Old Oct 22, 2012, 09:58 PM
Aaeolien is offline
Find More Posts by Aaeolien
3d addict
United States, NY, Rochester
Joined May 2011
There is different foam sandwiched in the wing, the horizontal and vertical stabs. Everything else looks to be just regular EPP. I honestly would use foam safe ca if you are going that route. Never know where it might drip. I used foam safe ca and beacon foam tac to put mine together.
Aaeolien is offline Find More Posts by Aaeolien
Old Oct 22, 2012, 10:00 PM
Aaeolien is offline
3d addict
Joined May 2011
Also look at reinforcing your landing gear area just a bit. Seems to be pretty weak spot on this one. Mine has been broken out a couple of times and this last time I slathered it with wood glue before clamping it together to dry. And I've bounced it twice since the in the grass pretty hard. Hard enough where it would have broken out before.
Old Oct 24, 2012, 06:12 AM
Natesh is offline
Find More Posts by Natesh
PA Team Pilot
Natesh's Avatar
Australia, SA, Adelaide
Joined Jul 2012
I reckon all the glues recommended by the manual for each step are spot on.. I'd go that way.. the only thing I did also was to have kicker ready for the hinging of the elev and ailerons, as I learnt from the first edge that the thin CA can seep in and melt the eps core and the stab/wing 'let go' of the surfaces.. use foam safe CA or hit it with kicker immediately after applying CA.. there's no need to fully deflect then CA as with balsa planes, as the epp is SO flexible you can just butt up the epp bevels to just touching (seals the gap), and glue.. massive deflection no prob with no binding. ot allows you to get nice and accurate with your hinging too... just my 2 c
I agree with Aaeolien .. i reinforced the gear mount srea with some 30 min epoxy, just enough to help it not to shatter, but didn't reinforce it into fuse with cf rods etc as some did.. I don't think it's worth adding ANY extra weight to this plane.. when it does go in and the front end smashes up or front of fuse splitting open are REALLY easy to fix.. I use CA and kicker and it takes a few minutes only for the fuse, and epoxy for the firewall area. still flying pretty much perfectly after about a dozen big hits.. including 3 broken wing crashes!! hehe
Natesh is offline Find More Posts by Natesh
Old Oct 24, 2012, 10:42 AM
RC_Feen is offline
Find More Posts by RC_Feen
RC_Feen's Avatar
Culpeper, VA
Joined Oct 2005
Motrolfly 2810-1200
Last night I was installing my Motrolfly 2810-1200 motor and I had to trim the front foam for the motor to clear. Then once installed and I mounted the spinner and prop the spinner is like an inch out from the front of the fuse. Are these two items normal when using the 2810-1200? I'll post some pic's tonight what I'm talking about. Thanks!
RC_Feen is offline Find More Posts by RC_Feen
Old Oct 24, 2012, 10:43 AM
JavaScript is offline
Find More Posts by JavaScript
JavaScript's Avatar
DFW Texas
Joined Feb 2010
I used the 103g Omega... i cut all the foam off around the motor...
now it's just a square opening... the circle around the motor rubbed the foam for me...
JavaScript is offline Find More Posts by JavaScript
Old Oct 24, 2012, 11:05 AM
RC_Feen is offline
RC_Feen's Avatar
Culpeper, VA
Joined Oct 2005
Thanks...so I'm not the only one. BTW...your 14x7 props will be shipped out tomorrow morning. Had to get a box today big enough for them to fit in. Thanks!
JavaScript's Avatar
DFW Texas
Joined Feb 2010
LOL.. No worries.
Old Oct 24, 2012, 06:57 PM
Natesh is offline
PA Team Pilot
Natesh's Avatar
Joined Jul 2012
I just trimmed the front circle cutout a tad wider to just clear the motor you're using, to keep it looking nice and neat. also it's possible to squeeze the motor/mount through the opening, then to squeeze your screwdriver through the gap.. just stretch the epp a bit.. if you crack it slightly (I did) a drop of CA invisibly fixes the crack in seconds.
Old Oct 25, 2012, 08:16 PM
Randino is offline
Find More Posts by Randino
StevieT.
United States, NC, Cary
Joined Apr 2011
Is it just me, or does the tail look small on this plane compared to the wings? Gorilla proportions?
Randino is offline Find More Posts by Randino
Old Oct 25, 2012, 11:31 PM
Aaeolien is offline
3d addict
Joined May 2011
The tail moment is very short on this plane. The tail surfaces have a lot of authority because of it.
Old Oct 26, 2012, 02:05 PM
Natesh is offline
PA Team Pilot
Natesh's Avatar
Joined Jul 2012
yeah, and very agile because of it.. still I needed to use an servo arm extension to get a good 50 degrees of elev throw that I wanted.. flat spins flatten out better, KE spins and waterfalls are tighter etc.. I've set a switch to lower expo on rudder and elev (about 40%) that I flip on if i'm gonna be hovering/TR'g for a while.. less stick movement needed then
it is an interesting shaped plane i think.. yep it does have gorilla arm wings. when I first got it I looked at the short tail moment and thought it would be way twitchy, but it is surprisingly solid and precise (though it definitely requires being fast on the sticks! ) . hovers look amazing with the huge wings and short fuse/tiny tail hanging down, and work so well. i love the bright orange paintjob against a clear blue sky too!
Old Oct 26, 2012, 02:30 PM
bigbookfrank is offline
Find More Posts by bigbookfrank
bigbookfrank's Avatar
United States, TX, Dallas
Joined Mar 2004
Haven't flown mine in a week and I am in serious withdrawl mode! Putting the new 103g in tonight and finishing the aurora lights so the only thing that will prevent flying is the W's - Wind, Work, and Women (and trying to stay away from the later ....
Anyone have the 48" Yak EPP.... thats my next purchase I think. I am really liking these planes...more forgiving than Balsa so funner!
bigbookfrank is offline Find More Posts by bigbookfrank
Old Oct 26, 2012, 02:39 PM
JavaScript's Avatar
DFW Texas
Joined Feb 2010
Frank..
There is a guy that flies at the field that has one... of the 48" extras.. they fly nice.. i thought it was somewhat under powered but could have been his setup.
I like my 48" balsa planes from 3dh to fly 4s vs 3s that could be what i am more used to...
but they fly nice!
J
Old Nov 01, 2012, 11:00 AM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
There was a few spots that I used foam-tac instead of CA because I felt more comfortable with the stronger bond of foam-tac. I think the stab was one of them.
I had no problems with non-foam safe thin CA for the hings. I would guess you are using too much. It really takes very little CA to do hinges, much less then you would expect.
I notice they still have not allowed any reviews to be posted on the 3DHS site.... also the link for the manual is broken. Sigh. Still flying but not sure I'll be buying another 3DHS plane in the future.
grimbeaver is offline Find More Posts by grimbeaver
Old Nov 01, 2012, 11:25 AM
Joined Mar 2004
Anyone totally built a new forewall from scratch yet....tips or pics? Mine is toast after 4 repairs.... motor flew out of plane after last one LOL.... Everything else is fine just going to have to fabricate new firewall and mount it securely. Not a structural engineer though so tips would help.
Sold ... hosam Aircraft - Electric - Airplanes (FS/W) 1 Jul 17, 2012 09:23 PM
Sold 47" 3D Hobby Shop Edge 540.. LPU SteveT. Aircraft - Electric - Airplanes (FS/W) 1 Mar 11, 2012 06:58 PM
