Old Jul 17, 2012, 11:27 PM
chaleau is offline
Find More Posts by chaleau
Joined Sep 2011
Duraplane-ish spad plans
Any body got plans for a duraplane trainer type spad?
chaleau is offline Find More Posts by chaleau
Old Jul 18, 2012, 08:50 AM
TheRealFrosty is offline
Find More Posts by TheRealFrosty
Call me Frosty
TheRealFrosty's Avatar
Lawton, Oklahoma - USA
Joined Sep 2004
I would go straight for the Debonair at http://www.spadtothebone.net/SPAD/. You could chop the fuse off at the back and use aluminum channel for the back, but why bother? The Debonair makes a good trainer as is in the plans. It's even better if you build the RNAF style wing with a 4 mil bottom and 2 mil top (see http://www.spadtothebone.net/SPAD/Sp...21/page21.html for technique, but use Debonair wing dimensions.
TheRealFrosty is offline Find More Posts by TheRealFrosty
Old Jul 18, 2012, 09:06 PM
chaleau is offline
Joined Sep 2011
That's kinda the direction I was leaning but I like the aluminum tail boom look so I'm thinking that I'm gonna modify my Deb like you suggested. Thanks.
Old Jul 20, 2012, 12:08 AM
JohnsPop is offline
Find More Posts by JohnsPop
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
The only problem I have with the aluminum boom..... I really like the BUHOR 25 and it has the aluminum channel, but it is only for low or no wind. The aluminum channel allows a lot of twist in the tail if you're flying in windy conditions and it can be disastrous.
JohnsPop is offline Find More Posts by JohnsPop
Old Jul 20, 2012, 10:33 AM
Call me Frosty
Joined Sep 2004
That's true. I have seen a duraplane in person and the tail was a little more twisty than my debonair tail.
Old Jul 26, 2012, 05:00 AM
kenbad is offline
Find More Posts by kenbad
kenbad's Avatar
Joined Dec 2011
I have a brand new durabat, wonder if I should sell it......been in the attick for years
kenbad is offline Find More Posts by kenbad
Old Jul 27, 2012, 01:43 PM
JohnsPop is offline
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
Unless you just really like it, I'd sell it and use the proceeds to buy coro or something else you'd prefer.
Old Jul 28, 2012, 09:44 PM
Oldgzr is offline
Find More Posts by Oldgzr
Oldgzr's Avatar
Finger Lakes Region, NY
Joined May 2008
Kenbad, Is your Durabat the older style one with the urethane coating on the wing or the later type with the plain foam wing that you had to cover?
Oldgzr is offline Find More Posts by Oldgzr
Old Jul 29, 2012, 04:34 AM
hiko is offline
Find More Posts by hiko
New Zealand
Joined Apr 2012
I have just done an electric Debonair with a 3mm Buhor wing and built as a taildragger
a 3s 4000 mah lipo 60amp plush ESC and 35-48 900kv NTN propdrive outrunner
13x6.5 prop The Debonair weighs 2.5KG and this setup pulls 440 watts
It flies great and makes a great trainer
hiko is offline Find More Posts by hiko
Old Jul 30, 2012, 08:04 AM
kenbad is offline
kenbad's Avatar
Joined Dec 2011
Plain foam wing
Wanted Duracraft Duraplane wanted !! FlyingKiwi22 Aircraft - Fuel - Airplanes (FS/W) 4 Aug 10, 2012 12:42 PM
Found In need of a new/or ish HS81 servo please. jjohns51 Aircraft - General - Radio Equipment (FS/W) 5 Jun 18, 2012 01:42 PM
Wanted Duraplane Kit FlyingKiwi22 Aircraft - Electric - Airplanes (FS/W) 2 Mar 09, 2012 08:14 PM
Question Avistar to Duraplane to SPAD RussMax SPAD - Simple Plastic Airplane Designs 4 Jan 12, 2007 11:40 AM
Duraplane 40 wing on a Duraplane 20 Model? kctrading SPAD - Simple Plastic Airplane Designs 0 Mar 28, 2005 09:03 PM
