had a bit of time so I started the build, having the 48" extra I knew the landing gear and motor mounts were weak points, I made a few improvement, I also added some carbon stringers from the landing gear back to the wood in the middle of the fuse
Latest blog entry: Zach & Dan 3DHS 71" Slicks Duo...
Joined Feb 2011
Checked the raw wing and it's pretty well balanced with nothing on it. Didn't make as much progress tonight as I wanted due to my lack of a 1/2" drill bit to enlarge the hole for the rear of the motor slightly. Also I need to get some spacers I think. But I did get all the electronics soldered up at least and the push rods put on the rear.
United States, CA, Palos Verdes Peninsula
Joined Dec 2011
One thing to point out. His plane does not have the landing gear skirts and wheel pants on them.
Joined Feb 2011
Joined Apr 2008
Furthermore, there are slots in the upper frame to fit and to line up the two pieces of the side frame where the wings slide into. Am getting use to this plane and after destroying 4 planes in less than a month, I'm flying this one a bit higher than I'm used to. Just got tired of fixing and assembling new planes after work and ignoring the significant other. It gets expensive when I don't pay attention to her. |
This plane is pissing me off, I am tired of dealing with those damn "easy" connectors so I tried the z bend route, well one wire already snapped so now I am short a wire, if I some how managed to get this z bend down I am hoping I have enough rod from a aileron that I have enough for the rudder setup.
Did anybody else do z bends in there's? |
| Thread Tools | |
| Sold ... | hosam | Aircraft - Electric - Airplanes (FS/W) | 1 | Jul 17, 2012 09:23 PM |
| Sold 47" 3D Hobby Shop Edge 540.. LPU | SteveT. | Aircraft - Electric - Airplanes (FS/W) | 1 | Mar 11, 2012 06:58 PM |
