Old Aug 16, 2012, 10:14 AM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
Originally Posted by chopper62 View Post
Instead of CA, use blue loctite on the ez connectors.
I did measured the cut out for the wing to the back of the tail, with the epp peeled back for a truer measurment, and they both are the same distance.
Refer to page 19. CA locks them on(no movement) there but can be cracked off it needed. They used the washers which is probably a better idea to spin more freely. Just a habit with me cause I usually drop them and lose them.
http://www.3dhobbyshop.com/assets/im...DGE-Manual.pdf
robj is offline Find More Posts by robj
Old Aug 16, 2012, 10:16 AM
robj is offline
robj's Avatar
Joined Nov 2008
Originally Posted by SD One. View Post
I bought 10 bags of easy connects a few years ago after building a 42" Slick that included them. I've used them on just about every plane I've built since. Love them!
As for the rest.. I'm here, I'm watching and I'm reading. If something really stands out like it could be the cause, I'll check mine or test it and let you know what happens.
Me to. Much better than the ones with the plastic hold on do-dad.
Old Aug 16, 2012, 10:22 AM
chopper62 is offline
Find More Posts by chopper62
Joined Apr 2008
Am from the old school and metal to metal I always used loctite.
chopper62 is offline Find More Posts by chopper62
Old Aug 16, 2012, 10:36 AM
robj is offline
robj's Avatar
Joined Nov 2008
You still running on 72? hehe, just kidding.
Old Aug 16, 2012, 11:07 AM
nickelbn1 is offline
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
Some more testing with mine this morning. I haven't really noticed the right roll under power because I do more slow stuff or only WOT verticals.
Put on a 12x6 this morning, liked the way it flew, no heavy TR issues, plenty of power, actually hovered nicely. Then did the straight and level WOT. Woaa!! plenty of hard right roll. Yikes!
Put on a 10x5 and tried. Useless, no power, not even to sport fly it.
Went back to the 11x5.5 and tried the WOT straight and level. No roll in mine, I did it twice. Plenty of power.
What has been bugging me is if I'm coasting along and bring it up into a quick hover, it would want to dive left. I do have about 50* elevator travel, but it;s not flexing. I did several only using half elevator, same thing. Landed, took off the SFG's, no more diving to the left.
Only other thing I noticed in the few flights I have on it is when going from pre stall to post stall in harrier form, it gets real rocky right at that moment. But once post stall, rock solid harrier, upright and inverted.
I think I just have to get use to that short tail moment. But I'm seeing good things.
Some pics of my trims..
So you see how scary it is to fly this thing with that hard right roll.....it is a yikes moment. I really dont like not being able to go above 50% throttle or i get a unstable plane. Interesting your roll was solved with a prop change. But others using the same prop roll still.
nickelbn1 is offline Find More Posts by nickelbn1
Old Aug 16, 2012, 11:54 AM
Jboy90277 is offline
Find More Posts by Jboy90277
United States, CA, Palos Verdes Peninsula
Joined Dec 2011
OK, so this is interesting. Here's a theory to test:
The roll tendency is not from the motor's torque (that would want to roll the plane left-opposite direction of the prop), but from the prop wash. If you've ever looked at the prop wash coming from a boat, you'll see it's a vortex that rolls in the same direction as the prop rotation. Same principle with the plane - the prop wash coming from a counter clockwise rotating prop will create a counter clockwise rotating prop wash, which will want to roll the plane right as it hits the surfaces of the plane. I don't think RobJ or Chopper see the roll tendency with the 11x5.5 because they don't have as big a flat surface for the prop wash to push against as folks with wheel pants do. I think RobJ experienced his problem with the 12x6 because he's got a larger column of prop wash that's hitting more of the wheels, wing, and tail. So, to fix it, you would either need to reduce the surfaces getting hit by the prop wash (like the wheel pants) or reduce the size of your prop so the wash isn't as large.
My guess at the solution if anyone with the problem cares to test it.
Jboy90277 is offline Find More Posts by Jboy90277
Old Aug 16, 2012, 12:26 PM
Joined Apr 2008
you still running on 72? Hehe, just kidding.
27!
Old Aug 16, 2012, 12:29 PM
Joined Apr 2008
I'll install a 12x6 and WOT (for a few seconds on the 72g) to test your theory. Thereafter, I'll run both props (11x.5.5 and 16x6) with the wheel pants and skirts.
Old Aug 16, 2012, 12:34 PM
Joined Dec 2011
Good on ya to do this for the group. Most folks wouldn't want to mess with a plane that's flying right. You might want to use a a 12x6 instead of a 16x6.
Old Aug 16, 2012, 12:46 PM
Joined Apr 2008
Go big or go home
Old Aug 16, 2012, 12:48 PM
UDO999 is offline
Find More Posts by UDO999
UDO999's Avatar
United States, MN, Cottage Grove
Joined Jul 2010
I have wheel pants and skirts, no roll with a 12x6 or 11x5.5. Too bad you guys are having so much trouble. I notice in nickelbn1's photos his ailerons are right up against the SFG's. If you haven't already I would put a spacer in there so they don't bind.
UDO999 is offline Find More Posts by UDO999
Old Aug 16, 2012, 12:53 PM
Joined Dec 2011
Hmmm...what size motor are you running?
Old Aug 16, 2012, 12:54 PM
UDO999 is offline
UDO999's Avatar
Joined Jul 2010
Motrolfly 2810-1000.
Old Aug 16, 2012, 01:04 PM
SD One. is offline
Find More Posts by SD One.
My hovercraft is full of eels.
USA, TN, Gallatin
Joined Aug 2009
For folks with no right roll problems, did you need any aileron trim at all? 1 click? 2 clicks?
SD One. is offline Find More Posts by SD One.
Old Aug 16, 2012, 01:09 PM
Joined Dec 2011
That's a strong motor. I assume you did WOT runs and didn't see any problems?
Sold ... hosam Aircraft - Electric - Airplanes (FS/W) 1 Jul 17, 2012 09:23 PM
Sold 47" 3D Hobby Shop Edge 540.. LPU SteveT. Aircraft - Electric - Airplanes (FS/W) 1 Mar 11, 2012 06:58 PM
