Old Jan 27, 2013, 11:23 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
Originally Posted by comanch View Post
Umm, I actually use the bullet connectors and like them as they make a great connection and will not come apart unless you pull them apart. There is no way to plug them in backwards as they have a female and male side that are different sizes. They do however have a large enough area for your fingers to grasp without worrying about pulling the wires out of the connector when unplugging. I am using them in this aircraft with SkyLipo 3s 40c 1600 mah batts with an ExceedRC 40a opto w/exceedRc ubec and a Suppo 2814 motor. Merely had to slide the batt back against the wing to achieve balance. Great flying bird. Btw I use these connectors in all my aircraft including smaller 800mm birds.
There is no way to plug them in backwards but... if you are not paying attention when setting up your parallel charge you can plug battery into battery and it will be backwards and short. Also from everything I've heard HobbyKing wires them one way and HobbyPartz does it the other way. So if you buy batteries from both they will be in trouble.
grimbeaver is offline Find More Posts by grimbeaver
Old Jan 27, 2013, 12:29 PM
comanch is offline
Find More Posts by comanch
United States, FL, Satellite Beach
Joined Jul 2012
Well it is true that red must go with red and black with black, kinda like up stick should result in up elevator... The Turnigy batts I've bought from HK had XT60s as did the Watt meter. Cut em off and put on bullets. Everything has its pluses and minuses, I on one hand don't like the space needed for the bullets but on the other it's also what makes them easier to connect and disconnect without pulling a wire, plus the absolute positive connection. Just personal preference, I've seen the gamut with just the few guys/gals at the field, xt60s, deans, power poles (big as well), and others.?
comanch is offline Find More Posts by comanch
Old Feb 01, 2013, 03:51 PM
Lobe_DethFaurt is offline
Find More Posts by Lobe_DethFaurt
Lover of fine cheeses
United States, IN, Mauckport
Joined Jan 2012
Hey all, quick question: where is the best place for the rx?
Lobe_DethFaurt is offline Find More Posts by Lobe_DethFaurt
Old Feb 01, 2013, 03:54 PM
comanch is offline
Joined Jul 2012
put mine on the upper rear of the wing, where the cutout in the underside of the canopy is.
Old Feb 01, 2013, 04:32 PM
Park_aviator is offline
Find More Posts by Park_aviator
3D, 1D at a time!
Park_aviator's Avatar
United States, TX, Plano
Joined Aug 2010
Same
Park_aviator is offline Find More Posts by Park_aviator
Old Feb 01, 2013, 04:47 PM
Joined Jan 2012
OK thanks guys
United States, MN
Joined Feb 2011
same, though the hot glue I used to attach it gave way, i should really get it glued back down.
Old Feb 01, 2013, 05:57 PM
3D, 1D at a time!
Joined Aug 2010
I velcroed mine
Old Feb 02, 2013, 01:45 PM
comanch is offline
Joined Jul 2012
Originally Posted by Park_aviator View Post
I velcroed mine
Same
Old Feb 04, 2013, 12:50 PM
Bipesexual is offline
Find More Posts by Bipesexual
United States, MN, Elk River
Joined Oct 2011
I just bought one of these bad boys. What a riot. I tried to do a review on this plane on 3DHS, but it wouldnt allow me to complete it. Anyways, I just put all of the electronics out of my cheap Techone and this plane kicks butt. I am going to invest in good electronics now that I know its a solid rig. Nice job 3DHS!
Bipesexual is offline Find More Posts by Bipesexual
Old Feb 04, 2013, 09:38 PM
Joined Jan 2012
Still haven't gotten to fly mine. It sits in the room, staring at me...sometimes I swear I hear it mocking me: "You can't fly me, you'll never get to fly me! Ha ha ha!!!"...but then I realize that it's just my wife hiding behind the table...
Old Feb 04, 2013, 09:46 PM
DanBo3D is offline
Find More Posts by DanBo3D
RC Keeps Me Sane
DanBo3D's Avatar
United States, NJ, Carlstadt
Joined Sep 2005
Which Techone plane did the transplant come from? What motor did it have?
Just curious on the "cheap" electronics that made it kick butt
DanBo3D is offline Find More Posts by DanBo3D
Old Feb 08, 2013, 03:48 AM
Joined Jan 2012
Thinking about using this battery...any ideas?
https://www.aero-model.com/4_157_165...1300-3S30.html
Old Feb 08, 2013, 07:39 AM
Aaeolien is offline
Find More Posts by Aaeolien
3d addict
United States, NY, Rochester
Joined May 2011
Haven't used those ones. I have a bunch of http://epbuddy.com/index.php?main_pa...roducts_id=357 and they are great. Shows out of stock at the moment but keep en eye out for them. I love the glaciers. Good prices too. The 1300s are good size and weight for this plane.
Aaeolien is offline Find More Posts by Aaeolien
Old Feb 08, 2013, 10:37 AM
DanBo3D is offline
RC Keeps Me Sane
DanBo3D's Avatar
Joined Sep 2005
Here is the battery I intend to use.
It's the biggest that fits. Perfect thickness to slide under the wing.
So as long as the width and thickness & length don't exceed these specs you're good to go.
The Elite series are light too, the 1800 is only 140gr not the listed weight of 145gr
http://www.valuehobby.com/power-syst...800mah-3s.html
Sold ... hosam Aircraft - Electric - Airplanes (FS/W) 1 Jul 17, 2012 09:23 PM
Sold 47" 3D Hobby Shop Edge 540.. LPU SteveT. Aircraft - Electric - Airplanes (FS/W) 1 Mar 11, 2012 06:58 PM
