Old Aug 14, 2012, 12:11 PM
djmoose is offline
Find More Posts by djmoose
C-Main Champ
djmoose's Avatar
USA, OH, Macedonia
Joined Jul 2009
Originally Posted by skarface View Post
12x6 with a 72g?
Nobody needed the 3dhs arms they just used the hitec long arms correct? Any tips before I start this?
Correct, no need for the longer arms. My only tip is to let the glue dry on the CA hinges. We're all used to CA hinges in balsa drying in like 2 seconds. I had to leave mine sit for about 15 minutes using medium non-foam safe CA.
djmoose is offline Find More Posts by djmoose
Old Aug 14, 2012, 12:13 PM
djmoose is offline
C-Main Champ
djmoose's Avatar
USA, OH, Macedonia
Joined Jul 2009
Originally Posted by nickelbn1 View Post
Not sure what there is to see. If i let sticks sit at neutral the right wing goes down like i am pushing right aileron at about 30%. That would be great if you can talk to those guys about it. I emailed them this morning. I have had a parkzone extra 300 foamy and a eflite extra 260 3d balsa and neither of them did i have an issue with at all. Flew great right away.
ok, I had *thought that it would intermittently drop a wing real quick every once in a while, not a constant roll you have always correct.
I'm looking into this.
Old Aug 14, 2012, 12:14 PM
ICU is offline
ICU
Find More Posts by ICU
ICU
Check out my Shapeways Shop
ICU's Avatar
Dallas,Tx.
Joined Apr 2007
I don't think anyone used the 3dhs arms. In fact on the rudder I used the second most inner hole @ 140 or so EPA. But I would like a few degrees more on my elev, but I think it would be perfect the way it is if I had the 72 in there instead of the 103.
ICU is offline Find More Posts by ICU
Old Aug 14, 2012, 12:15 PM
skarface is offline
Find More Posts by skarface
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
Ok well I am using the bsi thin ca will that work on the hinges? I have no medium.
skarface is offline Find More Posts by skarface
Old Aug 14, 2012, 12:19 PM
djmoose is offline
C-Main Champ
djmoose's Avatar
USA, OH, Macedonia
Joined Jul 2009
Sorry, I actually used thin on the hinges and medium on everything else. My bad!
Old Aug 14, 2012, 12:28 PM
robj is offline
Find More Posts by robj
robj's Avatar
United States, LA, Moss Bluff
Joined Nov 2008
Well 3dhs got this plane to me with in 24 hours wooooo hooooo.
I use to enjoy that when they were in Fredricksburg, TX and I was in Houston. 1 day shipping. Not so much anymore.
robj is offline Find More Posts by robj
Old Aug 14, 2012, 12:32 PM
robj is offline
robj's Avatar
Joined Nov 2008
Oh and it's a pretty quick build. No wiping up excess CA drips on this one!
Old Aug 14, 2012, 12:49 PM
skarface is offline
skarface's Avatar
Joined Aug 2011
ah that stinks.
Old Aug 14, 2012, 01:03 PM
skarface is offline
skarface's Avatar
Joined Aug 2011
The thick CA dried really quick I should have put it in first, so now I just put more thick CA around it and I am going to cut that tip off. oh well.
Old Aug 14, 2012, 01:13 PM
Benf207 is online now
Find More Posts by Benf207
United States, CT, Ridgefield
Joined Dec 2009
Hmm, I used welders on my landing gear, figured it would be stronger.
Benf207 is online now Find More Posts by Benf207
Old Aug 14, 2012, 01:18 PM
Jboy90277 is offline
Find More Posts by Jboy90277
United States, CA, Palos Verdes Peninsula
Joined Dec 2011
I used 30 min epoxy - brushed it on the front and back of the landing gear structure. To access the back of the landing gear structure, I cut a hole in the EPP from the top (battery tray). If you're neat about it, you wouldn't know there was a hole there after you reseal the hole. I didn't care so much about being neat.
Jboy90277 is offline Find More Posts by Jboy90277
Old Aug 14, 2012, 01:25 PM
dentalpain is offline
Find More Posts by dentalpain
dentalpain's Avatar
United States, FL, Marianna
Joined Apr 2011
I soldered my landing gear in
dentalpain is offline Find More Posts by dentalpain
Old Aug 14, 2012, 01:37 PM
chopper62 is offline
Find More Posts by chopper62
Joined Apr 2008
Originally Posted by 3derik View Post
how long do you guys think this build will take me, my second build ever?
Over 24 hrs because I had to wait for the PU glue to dry.
chopper62 is offline Find More Posts by chopper62
Old Aug 14, 2012, 01:43 PM
nickelbn1 is offline
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
I have lots of epo and eps foam planes but this is my first epp. Cant say i am a big fan of this type of foam. Is there some benefit to epp? Seems to flexible to me.
nickelbn1 is offline Find More Posts by nickelbn1
Old Aug 14, 2012, 01:45 PM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
Man if i could get off work right now....its perfect outside! 80 degrees, cloudy, no wind.
Hows it looking for you sd??
Sold ... hosam Aircraft - Electric - Airplanes (FS/W) 1 Jul 17, 2012 09:23 PM
Sold 47" 3D Hobby Shop Edge 540.. LPU SteveT. Aircraft - Electric - Airplanes (FS/W) 1 Mar 11, 2012 06:58 PM
