Old Aug 14, 2012, 09:55 AM
nickelbn1 is offline
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
Well my left aileron was definitely up and right one down even when looking from behind. I am using the apc 11x5.5e with the 72g omega.
Doesnt appear to be a motor issue since we all are using different motors....
nickelbn1 is offline Find More Posts by nickelbn1
Old Aug 14, 2012, 10:31 AM
SD One. is offline
Find More Posts by SD One.
My hovercraft is full of eels.
USA, TN, Gallatin
Joined Aug 2009
Yeah, it's not motors or torque. Maybe the wind will stay down this evening so I can try a little less thrust angle.
SD One. is offline Find More Posts by SD One.
Old Aug 14, 2012, 10:34 AM
djmoose is offline
Find More Posts by djmoose
C-Main Champ
djmoose's Avatar
USA, OH, Macedonia
Joined Jul 2009
I'd like to see video of someone's Edge doing this. I'll be seeing Noll, Arron, and Joe this weekend at the Ohio Huckfest and I'll see if they've heard of anything.
I can't imagine an airframe would cause a random wing drop. I'll also have mine there to maiden by then so I'll be able to chime in as well.
As it stands, I need to see this happening to get a better idea.
moose
Originally Posted by SD One. View Post
Ok. Now we're getting somewhere. Multiple planes rolling right means something. My ailerons look the same after trimming when looking at the plane from above. Left side is up, right side looks flat but really isn't when looking from directly behind or comparing to the Edge graphic on the side.
What props are you guys using? I used an 11x5.5E with the 2810 and an 11x7E with the 2610. Anyone using a 12x6E?
djmoose is offline Find More Posts by djmoose
Old Aug 14, 2012, 10:49 AM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
Not sure what there is to see. If i let sticks sit at neutral the right wing goes down like i am pushing right aileron at about 30%. That would be great if you can talk to those guys about it. I emailed them this morning. I have had a parkzone extra 300 foamy and a eflite extra 260 3d balsa and neither of them did i have an issue with at all. Flew great right away.
Old Aug 14, 2012, 10:52 AM
skarface is offline
Find More Posts by skarface
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
Well 3dhs got this plane to me with in 24 hours wooooo hooooo.
skarface is offline Find More Posts by skarface
Old Aug 14, 2012, 11:01 AM
ICU is offline
ICU
Find More Posts by ICU
ICU
Check out my Shapeways Shop
ICU's Avatar
Dallas,Tx.
Joined Apr 2007
Finally got thru all these pages....
I to am experiencing roll issues. Here's my setup
HS-65MG's all around
Omega 103
ZTW 50A esc
12x6 apc knock-off from hk
First day I flew I had to add just a few click of aile trim (forgot which way, and just chalked it up to maiden trimming). And yesterday was the second day I was able to fly it. I had some unwanted left roll, and I just thought that it was coming from the temp swings the plane went thru going from the office to the car to the field. Didn't think a whole lot about it cause I've experienced this with an epp profile I have. But after seeing other talk about it I'm all ears. I will reasses it after I fly tonight to see if I need to retrim the aile.
Now with a WOT blast mine will roll hard to the right, and the aile virtually do not respond. It's all I can do to keep it from rolling too far. But to be honest I can see why it's happening to me. One this motor has "stupid" power for this airplane, I actually think I'm going to pick up the 72 for this plane instead (it just feels like there is too much nose weight, not nose heavy, too much weight). Two I'm using a 12x6, so there's even more torque. And three these aile are made out of epp, they are going to flex and not keep their shape with the amount of force being applied to them with this motor prop combo.
ICU is offline Find More Posts by ICU
Old Aug 14, 2012, 11:08 AM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
Omega 103
ZTW 50A esc
Well yours is doing just like mine. It will roll hard right upon giving wot and like you its all i can do to get it back level giving full left aileron. It almost seems unresponsive. Except i am using the 72g and a apc 11x5.5. So i dont think your motor power is your issue. Or your prop. Something is wrong here......
Old Aug 14, 2012, 11:11 AM
SD One. is offline
USA, TN, Gallatin
Joined Aug 2009
Thanks for that info. Left roll, as long as everything else is straight, is probably torque. Big motor + big prop and all that. I expected that out of mine but it didn't happen. Right roll though... well... I'm sure we'll figure it out.
I sure like mine a lot better with the lighter setup in the nose. I also prefer having " just enough" power as opposed to insane amounts of power that I'll never put to use for anything other than silly fast vertical runs.
Old Aug 14, 2012, 11:12 AM
hone1er is offline
Find More Posts by hone1er
Team Twisted!
hone1er's Avatar
United States, CA, Hercules
Joined Dec 2011
Have you tried adjusting the thrust angle yet? I think that has been the only reasonable thing to try that has been suggested.
hone1er is offline Find More Posts by hone1er
Old Aug 14, 2012, 11:15 AM
3derik is offline
Find More Posts by 3derik
Team Thrasher
3derik's Avatar
United States, FL, Tarpon Springs
Joined Sep 2011
how long do you guys think this build will take me, my second build ever?
3derik is offline Find More Posts by 3derik
Old Aug 14, 2012, 11:17 AM
skarface is offline
skarface's Avatar
Joined Aug 2011
Cale, this plane has a nice and big 1" tail wheel, I will probably buy more of those and put them on my small balsa planes. Has for main wheels, they will have to go, there 2" but I have 2 1/2" and 3" sitting here.
Old Aug 14, 2012, 11:18 AM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
No i have not had a chance to try that. Probably wont until this weekend. Hopefully sd can today.
Old Aug 14, 2012, 11:20 AM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
This was my 3rd true build and it took me arpund three hours. The motor caused issues getting it mounted right and all since i had to drill new mounting holes. If you have ca accelerator you can probably get done quicker.
Old Aug 14, 2012, 11:36 AM
3derik is offline
Team Thrasher
3derik's Avatar
Joined Sep 2011
oh wow thats quick, still need to get me more Medium CA and a 12x6 and ill have everything set up and laying out
Old Aug 14, 2012, 11:49 AM
skarface is offline
skarface's Avatar
Joined Aug 2011
12x6 with a 72g?
Nobody needed the 3dhs arms they just used the hitec long arms correct? Any tips before I start this?
Sold ... hosam Aircraft - Electric - Airplanes (FS/W) 1 Jul 17, 2012 09:23 PM
Sold 47" 3D Hobby Shop Edge 540.. LPU SteveT. Aircraft - Electric - Airplanes (FS/W) 1 Mar 11, 2012 06:58 PM
