Old Dec 03, 2012, 02:42 PM
BrightCap232 is offline
Find More Posts by BrightCap232
I've got gas
BrightCap232's Avatar
United States, PA, Quakertown
Joined Aug 2011
Originally Posted by Mike Smart View Post
Here's mine
http://www.rcgroups.com/forums/showp...&postcount=368
I would Strap it on first and get teh C of G right before you cut. The C of G in the manual is conservative, mine is around 125mm now.
125mm measured from where?
BrightCap232 is offline Find More Posts by BrightCap232
Old Dec 03, 2012, 02:44 PM
Mike Smart is offline
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
Leading edge of the wing.
Mike Smart is offline Find More Posts by Mike Smart
Old Dec 03, 2012, 02:45 PM
Slats! is offline
Find More Posts by Slats!
Joined Jan 2009
I am forward like JC, even a little more forward but I have my RX and some of the light kit wired behind the CG so that would make sense.
So you guys are cutting holes in the top. Any difference in flight characteristics as opposed to the side?
Slats! is offline Find More Posts by Slats!
Old Dec 03, 2012, 03:04 PM
I've got gas
Joined Aug 2011
Supposedly it helps with lateral balance.
Old Dec 03, 2012, 03:07 PM
Slats! is offline
Joined Jan 2009
Interesting, makes sense. I would think the ESC on one side and batt on the other would kinda even each other out.
Its EPP MIGHT AS WELL CUT LOL. Freg the velcro did enough damage to the paint.
Old Dec 03, 2012, 03:11 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
Might be worth mentioning that I am running a 78g 1000kv A2810 motor with APC 12x6.
It flies very precise at the moment and I have been thinking about moving the CG rearward to see if I can make it a little more floaty and easier to hover.
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Dec 03, 2012, 03:58 PM
uptime4downtime is offline
Find More Posts by uptime4downtime
3d Kiwi
uptime4downtime's Avatar
New Zealand
Joined Dec 2007
Just came back from my second day of flying this machine after a break due to weather. I adjusted my ailerons to align with the carbon slats. I am very satisfied with this model. It is a locked in type flyer, with great confidence down low and slow. It excels in KE, snaps and inverted flight. I am most impressed!
uptime4downtime is offline Find More Posts by uptime4downtime
Old Dec 03, 2012, 09:26 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
Ok I probably don't have much off a chance to score an answer but here goes. I plan on cutting a slot for my 1800 mah zippy on the top off the fuse. Anyone using an 1800? If so can I get your measurement from the nose to where your cutout starts?
Here you go...
My cutout starts at 105mm from the nose.
My CG is at 110mm but as I stated previously, I am going to move it rearward.
It flies great precision currently.
What are the rest of you set at for pure 3D thrills?
JC
Old Dec 03, 2012, 09:47 PM
3d Kiwi
New Zealand
Joined Dec 2007
My 1600 is bang on centre between the landing gear mount (no hole cut at this stage)
Old Dec 04, 2012, 07:25 AM
Tom Eutsler is offline
Find More Posts by Tom Eutsler
Tom Eutsler's Avatar
Asheville,NC
Joined Jun 2002
ESC and Brake
I have my plane all togeather now , but can't figure out how to get dern 100 Gm motor and TH 45 amp esc OFF OF BRAKE ?
I printed out the sheet that TH has with the ESC but duh - no luck and it is on "soft" start as well
After binding , I went thru the normal set up of the motor and Tx routine
So, I ordered a Programming Card from TH
..te
Tom Eutsler is offline Find More Posts by Tom Eutsler
Old Dec 04, 2012, 07:36 AM
I've got gas
Joined Aug 2011
..te
Email Brad @ TH. he replies quickly
Old Dec 04, 2012, 09:45 AM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
Tom...
The programing card is certainly the easiest. If having to do via the transmitter, I believe that you can only set one item at a time, ie you will have to cycle through all the settings seperately for each item you want to change.
cdee
cdee is offline Find More Posts by cdee
Old Dec 04, 2012, 09:49 AM
I've got gas
Joined Aug 2011
What other props areas you guys running? I have 11x5.5's to start.
Old Dec 04, 2012, 09:54 AM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
With the 100g motor I like the APC style 12x3.8sf props. The electric props are nice too, they are a little more efficient, but I prefer the slower speeds and increased prop wash. I have tried lots of different props with the 100g motor, I will round up some of the info gathered and post something here tonight or tomorrow for those interested.
cdee
Old Dec 04, 2012, 09:56 AM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
Depends on what motor you are using.
I am running a Suppo 78g A2810 1000kv w/ 12x6 APC-E on 3S 1800 Nanotechs.
If you are running the Twisted 78g A2810 1100kv motor, you may not be able to go larger. An amp meter will tell the story.
JC
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 08:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion NEW Twisted Hobbys/ParkAero RC Factory 31" Sbach 342 Greengiant 3D Foamies 130 Jan 24, 2013 01:49 PM
Discussion NEW RC Factory-Park Aero/Twisted Hobbys 31" Sbach 342 Greengiant 3D Flying 0 Nov 04, 2011 11:34 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
