Old Jul 17, 2012, 09:59 PM
jrudy75 is offline
Find More Posts by jrudy75
Joined Oct 2007
Help!
Help with motor and esc match
Thanks for the help in advanced with this, I looking for someone to try and explain to me how to match the right size esc and battery for the specific motor, I'm not so new at RC but am new on building and setting up my own models so to speak.
The first project is a sailplane with 2 brushed speed 400 motors, would I need 1 or 2 esc's and which size along with recommended battery.
The 2nd project is an A-10 with using 2 of the following
http://www.hobbypartz.com/88e-adf50-300l-5800kv.html
what esc do you suggest and is it better to use 1 or 2 of them, and what battery also would you suggest (preferably Li-Po)
jrudy75 is offline Find More Posts by jrudy75
Old Jul 18, 2012, 12:47 AM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
Rudy
First project: each motor should get it's own brushed ESC, even though one ESC could serve two motors.
ESC size depends on how many amps each motor and it's prop draw.
Amps x 125% = ESC size in amps or greater (see 2nd project for example)
http://www.bphobbies.com/view.asp?id=V573706
http://www.hobbyking.com/hobbyking/s...USHED_ESC.html
The motors were made to operate within a voltage envelope. I would choose based on the
upper end of that envelope.
Battery size depends on how much weight the airframe can support and still fly.
Second project: The EDF specs are 12.6 volts at 28 amps max.
Size the ESC by multiplying by 125% 28 amps x1.25=35 amps
Get an ESC for each EDF. As HobbyPartz doesn't have 35 amp Air ESCs, choose a 40 amp that supports the battery of your choice (3s, 4s)
http://www.hobbypartz.com/07e-skywalker-40a.html
http://www.hobbypartz.com/07e05-proton-40a.html
http://www.hobbypartz.com/60p-dye-40a-x-2-esc.html
rick.benjamin is offline Find More Posts by rick.benjamin
Old Jul 18, 2012, 03:03 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
With brushed motors you can use one ESC for the pair and that's what I've always done. A 30A ESC will be plenty for 2 x S400s because you shouldn't run them much over 10-12A each. What battery will depend on exactly which S400s you have. There are loads of different ones with very different specifications. A 2S Lipo is a fairly safe option if you want to use a lipo.
Brushless motors must have an ESC each. You'll have to decide for yourself what size battery you want to use, 3S or 4S and if you want to use a single battery it will need to be a biggish one as you'll be asking for around 60+A out of it.
Steve
slipstick is offline Find More Posts by slipstick
Old Jul 18, 2012, 10:25 AM
jrudy75 is offline
Joined Oct 2007
Thanks a lot! thats the answer i needed
Old Jul 18, 2012, 12:53 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
One slight alternative to a 2s Lipo and motors in parallel off one ESC, is the motors in series with one ESC and a 3s Lipo. Though you should check the props and amps draw are still suitable.
I have a GWS C-47 (brushed motors), that flew on 2s with the stock motors and props, having destroyed both props and having plenty of the small Gunter props, I switched the motors to series connection fitted the Gunter props and found that I could run it on 3s, (I also had plenty of 3s packs). Flies great.
Although the volts went up, the series connection meant the motors were still well within spec and actually drew less amps.
Sorry if I have complicated or confused things.
eflightray is offline Find More Posts by eflightray
Sold Pair of balanced Wicked 4800 motor and matching ESC for twin EDF setup The Don Aircraft - Electric - Jets (FS/W) 4 Jun 25, 2012 07:34 PM
Question Matching a esc to a motor? clonedkorl Power Systems 1 Apr 12, 2012 03:33 PM
Discussion Help with buying a good motor to perform with my esc leo.geo Electric Plane Talk 5 Mar 15, 2012 06:10 AM
Discussion Help match warbird to motor/esc jet_jer Electric Warbirds 2 Apr 26, 2006 08:26 AM
HELP HELP HELP, motor/esc/battery matching? L0keman Electric Plane Talk 6 Dec 21, 2005 07:59 AM
