Old Aug 12, 2012, 11:29 AM
SD One. is offline
Find More Posts by SD One.
My hovercraft is full of eels.
USA, TN, Gallatin
Joined Aug 2009
Well, my aileron trim issue is not motor torque. I took off the 2810-1200 and put on the 2610-1100 with an 11x7 prop. I already like it better this way. Lighter in the front. Still plenty of vertical power. Harriers and hovers are so much easier at half throttle than they were at quarter throttle. Lol!
I also spaced out my SFGs with some little ply washers. I had the same clearance as shown in the manual but now i have twice as much. No problems last flight.
SD One. is offline Find More Posts by SD One.
Old Aug 12, 2012, 11:39 AM
RCAddict16 is offline
Find More Posts by RCAddict16
United States, VA, Ashburn
Joined Apr 2012
Alright guys. Its settled, this is my next plane got $140 and I need $80 more. Woohoo! Ill be flyin my edge in 1-2 weeks
RCAddict16 is offline Find More Posts by RCAddict16
Reply With Quote  (Disabled)
Old Aug 12, 2012, 11:48 AM
nickelbn1 is offline
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
Originally Posted by Jboy90277 View Post
Try doing a range check to see if your transmit power is starting to degrade. Also check your batteries and try putting in some fresh alkaline batts - they run aka higher voltage than NiMH, if that's what you're using.
I normally use raovac rechargable batteries and they work great, but lately I have been using some normal duracell batteries and they are probably getting close to worn out. my low battery warning was not going off though. I just put some fully charged raovac's in again to try that. I will try doing a range check too.
nickelbn1 is offline Find More Posts by nickelbn1
Old Aug 12, 2012, 12:13 PM
3dflyboy1 is offline
Find More Posts by 3dflyboy1
USA, CA, San Juan Capistrano
Joined Dec 2010
Traitor!
3dflyboy1 is offline Find More Posts by 3dflyboy1
Old Aug 12, 2012, 12:32 PM
Joined Apr 2012
Originally Posted by 3dflyboy1 View Post
Traitor!
I don't like big profiles. And this is cheaper. So sorry
Old Aug 12, 2012, 01:28 PM
skarface is offline
Find More Posts by skarface
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
Originally Posted by robj View Post
mine is a 1350 and its about 2 years old. timer set for 6 min, but put 8 on it trimming and stuff. so noreal test. i'll probably stick with 6 minlike everything else. it's a smaller prop than the last planeihadthismotor on and the plane is a lot lighter to.
Ok then when I am actually done trimming I will have to set my timer to 5 lol!
skarface is offline Find More Posts by skarface
Old Aug 12, 2012, 01:37 PM
Joined Apr 2012
Why not go for a 1600? I'm going for an 1100 kv 78g motor when I get mine and I'm gonna be using 1600's hopefully ill get 7 if not 8 minutes out of em.
Old Aug 12, 2012, 01:41 PM
skarface is offline
skarface's Avatar
Joined Aug 2011
It is 3$ cheaper so I can get 5 for the price of 4 1600's and I can charge them faster and they are lighter so it will make the plane fly better and it will fit easier.
Old Aug 12, 2012, 01:49 PM
Joined Apr 2012
oh ok good point do you think mine will CG well?
Old Aug 12, 2012, 01:51 PM
skarface is offline
skarface's Avatar
Joined Aug 2011
Not sure because I don't have one.
Old Aug 12, 2012, 01:55 PM
Joined Apr 2012
haha ok.......... do you know if it balances with the Omega 72g and 1600's? maybe its slightly tail heavy, and that case my 78g will work perfectly
Old Aug 12, 2012, 02:06 PM
Jboy90277 is offline
Find More Posts by Jboy90277
United States, CA, Palos Verdes Peninsula
Joined Dec 2011
It's been a while since I used a DX6i, but IIRC you had to tell it what type of batteries you are using. Alkaline batteries that reach the same operating voltage as NiMH are probably about dead.
Jboy90277 is offline Find More Posts by Jboy90277
Old Aug 12, 2012, 03:16 PM
SD One. is offline
USA, TN, Gallatin
Joined Aug 2009
It's low res and still processing but here ya go. I'll upload the HD vid when I get home.
3DHS 40" EPP Edge 540 (4 min 20 sec)
Old Aug 12, 2012, 03:25 PM
3171scott is offline
Find More Posts by 3171scott
3171scott's Avatar
United States, OH, Youngstown
Joined Apr 2011
Ohio HuckFest and King 50 Tentative Schedule
This is just a tentative schedule, the HuckFest tour is about friendship and a LOT OF AWESOME FLYING we are trying to keep it simple and fun!
Wednesday the 15th,
Early set up after 5:00 pm No landing fees, you can fly till dark.
Thursday the 16th the Official start of the event!
Registration starts at 8:00am, electrics open to fly, gas starts at 9:00am. You must be registered and wearing an arm band to fly.
Pilots Meeting at 9:30.
Fommy flight line will be open after the pilot’s meeting.
Huck your little hearts out for the rest of the day! Light will be turned on around 8:30/9:00pm, gas is permitted until 11pm and electrics until midnight. Lights will be turned off at midnight.
The Nighthawks will be giving away pilot prizes every hour starting from 10:00am Thursday to Saturday night! You must be present to win the pilot’s give away.
Friday the 17th
8:00am registration open and electrics and Fommy flight line open to fly, 9:00am gas open to fly.
9:30 Pilots meeting.
Open flying until 3:00pm King 50 qualifying starts.
Open flying starts after the qualifying finishes.
Ok here is where we are making a little change to the Ohio Huck fest, we are going to start a new tradition this year! We are going to have a Night time one trick contest under the lights!
That right I sad it! UNDER THE LIGHTS ONE TRICK CONTEST!!!!!!!!!!
Rules simple…… Any pilot can enter, and any size plane is allowed “ the bigger the better though”. There is a $10.00 entry fee. All Paid to the winner! We will line up all the paid contestants at the flight line at 9pm and they will go one by one and take two shots at there best trick!!!!! We will have Three Judges judging. One for execution, one for difficulty, and one for crowd wow factor! All on a 10 point scoring system. Who ever has the highest point total wins the Cash!!!!!!!!
Saturday the 18th
Open flying to 11:30 am.
Factory team demos start.
Open flying after noon demos until 3:00pm when the finals of the king 50 start.
3:00 pm finals for the king 50
Awards for the king 50
Around 5:00pm the Raffles will start for all the prizes that were donated.
Pilot catered dinner will start at 6:00pm
Open flying once the king 50 awards is over.
Sunday the 19th
Open flying after 9:00am
Teardown whenever
3171scott is offline Find More Posts by 3171scott
Old Aug 12, 2012, 04:05 PM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
http://www.youtube.com/watch?v=sYkmQ...e_gdata_player
nice video. great flying.
Sold ... hosam Aircraft - Electric - Airplanes (FS/W) 1 Jul 17, 2012 09:23 PM
Sold 47" 3D Hobby Shop Edge 540.. LPU SteveT. Aircraft - Electric - Airplanes (FS/W) 1 Mar 11, 2012 06:58 PM
