Old Nov 21, 2012, 12:59 PM
Mike Smart is offline
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
Originally Posted by Tom Eutsler View Post
Well, I got out the CG meter - as one of the guys told me who works for PA
much better than fingers.
with 100 Gm motor prop and collett on , ESC nestled up under front right side, MID wing so flipped plane upside down
I set the CG meter up at 110 mm from LE and only had to cut out small amt [1/2" ]
forward of my already cut out section on the top fuse and it balance right on the spot with a nano T 2200 battery
Front of battery is 5 3/4 " back from the very front of the foam
So think it is now close enuff and I can move on :-)
...te
I think you will find 110mm too far forward, but its a good starting point.
Mike Smart is offline Find More Posts by Mike Smart
Old Nov 21, 2012, 03:52 PM
Tom Eutsler is offline
Find More Posts by Tom Eutsler
Tom Eutsler's Avatar
Asheville,NC
Joined Jun 2002
Forward
ok Thankee I got room to move battery back in the slot :-)
I always like to get the COG right on what mfg suggests, then go from there
...te
Tom Eutsler is offline Find More Posts by Tom Eutsler
Old Nov 21, 2012, 05:12 PM
Gravitycheat is online now
Find More Posts by Gravitycheat
Don't give in to gravity
Gravitycheat's Avatar
USA, FL, Palm Harbor
Joined Dec 2009
Originally Posted by Slats! View Post
How are you guys storing this thing? Are you hanging it from the prop?? Thxs
I hang all of my foam. It does help to keep them staright and true and makes more room for more planes. I have found that more planes is a good thing
Description:
Gravitycheat is online now Find More Posts by Gravitycheat
Old Nov 21, 2012, 07:03 PM
toolman18 is offline
Find More Posts by toolman18
toolman18's Avatar
United States, TX, Portland
Joined Apr 2008
Attachment 5319471
Wow. Look at that fleet. Drooling
toolman18 is offline Find More Posts by toolman18
Old Nov 21, 2012, 07:12 PM
kenelder is offline
Find More Posts by kenelder
kenelder's Avatar
USA, FL, St Petersburg
Joined Dec 2003
Is that 2 of the SBach's I see in there?
Attachment 5319471
kenelder is offline Find More Posts by kenelder
Old Nov 21, 2012, 07:28 PM
Joined Dec 2009
Just one sbach but nearly every other TH model. guess I should not have post my hanger pic. Now everyone knows
How bad my addiction is.
Old Nov 21, 2012, 07:37 PM
uptime4downtime is offline
Find More Posts by uptime4downtime
3d Kiwi
uptime4downtime's Avatar
New Zealand
Joined Dec 2007
Installed my Turnigy D3536/8 1000KV - but on 11x7 I get at least 32A in a 25c battery, and obviously more on a 45c. That motor is rated for 30A max.
Thinking I might prop down to 11x5.5
Eventually, I'm going to swap it out for my Dualsky 3536 EA-7, 990KV, which has a 34A max amp rating. That motor I've tested on 12x6 and it got to 34A, so would be a better option, maybe running 12x3.8SF?
uptime4downtime is offline Find More Posts by uptime4downtime
Old Nov 21, 2012, 08:36 PM
3d Kiwi
New Zealand
Joined Dec 2007
Has anyone tried a 72g Omega on this? A 40A motor with plenty of power. Might be interesting (assuming CG is ok)
Old Nov 21, 2012, 11:53 PM
3d Kiwi
New Zealand
Joined Dec 2007
Well, not to be defeated, I bolted up my Omega 72g to this frame. I measured 421watts at 36 Amps using 45c 2200 Nanotech on APC 11x7 WOT on a fresh charge. I don't think that will let me down. That motor could go to a 12" I would expect and keep under 40A
I am thinking of standardising on Omegas on my Telinks and larger foamies. The 72, 105 and 130g is a nice range, and a fairly realistic price, with decent amp ratings per weight, and lots of watts. They look very well built also.
The only issue on this size frame is that this motor is 1100kv, rather than 890ish of the 130g Omega. Wonder if this will be an issue
Old Nov 22, 2012, 12:09 AM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
+1 Gravitycheat... hanging by the prop is the best way.
cdee
cdee is offline Find More Posts by cdee
Old Nov 22, 2012, 12:11 AM
Slats! is offline
Find More Posts by Slats!
Joined Jan 2009
Looks great. Thxs.....
Attachment 5319471
Slats! is offline Find More Posts by Slats!
Old Nov 22, 2012, 12:20 AM
3d Kiwi
New Zealand
Joined Dec 2007
I always wondered how you hung them. What do you use around the prop to hang them? That is a very neat system.
Old Nov 22, 2012, 12:22 AM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
There is some more info on my blog, and a link if interested.
cdee
Old Nov 22, 2012, 12:48 AM
3d Kiwi
New Zealand
Joined Dec 2007
Thanks and very nice indeed!
Old Nov 22, 2012, 11:18 AM
RC4x4 is offline
Find More Posts by RC4x4
Fly Low or you'll never know!
RC4x4's Avatar
Thornton, Colorado
Joined Jul 2002
Maybe I shud just put batt under neath on one side, strap it on and use some weight on opposite wing to balance
....te
Good idea. Mine works just fine, and I can adjust the cg if I want. I find nothing bad while flying with the pack on the side velcroed.
Cory
RC4x4 is offline Find More Posts by RC4x4
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 08:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion NEW Twisted Hobbys/ParkAero RC Factory 31" Sbach 342 Greengiant 3D Foamies 130 Jan 24, 2013 01:49 PM
Discussion NEW RC Factory-Park Aero/Twisted Hobbys 31" Sbach 342 Greengiant 3D Flying 0 Nov 04, 2011 11:34 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
