On the thrust angle, the only plane I had to mess with was my 38 epp slick. Those are a little different but I had to put in a lot of right rudder to keep it from dog walking. After some research the rule is if you need right rudder, then the motor needs to point more right. All the other surfaces were normal. One washer did it. It might have been my build but I was glad to get it fixed. I just sold it to get this baby. Might have been some other ways to test and fix it but this one worked for me. Wish I had my servos for this Edge! |
Latest blog entry: Well...
United States, CA, Palos Verdes Peninsula
Joined Dec 2011
EPP is EPP. FoamTac, Welders or Uhu Por should work well. Thick CA takes a while to cure unless you kick it. I'm going to use Welders where I can. I might experiment with FoamTac or Uhu Por to hold the hinges. I'll soak the motor mount with thin CA or maybe even epoxy. The landing gear box will get a coat of epoxy (like the buck huck).
Here's what happens when CA migrates to the wrong place. This was a quick field repair to get flying again as soon as possible. |
Joined Dec 2011
The brown truck came by today.
Finally got the fabled 51" AJ Slick and the EPP Edge. So, there definitely is a significant amount of right thrust built into the motor mount judging from the difference in the amount of square carbon fiber tube protruding from the top. I don't see much of a down thrust, though. I might just go ahead and use washers on the right side when mounting the motor to see if it does away with the issue. The ailerons also look like they'll flex from control horn to tip if you're heavy on the throttle, which I tend to be - will have to think of something to do if that becomes an issue. It may not, given how light this kit is. I'm also going to insert some carbon fiber rods in the square fiber tubes. After seeing those things shatter on Chopper62's plane, I think it needs some support. Off to build! |
I would try to line the ailerons up level with the horizontal stab. Or you could make it so the ailerons are in the middle of the wing.(Not level with the top or bottom of the wing, but in the middle)[/QUOTE]
I was kind of wondering that. i did first line up with ailerons with the horizontal stab and that has where they have been for the first two flights. |
USA, TN, Gallatin
Joined Aug 2009
Ok. Now we're getting somewhere. Multiple planes rolling right means something. My ailerons look the same as described above after trimming when looking at the plane from above. Left side is up, right side looks flat but really isn't when looking from directly behind or comparing to the Edge graphic on the side.
What props are you guys using? I used an 11x5.5E with the 2810 and an 11x7E with the 2610. Anyone using a 12x6E? |
| Thread Tools | |
| Sold ... | hosam | Aircraft - Electric - Airplanes (FS/W) | 1 | Jul 17, 2012 09:23 PM |
| Sold 47" 3D Hobby Shop Edge 540.. LPU | SteveT. | Aircraft - Electric - Airplanes (FS/W) | 1 | Mar 11, 2012 06:58 PM |
