Old Aug 05, 2012, 09:51 PM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Originally Posted by cdee View Post
New Favorite!!!.
Finally.... I got this new plane in the air... reading all the posts and watching the videos of those that are already done was making me crazy. I have decided that this plane is not an Sbach, it's Sbertha, IT'S HUGE! My AUW was exactly 24oz with 3s 1600 batteries (given it size... I expected more), and of couse no Landing Gear, as many of you know, it just gets in the way when I am flying low... lol... no but seriously, flying off of grassy Parks is not Landing Gear friendly... I did however install all the plates and brackets for the LG so I can easily attach it at a later date if needed
The build was pretty straight forward, I took a little different approach to this one... with the exception of the aileron servo arm extensions, I only used stuff that came in the box!! Although this is a very big plane, it is still a foamie, and I wanted to give the RC Factory methods a whirl.... Not bad, sure there are lots of things that people will want to do different, like the rudder hinge system and the pull-pull cables also on the rudder (and I might have been one of those), but honestly their methods were well thought out and worked great. I will report back here as time goes on about how securing the pull-pull thread on the servo side under the head of a screw works, but see no reason why it won't weather my abuse just fine.
I used the familair Welder construction methods (foam to foam joints), and where ever possible did the tack to dry and press together techinique. I did use a little more CA on this build than normally.... all the carbon spars and stiffners got CA'd... I will continue this on future builds... it worked great.
With the excpetion of the servos... I used everything from the power set that is sold on the Twisted Hobbys Website. I did use servos from Twisted Hobbys, but they were the next ones up MG16Rs. The ones in the power set are actually a better fit for the plane, they just were not in stock when I ordered.
FLYING!!.... OMG!!
It was pretty gusty out this afternoon when I went out to the park for Sbertha's Maiden flight, but did not hesitate to through it up. My initial control surface setting were very close, ended up moving the battery towards the tail for good upright and inverted neutrality, but will wait to report on the exact COG location until I have a chance to fly in calmer conditions. I did add a washer under the two left tabs of the motor mount, and before I go out again will also add a washer of down thrust. Power off dives from altitude were straight as an arrow, so CG is probably pretty close. I was immediately comfortable flying this plane and was literally throwing it around right in front of me as if it were Crack Yak or something, which, I must say surprised me a little. You certainly have to allow for the extra mass, but with the power set motor, there was an abundance of punch out power and smooth transitions from low to high rpm.
Roll Rate... with the throws as shown in the pictures was super.. not sure exactly how fast, but probably somewhere in the 1 to 2 rolls per second range.
Elevator and Rudder Authority... both very strong, easy to set up control surfaces to +/- 45 degrees... and even in slow flight there was good control.
The Verdict...
If you are hesitant, afraid or just sitting on the fence about getting a bigger plane, you should consider this one.... you can throw it around much like the smaller planes but handles the wind and gusts much better. When I go out to fly, I usually take anywhere from 20 to 50 various sized charged packs and airplanes to fit them, and fly them all... with this plane in my hanger I will bulk up my supply of 1600-1800 3s lipos and very likely only take it when I head out. It has a great paint scheme, it's big in the air, a pleasure to fly, and best of all..... made from EPP, so fly low, fly hard and have fun!!
cdee
Impressive. Thanks for the write up. You should add these kind of write ups on airframes to your blog. That way people can look at what you had to say about all the different planes you've flown. I really enjoy how in depth you get with it. All it takes is a copy and paste
hone1er is offline Find More Posts by hone1er
Old Aug 05, 2012, 10:20 PM
cdee is offline
Find More Posts by cdee
Team Twisted!
cdee's Avatar
United States, CO, Denver
Joined Jun 2011
Thank you for the words of encouragement... I was acutally thinking about doing that, not only with this one but of all the other planes I currently have or had over the last 12 months... it would be interesting.
cdee
cdee is offline Find More Posts by cdee
Old Aug 05, 2012, 10:27 PM
hone1er is offline
Team Twisted!
hone1er's Avatar
Joined Dec 2011
cdee
Definitely. You'd be surprised how often people end up in the same spot as you were last year looking at the same planes. A blog with a review of each one would give folks something to read up on when looking into a new airframe and could help people make up their minds
P.S. I like the build log on the buster too. Makes me want to get one
Old Aug 05, 2012, 11:35 PM
DaxFX is offline
Find More Posts by DaxFX
AIMDROIX
DaxFX's Avatar
Puerto Rico, San Juan
Joined May 2008
Hi guys.
I have a power 10 looking for a fuselage. I saw this sbach and looks awesome. Im in between the 1200 sback from twsted hobbys or the hacker sc extra 1200 from rc baron.
What you think guys. Will be good the P10, and between sback and sc extra hacker. Wich one will be better. Im not a 3d pro just a casual 3d flyer im looking for a floaty easy 3d one like my techone pulama or angel.
