Old Aug 27, 2012, 12:11 PM
Vince_TT is offline
Find More Posts by Vince_TT
United States, PA, Philadelphia
Joined Dec 2011
Originally Posted by nickelbn1 View Post
sitting on the ground, I do not notice any binding or issues. I dont know if the servo is locking up or not. I am only having an issue while its flying. I have pretty much got it all fixed now. I bought some balsa and a small thin sheet of plywood from hobbylobby to use to do some reinforcements like some of you have done. I am putting extra welders glue around the edges and seams of places to also give more reinforcement.
Had a terrible weekend as my SUV broke down in the mountain with whole family and full load of luggage on Saturday night, after four hours of shopping. Waited for 2 hours and none of the tow companies want to help us. So no flying and internet stuff for the whole weekend.
If you rule out the linkage and flexing problem on your ailerons, the next thing I would try is to replace both aileron servos, get a SBEC and a new RX. Two of my planes had similar problem before, One turned out to be a bent RX antenna that caused signal loss at high G moves, the other one is a loosen weld on T-plug at the ESC/SBEC, I would lose all control at certain angle, and regain control a second later but no throttle until I shut down the throttle completely.
Vince_TT is offline Find More Posts by Vince_TT
Old Aug 27, 2012, 12:26 PM
nickelbn1 is offline
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
I was planning on waiting to get some of the new power servos that are higher in torque. Will also get my linkage better where my pushrod is more level. If that does not work i guess a new esc or sbec might be in order. I am using a cc Thunderbird 54. Their website does not state how many servos it can handle so i just emailed them.
The more i am reading about the cc Thunderbird esc's the more i am thinking that may be my issue. The have a linear 3a bec and are made for light parkflyer foamies at 2-3 cells max. In one forum a cc rep wrote that they dont recommend using the bec over 2 cells. I will see what they reply over email.
nickelbn1 is offline Find More Posts by nickelbn1
Old Aug 27, 2012, 01:42 PM
chopper62 is offline
Find More Posts by chopper62
Joined Apr 2008
I'm using the same CC Thunderbird 54A esc so you can probably rule out esc problem. Sent you a PM.
chopper62 is offline Find More Posts by chopper62
Old Aug 27, 2012, 02:03 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
I experienced a similar issue to yours. I took off at full throttle and at one point before I dropped my throttle the ailerons (pretty sure both) were unresponsive. I quickly dropped the throttle and tried the ailerons again and they were fine so not sure what fixed it as it all happened so fast. This is with Hitec HS-5065MGs and a Castle ICE50 Lite. I should really try and reproduce it and see if the castle log shows anything. I'm seriously considering switching to ball links because I worry that the 3DHS ez-connectors are too tight with the way they screw on the servo horn.
Pretty sure they don't recommend using the BEC on 3S because I don't think you get 3A due to efficiency loss with the increased voltage drop required.
grimbeaver is offline Find More Posts by grimbeaver
Old Aug 27, 2012, 02:11 PM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
Hmm you just mentioned something thst may be my issue. I have tightened all my ez-connectors as tight as i could and then put ca on the tip. But now that you said that, could that be causing binding problems because their too tight and not rotating freely? Should they be a little loose?
Old Aug 27, 2012, 02:14 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
My plane would sort of do this. I think with the right roll the first time you give it left aileron it seems unresponsive. Then you give it left again and it works.
zmonster97 is offline Find More Posts by zmonster97
zmonster97's Avatar
Joined May 2011
Double post.
Old Aug 27, 2012, 02:19 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
yes they should rotate 360 easily
3drcparts is offline Find More Posts by 3drcparts
Old Aug 27, 2012, 02:21 PM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
But mine is doing this after its trimmed out and been flying fine for 2 minutes or so already.
Old Aug 27, 2012, 02:22 PM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
Hmmm. But if this is my issue i wonder why its only sparaticly happening. I bet i do need to loosen them though. I tightened them tight.
Old Aug 27, 2012, 02:25 PM
zmonster97's Avatar
Joined May 2011
Yeah, mine did that too. I was flying at about 3/4 to full throttle straight and level and I would give it full left aileron and nothing would happen. So I give it left aileron again and then it worked. Weird. I think I could see the left aileron flexing.
Old Aug 27, 2012, 02:38 PM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
Hmmm. Interesting. Never figured it out though huh??
Old Aug 27, 2012, 02:42 PM
zmonster97's Avatar
Joined May 2011
Nope. I sold it to a guy who isn't going to fly it as hard right now. He loved how it flew yesterday.
Old Aug 27, 2012, 02:46 PM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
I am so mad at this plane right now after the wing issue (which still isnt fully corrected) and now this. I just want to stomp on this plane. And 3dhs not doing anything about this wing issue and ignoring my last email is not making me want to buy another plane from them. I didnt rant or rave or anything.
Old Aug 27, 2012, 02:49 PM
zmonster97's Avatar
Joined May 2011
I think the aileron issue is related to the wing issue. Not sure though.
Sold ... hosam Aircraft - Electric - Airplanes (FS/W) 1 Jul 17, 2012 09:23 PM
Sold 47" 3D Hobby Shop Edge 540.. LPU SteveT. Aircraft - Electric - Airplanes (FS/W) 1 Mar 11, 2012 06:58 PM
