill a hole in the gear a little higher up on the gear. This would work better for taxing on grass runways. This mod keeps the gear from spreading on landing, especially those hard landings (which I seem to like to do). This mod has saved a lot of props.
Attachment 5475192
Shawn
I took a straight edge ,laid on bottom of fuse to find the highest or Max height that I cud run rubber bands across.
then I took some Piano wire , made it into a J shape with short 90 deg bend on top.
Drilled small hole in LG for 90 deg bend to go thru ,then drilled couple of small holes on either side of my J hook - after I centered it tween edge of Inside LG
Used small dia copper wire and threaded - such as shoe laces -thru holes and around my piano wire J hook - later when satisfied , covered my lace job around the J , with epoxy .
Now I can use rubber band[s] attached in the J hooks, to keep LG from going spread eagle .They are up high enough to avoid the grass.
Tom Eutsler is offline Find More Posts by Tom Eutsler
Old Jan 24, 2013, 07:08 PM
Gravitycheat is offline
Find More Posts by Gravitycheat
Don't give in to gravity
Gravitycheat's Avatar
USA, FL, Palm Harbor
Joined Dec 2009
[QUOTE=Mike Smart;23913388]
Originally Posted by Gravitycheat View Post
Hi Shawn,
Yes landing gear in the US
Thanks, I may give that a try.
I thought thats what you were referring too
[QUOTE=Tom Eutsler;23914102]
Sound like a great mod. How about a photo?
Gravitycheat is offline Find More Posts by Gravitycheat
Old Jan 25, 2013, 10:05 AM
Asheville,NC
Joined Jun 2002
LG spread eagle
I shud have done photo - so here ya go
One can add rubber bands as needed to reduce the flexing outward in not So
soft landings
Old Feb 01, 2013, 10:14 AM
jcansdale is offline
Find More Posts by jcansdale
jcansdale's Avatar
United Kingdom, Gunnerton
Joined Dec 2010
I've trying to decide what setup to get for a new Sbach. I've been flying the 32" models a lot and recently the Crack Yak Mini. I'm wondering if I should start as light as possible or jump in with heavy and powerful? I.e. 70 or 100g motor?
My preferred planes at the moment are the Crack Pitts on 3s and the Crack Yak Mini. What setup would you recommend I try for the Sbach?
Thanks for any suggestions.
jcansdale is offline Find More Posts by jcansdale
Old Feb 01, 2013, 11:16 AM
Slats! is offline
Find More Posts by Slats!
Joined Jan 2009
Go with the 100gram for sure. Mine still floats like heck with the 100.
If you like the Crack Pitts on 3S (I have it as well) you will want this thing to rip as well. The 70g may disappoint you.
Slats! is offline Find More Posts by Slats!
Old Feb 01, 2013, 11:22 AM
Mike Smart is offline
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
Yes I would try the 100gm, if you can run to it, an AXi 2814/16 really pulls it round the sky
Mike Smart is offline Find More Posts by Mike Smart
Old Feb 01, 2013, 04:04 PM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
Check out the new motors in the Crack Series... here is a link to the 100g motor that is part of the group...
http://www.twistedhobbys.com/Outrunn...eries-2814.htm
I have tested it on my 48" Sbach, and it really pulls this plane around... similar vertical performance as the little Crack Pitts on 3s..!!
You can certainly get a way with less motor, but this plane handles the big motors just fine.
cdee
cdee is offline Find More Posts by cdee
Old Feb 01, 2013, 04:15 PM
Slats! is offline
Joined Jan 2009
Wow that looks nice. How would you compare it to their other 100g?
cdee
Old Feb 01, 2013, 04:32 PM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
The 100g Suppo motor is still a good choice, it does run a little hotter than the 100g Crack Motor though. What is nice about the Crack motor is the option to bolt on the included prop shaft, and not have to use an adapter! The Crack Series motor are really nice. I have done lots of testing on all of them, every one has been flawless.
Also, the question was asked about motor mounts, they are all sized to fit the hole patterns on the Telink and RCF motor mounts as well as the alum upgrade motor mount for the Telink.
cdee
Old Feb 01, 2013, 05:46 PM
uptime4downtime is offline
Find More Posts by uptime4downtime
3d Kiwi
uptime4downtime's Avatar
New Zealand
Joined Dec 2007
Can you order replacement bolt on prop shafts for the new CS motors? They look nice
uptime4downtime is offline Find More Posts by uptime4downtime
Old Feb 01, 2013, 08:23 PM
jcansdale's Avatar
Joined Dec 2010
I'm having to watch my budget a bit so I've gone with the SunnySky X2814 1000KV. I believe this is the same as the Crack Series 2814 1000KV motor (100g).
The SunnySky motor was £25 compared to £65 for the AXi 2814/16. Are the AXi motors really that good to demand such a premium?
Old Feb 02, 2013, 05:29 AM
Mike Smart's Avatar
Joined Jan 2000
I think it depends how long you expect to use it for, the AXi motors are very good build quality and in my experience have had the edge in power over the cheaper motors. Certainly, my SBach is very well powered with this motor.
Old Feb 09, 2013, 09:33 PM
jcansdale's Avatar
Joined Dec 2010
Best way to make servo holes?
Good point. These planes do seem to last forever. It's Chinese New Year at the moment so I decided to splash out on an AXi. It will be interesting to compare it to the SunnySky when that eventually arrives.
I now have all the parts and have started my build. Does anyone have any tips when it comes to making holes for the servos? Digging a hole with an Xacto blade feels wrong.
Old Feb 10, 2013, 05:03 AM
Mike Smart's Avatar
Joined Jan 2000
Plus when you have eventually worn out the model, you can put the motor in the next one
I always mount my servos on their side to reduce the risk of cutting through the wing, plus the geometry of the linkage always seems better. If you mark around the servo with a pen, just cut vertically around the edges of the location with a fresh scalpel blade, then make a series of criss-cross cuts of the foam inside and you can pop the bits out with a round needle file. Then just clean up the bottom of the hole with some coarse sandpaper stuck to the end of a wooden stick.
Old Feb 19, 2013, 11:41 AM
jcansdale's Avatar
Joined Dec 2010
Safety distance!
This morning the conditions were perfect and I was practicing some low and slow harriers. I'm not sure what happened exactly, but next thing I knew the plane was coming right at me. I do know better and should have kept my safety distance!
I've had an x-ray and apparently the propeller nicked the bone at the end of my finger. They're calling it a compound fracture and I have a hospital appointment tomorrow to find out more.
This is embarrassing but I figured we can never have too many safety reminders. I imagine I'm not the only one to have grown a little complacent flying the 32" planes.
Be safe out there!
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 09:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 06:40 PM
Discussion NEW Twisted Hobbys/ParkAero RC Factory 31" Sbach 342 Greengiant 3D Foamies 130 Jan 24, 2013 02:49 PM
Discussion NEW RC Factory-Park Aero/Twisted Hobbys 31" Sbach 342 Greengiant 3D Flying 0 Nov 04, 2011 12:34 PM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 07:34 AM
