Old Nov 21, 2012, 01:39 AM
uptime4downtime is offline
Find More Posts by uptime4downtime
3d Kiwi
uptime4downtime's Avatar
New Zealand
Joined Dec 2007
Just the servos left to install. And the pull system (keeping it stock here!) - maybe a maiden tomorrow.
uptime4downtime is offline Find More Posts by uptime4downtime
Old Nov 21, 2012, 06:37 AM
Gravitycheat is offline
Find More Posts by Gravitycheat
Don't give in to gravity
Gravitycheat's Avatar
USA, FL, Palm Harbor
Joined Dec 2009
Good luck on the maiden! If you find this plane 1/2 as fun as i do, then you'll love it.
Gravitycheat is offline Find More Posts by Gravitycheat
Old Nov 21, 2012, 07:47 AM
kenelder is online now
Find More Posts by kenelder
kenelder's Avatar
USA, FL, St Petersburg
Joined Dec 2003
Especially when used to trim your trees
kenelder is online now Find More Posts by kenelder
Old Nov 21, 2012, 08:30 AM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
The Stock Pull-Pull works very well. Lots of flights on mine, had to tighten it up once after about 5 or so flights, and has been holding ever since, probably 200ish flights on it now.
cdee
cdee is offline Find More Posts by cdee
Old Nov 21, 2012, 09:42 AM
toolman18 is offline
Find More Posts by toolman18
toolman18's Avatar
United States, TX, Portland
Joined Apr 2008
Ha. Wish we had gotten that on film. Classic.
toolman18 is offline Find More Posts by toolman18
Old Nov 21, 2012, 11:21 AM
Slats! is offline
Find More Posts by Slats!
Joined Jan 2009
How are you guys storing this thing? Are you hanging it from the prop?? Thxs
Slats! is offline Find More Posts by Slats!
Old Nov 21, 2012, 11:58 AM
Tom Eutsler is offline
Find More Posts by Tom Eutsler
Tom Eutsler's Avatar
Asheville,NC
Joined Jun 2002
Cg
Originally Posted by Mike Smart View Post
This is where I have my lipo.
I cut out top of Fuse such as yurs before I glued it down whewwww
with a nano tech 2200 battery WAY tail heavy . I would like to put batt in center of Fuse for lateral balance but now I have to rethink where I am going to put it
good thing I saved the cut out piece . I thought about leaving top fuse off and moving batt back and forth to get an Idea where it might go , but on the other hand I would not have had the Rudder etc attached
Maybe I shud just put batt under neath on one side, strap it on and use some weight on opposite wing to balance
....te
Tom Eutsler is offline Find More Posts by Tom Eutsler
Old Nov 21, 2012, 12:01 PM
Asheville,NC
Joined Jun 2002
Hang
That is what I will have to do when it is done, got tooo many other planes taking up room
............te
Old Nov 21, 2012, 12:06 PM
Slats! is offline
Joined Jan 2009
I am running the 100g motor with 1750 Rhinos (waiting for my Hyp 2100's). All I will say is I am shocked how tail heavy I am. I tried my buddies 2100s and still way tail heavy.
45 deg upline test and I am outside looping. I had my packs on and a little behind the spar, moved them up a little and no change. I am thinking I am going to have to be as far forward as possible.
All I will say is try it before you go cutting.
This is one awesome plane I think I will always own a TH 48" Epp.
Old Nov 21, 2012, 12:16 PM
Mike Smart is online now
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
Where do you two have the C of G? Mine is close to 120mm from the LE and I am using a 1800 NanoTech.
Mike Smart is online now Find More Posts by Mike Smart
Old Nov 21, 2012, 12:20 PM
Asheville,NC
Joined Jun 2002
Cg
I am going to get my CG stand out now and find out where it balances - with batt in cut out similar to yurs - will get back on where it ends up
..te
Old Nov 21, 2012, 01:20 PM
3d Kiwi
New Zealand
Joined Dec 2007
I'm going to Velcro 1600 then try 2200
Old Nov 21, 2012, 01:22 PM
3d Kiwi
New Zealand
Joined Dec 2007
Mike. Did u cut a hole, or strap? I'm thinking I might get away with strapping n an 1800. Do you think 1600 would be ok run time wise? Thanks
Ignore: I looked back and saw your cutout.
The 12x3.8sf seems to be a good prop for this
Old Nov 21, 2012, 01:38 PM
Asheville,NC
Joined Jun 2002
CG meter
Well, I got out the CG meter - as one of the guys told me who works for PA
much better than fingers.
with 100 Gm motor prop and collett on , ESC nestled up under front right side, MID wing so flipped plane upside down
I set the CG meter up at 110 mm from LE and only had to cut out small amt [1/2" ]
forward of my already cut out section on the top fuse and it balance right on the spot with a nano T 2200 battery
Front of battery is 5 3/4 " back from the very front of the foam
So think it is now close enuff and I can move on :-)
...te
Old Nov 21, 2012, 01:58 PM
Mike Smart's Avatar
Joined Jan 2000
I originally had the 1800 lipo strapped on the lower side of the fuselage, but due to handling issues that I reported here, I moved it to a cut-out in the upper fuselage. Much to my surprise, this made a massive difference to the handling. So far the slot is tight enough not to use a strap.
If you are running the 100gm motor, I think you will find a 1600 too short on run time. I am using 1800 and wish I had cut the slot to suit a 2200 to be honest.
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 09:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 06:40 PM
Discussion NEW Twisted Hobbys/ParkAero RC Factory 31" Sbach 342 Greengiant 3D Foamies 130 Jan 24, 2013 02:49 PM
Discussion NEW RC Factory-Park Aero/Twisted Hobbys 31" Sbach 342 Greengiant 3D Flying 0 Nov 04, 2011 12:34 PM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 07:34 AM
