Old Nov 15, 2003, 09:37 PM
Husband, Dad, Skydiver, RC'r
Bill K.'s Avatar
USA, GA, Loganville
Joined May 2002
What is the difference between these?
What is the difference between these two packs, say that I have 8 loose Kan 1050 cells. (which I do) What do I gain by building the pack like so
or what do I gain by building it like so
Both seem to work, one is slightly shorter and comes out lighter than the other, however am I loosing anything by using one method over the other? I like the second method because it's allowing me to move the battery back and forth more for CG, however I'm not sure if it's because the cells are brand new or what, but my run times on the first and second charge were pretty darn short. However another pack built side by side ran about double, but it was also on charge 10 or more.
Thanks in advance, now it seems like Lipolys are simple to me... I hardly ever mess with cells anymore...
BK
Bill K. is offline Find More Posts by Bill K.
Old Nov 15, 2003, 10:29 PM
thazy2's Avatar
Pueblo Colorado
Joined Mar 2002
I dont think it should matter when it comes run time. I like the first one. It easier to put together and remove. Plus if your using matched cells, the pack can equalize on a tray or cycle one cell at a time to show capacity. The only difference that I can see is size limitation of your application. Both method can be adjusted for CG, if im understanding your ? right.
..............Jason
thazy2 is offline Find More Posts by thazy2
Old Nov 15, 2003, 10:55 PM
Bill K.'s Avatar
USA, GA, Loganville
Joined May 2002
Thanks Jason,
Kind of what I figured. The plane that I'm flying them on, one gives me 1/4" aprox more to play with in moving my CG aft. That just makes the plane a little less stable, which is a good thing for the way that I'm trying to fly it. Most of my packs are built like method one, however I've got some loose cells and figured that I would build some the other way too. I think that my run times are just the packs being new and once they get a few runs under their belts they will be fine.
Bill
Discussion what is the difference between these 2 frames? DsWright Mini Helis 7 Mar 23, 2007 02:35 PM
Question What is the difference between these tail gears?? Crash549 Mini Helis 11 Apr 08, 2006 01:02 AM
What is the difference between these motors? louisd Power Systems 1 Sep 27, 2005 02:24 PM
What is the difference between these two GWS receivers ? robert harik GWS (Grand Wing Servo) 2 Mar 30, 2004 02:55 AM
what is the difference between these two GWS receivers? robert harik Radios 0 Mar 30, 2004 12:31 AM
