Old Aug 15, 2012, 12:44 PM
00nothing is offline
Find More Posts by 00nothing
Canada, ON, Barrie
Joined Jul 2011
Anyone own this and a buck huck I am buying one or the other and not sure which route to go I know this is EPP and extremly forgiving but with some of the issues I have read I am wondering seeing as how the buck huck is touted as being super tough which would be the better plane. Its going to be strictly outdoor flyer and will defintely see some wind winter flying here in ontario
00nothing is offline Find More Posts by 00nothing
Old Aug 15, 2012, 12:49 PM
nickelbn1 is online now
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
hmm
ok, check this out. looking at this over lunch today. if you look directly from behind, you can see if you line up the elevator stab with the wing and compare you can see in my picture where the left side is lined up with each other but then look at the right wing and you will see the right wing sticking up above the elevator stab. they are not level with each other. thoughts? possible cause?
nickelbn1 is online now Find More Posts by nickelbn1
Old Aug 15, 2012, 12:51 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
you didn't shim this when you built it? Or this happen afterwards?
3drcparts is offline Find More Posts by 3drcparts
Old Aug 15, 2012, 12:59 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Would there be any room to shim it? I have not gotten to putting the main wing on yet, but that stab sure is a tight fit. I did notice the instructions lack the usual measuring guidelines for making sure everything is lined up. For example no mention of measuring from wingtip to stab tip, etc. I know when I put the stab on I measured from tip of stab to front of plane to make sure it was as straight as possible.
grimbeaver is offline Find More Posts by grimbeaver
Old Aug 15, 2012, 01:06 PM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
I did not shim this nor did it happen afterwards. That stab is tight so i dont know how you would shim it. Did any of you check yours this way and actually shim it? Question is....could this cause a right roll at high enough speeds by the way the air is flowing over the stab coming off the wings?
Old Aug 15, 2012, 01:07 PM
Jboy90277 is offline
Find More Posts by Jboy90277
United States, CA, Palos Verdes Peninsula
Joined Dec 2011
On balsa builds, they say it doesn't affect flight much to have the horizontal stab slightly off like that. Of course, if you use the horizontal stab to align your ailerons, it's probably a whole different story. I haven't read the manual to see what it says about aileron alignment. I was just going to use the same approach I used with my 39" Sbach, which was to align the centerline of the wing at the wingtip with the centerline of the aileron.
Jboy90277 is offline Find More Posts by Jboy90277
Old Aug 15, 2012, 01:08 PM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
You said you havent put your wing on yet. Did you see my post asking someone to balance their wing to see if it seems balanced?
Old Aug 15, 2012, 01:10 PM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
I was not using the stab to align my ailerons no. Even if you did in this case a couple clicks of trim would fix the issue.
Old Aug 15, 2012, 01:16 PM
Joined Dec 2011
Not you - I thought I read SD did. And as he said, at high speed, the trim is probably blown back to some degree and you get the roll tendency again.
Old Aug 15, 2012, 01:23 PM
United States, MN
Joined Feb 2011
No I did not but I can do that tonight and let you know.
Old Aug 15, 2012, 01:24 PM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
Old Aug 15, 2012, 01:40 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
my wing is balanced, looks just about perfect
Old Aug 15, 2012, 01:42 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
Maybe the whole fuse by the tail is warped and that's why the stab isn't aligned? Or maybe the wing hole in the fuse isn't level which makes the wing not perpendicular to the fuse? Causing a right roll.
zmonster97 is offline Find More Posts by zmonster97
Old Aug 15, 2012, 01:47 PM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
That is kind of my thoughts....
Old Aug 15, 2012, 01:48 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
plenty of room to shim the stab to get it to line up with the main wing, just did it on mine, but I'm going to hold off building this until I have the time to do all the mods to the landing gear etc
Sold ... hosam Aircraft - Electric - Airplanes (FS/W) 1 Jul 17, 2012 09:23 PM
Sold 47" 3D Hobby Shop Edge 540.. LPU SteveT. Aircraft - Electric - Airplanes (FS/W) 1 Mar 11, 2012 06:58 PM
