Old Jul 23, 2012, 12:10 PM
skarface is offline
Find More Posts by skarface
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
Originally Posted by nickelbn1 View Post
Any estimate at all when this plane will be available???
Late summer, so I would say give it another 3 weeks, I will post here when it is available.
skarface is offline Find More Posts by skarface
Old Jul 23, 2012, 03:45 PM
nickelbn1 is offline
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
If i am just learning 3d and really wont be doing crazy hard 3d would hs65hb servos work just fine? At least in the ailerons??
nickelbn1 is offline Find More Posts by nickelbn1
Old Jul 23, 2012, 07:16 PM
skarface is offline
skarface's Avatar
Joined Aug 2011
Hb in the ailerons, you will definitely want metal gear in the rudder and elevator. (well I would definitely put metal gear in the tail, but that's me) also I am going to be using a 103g so I know my servo's will be working harder than if I would put a 72g in it.
Old Jul 23, 2012, 07:23 PM
AZAerobat is offline
Find More Posts by AZAerobat
Fly More Crash Less
AZAerobat's Avatar
United States, AZ, Prescott
Joined Sep 2007
Originally Posted by skarface View Post
Do not get the extra!!! The extra's ailerons flex with anything high speed, so will other control surfaces, so with the extra you can't really do anything at high speed with it. Trust me I know because I had one.
I don't think the 40" edge will have the same problem as the 48" because the edge is less mass and not as much aileron, so don't get the extra if you like full throttle blenders and such things. Either get the 40" when it comes out or don't get the 40" wait for a flight report on how it flies or just get another balsa, that 46" yak has my eye.
Thanks good to know. I will wait. I love the look of the Edge so I will wait too.
Originally Posted by SD One. View Post
It's not you. The elevator is tiny on this plane compared to the wing. That's all it needs though and it reduces the flexing that many people complain about on the Extra during high speed maneuvers. It has a very short tail and is just insane to fly compared to my 40" Sbach of similar build.
Interesting. Good to know that it flies differently then the SBach. I was afraid they would fly very similar and it would be like having two of the same. I am glad to know they are not.
AZAerobat is offline Find More Posts by AZAerobat
Old Jul 23, 2012, 07:53 PM
Park_aviator is offline
Find More Posts by Park_aviator
3D, 1D at a time!
Park_aviator's Avatar
United States, TX, Plano
Joined Aug 2010
They should..... I flew HS45s in my 41" Edge Ailerons, and 65HBs in the tail, and that's what I'm gonna fly in this...
Park_aviator is offline Find More Posts by Park_aviator
Old Jul 24, 2012, 12:29 AM
chopper62 is offline
Find More Posts by chopper62
Joined Apr 2008
Yeah, I think since it's an epp plane it will have a better chance in a crash, maybe you can destroy this one a couple of times.
EPP or balsa ... they all are the same. Last 6 weeks or may be 8 weeks ... I retired two 48" EPPs, the buck huck and the 51" AJ Slick, not including a few deprons and a T-28. I ought to go back to crawling as I destroyed cars and trucks too. Finally, the crack yak has so much welder that it most likely to go up in flame any where near a good source of fire.
Never the less, I can't wait for this plane to come into stock ... may be I should buy two just in case.
chopper62 is offline Find More Posts by chopper62
Old Jul 24, 2012, 06:47 AM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
holy cow! you are crashing a lot of planes. do you just get crazy with them or what are you doing? doesnt sound like much fun when your just crashing and fixing all the time.
Old Jul 24, 2012, 01:35 PM
cale10 is offline
Find More Posts by cale10
3dizzle 4 lyfe
cale10's Avatar
United States, OH
Joined Jul 2011
how well would this 3d with a eflite park 480 190KV with a 40 amp speedy?
cale10 is offline Find More Posts by cale10
Old Jul 24, 2012, 02:34 PM
SD One. is offline
Find More Posts by SD One.
My hovercraft is full of eels.
USA, TN, Gallatin
Joined Aug 2009
It should fly with a Park 480 although you'll probably want more power. Your KV rating is a little off.
SD One. is offline Find More Posts by SD One.
Old Jul 24, 2012, 03:26 PM
cale10 is offline
3dizzle 4 lyfe
cale10's Avatar
United States, OH
Joined Jul 2011
i kinda figured that.
Old Jul 24, 2012, 03:39 PM
Joined Apr 2008
I get bore quickly so I pushed the envelope more than I should. The only plane that I'm "babying" at this time is the EF 60 Extra EXP and the only time she goes below 50 feet in on approach for landing. The man-cave has quite a few broken planes and helis in need of repairing but I'm having too much fun flying the Blade 130X on 3S.
Old Jul 24, 2012, 06:53 PM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
maybe hes gonna run a 12s set-up? lol
keithy4129 is offline Find More Posts by keithy4129
Old Jul 24, 2012, 07:05 PM
zmonster97 is offline
Find More Posts by zmonster97
Team Aztech Aeromodels!
zmonster97's Avatar
United States, PA, Allentown
Joined May 2011
12s 100mah would be about right.
zmonster97 is offline Find More Posts by zmonster97
Old Jul 24, 2012, 09:43 PM
3D, 1D at a time!
Joined Aug 2010
I think a 12S 150mah would work for a great setup with HS65MGs!
Old Jul 24, 2012, 10:06 PM
Joined Apr 2008
Off topic ... where can I send the Omega for repair? Thanks.
Sold ... hosam Aircraft - Electric - Airplanes (FS/W) 1 Jul 17, 2012 09:23 PM
Sold 47" 3D Hobby Shop Edge 540.. LPU SteveT. Aircraft - Electric - Airplanes (FS/W) 1 Mar 11, 2012 06:58 PM