Any suggestion. Like all of us into the adiction always looking for a new toy
DaxFX is offline Find More Posts by DaxFX
Latest blog entry: Puerto Rico Drone Prix 2016
Old Aug 06, 2012, 05:48 AM
Gravitycheat is offline
Find More Posts by Gravitycheat
Don't give in to gravity
Gravitycheat's Avatar
USA, FL, Palm Harbor
Joined Dec 2009
Nice job Cdee. I like your aileron set up. Like your amount of alireon throw even better NOw that i have some time on mine with the "standard" Set-up, I look forward to doing some "tweeking" as well.
Any vid showing that new and improved roll rate
Gravitycheat is offline Find More Posts by Gravitycheat
Old Aug 06, 2012, 06:43 AM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
I took some video yesterday, not the best of conditions, will try and get something better today or tomorrow and post it up
cdee
Old Aug 06, 2012, 07:02 AM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
Originally Posted by DaxFX View Post
Hi guys.
Airframe will probably take the motor just fine, but bigger than needed, something in the 70 to 100 gram range / 350W-35A. The motor in the power set with an 11x5.5 thin electric prop works very nice with this plane. Got my first flight in on this airframe yesterday... pretty sure it is going to be my new favorite for a while. There are some comments a couple posts up from my build and first flight impressions.
cdee
Old Aug 06, 2012, 05:51 PM
JC Spohr is offline
Find More Posts by JC Spohr
3D Hack
JC Spohr's Avatar
United States, IL, Glen Carbon
Joined Jul 2010
Hey Cdee,
I noticed the angle (toward the back TE) on the extended aileron arms and was wondering - why?
Seems like that would induce about 15% differential which I would not think of as desirable for a mid wing aircraft.
For those flying with 3S 1800's - what flight times are you getting?
JC
JC Spohr is offline Find More Posts by JC Spohr
Old Aug 06, 2012, 06:03 PM
Parksinatree is offline
Find More Posts by Parksinatree
Limb stalker
Parksinatree's Avatar
United States, TN, Taft
Joined Aug 2010
JC
I set my timer at 7 min. Using Spyder 1800's and putting 900-1000 back in them, even when I run over.
Parksinatree is offline Find More Posts by Parksinatree
Old Aug 06, 2012, 07:11 PM
JC Spohr is offline
3D Hack
JC Spohr's Avatar
Joined Jul 2010
Awesome - thank you!
I have three 2100 packs and thinking about going to the 1800's for weight savings.
Still on the fence since I would have to order up some 1800's.
JC
Old Aug 06, 2012, 10:20 PM
Sixinarow is offline
Find More Posts by Sixinarow
Addicted
United States, CO, Parker
Joined Dec 2011
Cdee, when can I come over and drool over your RC workshop? Awesome room and collection. Congrats on the SBach!
Sixinarow is offline Find More Posts by Sixinarow
Old Aug 07, 2012, 09:00 AM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
Hey Cdee,
JC
I start with the link and the horn making a 90 degree angle so that there is an equal amount of up and down aileron, ie no differential, and then dial in the differential I want on the transmitter side. This does assume that the hole in the control surface horn is right over the hinge line.
cdee
Old Aug 07, 2012, 09:04 AM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
Yea, we should totally hook up sometime.
cdee
Old Aug 07, 2012, 09:13 AM
cdee is offline
Team Twisted!
cdee's Avatar
Joined Jun 2011
1.2m Sbach Thrust Line....
First time out I had one washer each under the left side (top and bottom) of the motor mount, giving a little right thrust... I did notice that after trimming and CG adjustments that the plane still needed a fair amount of down elevator while inverted, so I thought some down thrust would help that. And it did. If sitting in the cockpit, I now have two washers under the upper left, one under the upper right, one under the lower left and no washer behind the lower right, for an end result of down and right thrust. Inverted now just need a touch of down and the hovers are rock solid. I may fiddle with it some more at some point, but feel that it is good for now.
Flying last night was great, wind settled down a little had was able to get about 10 more packs thru, lots of hand snags from hover and KE flying.
cdee
Old Aug 10, 2012, 06:28 PM
Joined Dec 2009
Sbach Flight Report
Hey Guys.
I added a “Flight Report” to the first post of this thread. Here is a link to it.http://www.rcgroups.com/forums/showt...5#post22412889
I wanted to give my impressions, and some insight into the flying characteristic of the 48” Sbach 342. I hope this will help those trying to decide on whether, or not, this plane is right for you.
I am having a great time flying mine!
Shawn
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 08:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion NEW Twisted Hobbys/ParkAero RC Factory 31" Sbach 342 Greengiant 3D Foamies 130 Jan 24, 2013 01:49 PM
Discussion NEW RC Factory-Park Aero/Twisted Hobbys 31" Sbach 342 Greengiant 3D Flying 0 Nov 04, 2011 11:34 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
