Old Aug 01, 2012, 03:35 PM
3171scott is offline
Find More Posts by 3171scott
3171scott's Avatar
United States, OH, Youngstown
Joined Apr 2011
Originally Posted by Eagle34 View Post
They always have suggested the HS-65 servo for the ailerons on the 34 EPP Edge. Main reason is you have one servo driving both ailerons via a common horn.
The size of the servos (65 and 45) are almost the same so there isn't that much problem with the mounting. HS-45HB LxW is 23.4 x 9.7mm HS-65 LxW is 24x12mm. The 45 is an 8 gram servo and the 65 is a 12 gram servo. I think this is the biggest factor in trying to keep the weight light. The issue I see is the 14 oz/in torque of the HS-45 enough for the control surface, we all know the 25 oz/in of torque of the HS-65 is enough for any of these and larger size planes.
I understand, and have ben building 3D planes for almost 10 years now. I was just trying to give some perspective from another point, but I guess I upset a few for posting my thoughts. If you are a Joe Smith and Wamsy's who donít hit the ground much and have great throttle control go with the 45's and only 14oz of torque. I still bump the ground so the metal gear and 30 plus oz of torque. I built my 34 edge with 3114's all the way around and love it. I built it like the 33 Extra though, I left out some carbon and kept it under 6 OZ.
Again I was just trying to add a little other perspective.
Scott
3171scott is offline Find More Posts by 3171scott
Old Aug 01, 2012, 03:37 PM
3171scott's Avatar
Joined Apr 2011
This just in 3DHS is going to donate two 40 EPP Edges for raffel at the OHIO HuckFest and King 50!!!!!!!!!!!!!!
Old Aug 01, 2012, 03:39 PM
3171scott's Avatar
Joined Apr 2011
Also a 103 Extera!!!!!!!!!!!!!!!!
Get your pre registration done at the Nighthawks webpage!!!!! nighthawksrc.com
SD One. is offline
Find More Posts by SD One.
My hovercraft is full of eels.
USA, TN, Gallatin
Joined Aug 2009
Originally Posted by 3dflyboy1 View Post
What would be the benefit of using digital or analog? Would all analog be fine?
I wondered that same question, compared the two Solar variants in my Sbach (A107 vs. D650) and found it wasn't worth the extra cost, nor the time it took to swap them!. I lost my 6V capability and the extra torque that comes with it while gaining only the jitters. Yes, it enabled 11ms response time on my DX8 but I couldn't tell a difference. I'd rather have the extra torque.
Obviously, a higher quality servo may give different results.
All analog servos will be fine and dandy for this plane. Save the $$ and buy more batteries. You'll want as many as you can get. I have eleven 1300 packs and can burn through them in an hour if I don't bring a charger to the field.
SD One. is offline Find More Posts by SD One.
Old Aug 01, 2012, 05:20 PM
3dflyboy1 is offline
Find More Posts by 3dflyboy1
USA, CA, San Juan Capistrano
Joined Dec 2010
Originally Posted by skarface View Post
Great info, thanks!
Analog it is, then! More batteries are always nice.
3dflyboy1 is offline Find More Posts by 3dflyboy1
Old Aug 01, 2012, 06:29 PM
3171scott's Avatar
Joined Apr 2011
Great info!
Old Aug 01, 2012, 07:14 PM
djmoose is online now
Find More Posts by djmoose
C-Main Champ
djmoose's Avatar
USA, OH, Macedonia
Joined Jul 2009
Scott, did you order one of these? Bobby, Dave, and myself all have...it's going to be an orange whirlwind at the nighthawks soon!
Scott
djmoose is online now Find More Posts by djmoose
Old Aug 01, 2012, 09:04 PM
3171scott's Avatar
Joined Apr 2011
Sure did!....LOL......then today we spoke with Noll and 3DHS is donating 2 for the huckfest!
Old Aug 02, 2012, 12:17 AM
KTMRacr is offline
Find More Posts by KTMRacr
When in doubt, gas it!
KTMRacr's Avatar
United States, KS, Spring Hill
Joined Dec 2010
Hello my name is Brian, and I think I'm an addict.
Just got my night flyer twisted hobbys 44" EPP Extra Slick all put together and have about 15 flights on it. 71" Gas Slick came in on Monday, still waiting on engine and servos to come in. And here I am contemplating buying this thing.
I really like the 44" Extra Slick but it chews up the sky and I'm a little nervous flying it in my front yard (vacant lot across the street) with all of the houses around. A 40" EPP might have been a better choice for a neighborhood night flyer. I suppose I'll never know until I pony up and hit the "Add to Cart" button.
I cannot possibly imagine needing anything more than the 72g motor in this thing. I've got the 72g in my 41" Buck Huck and I can't imagine needing more power than that in a smaller plane.
I've been having good luck with the New Power servos from EPBuddy.com, just to add to the servo discussion. I would think the XL-9HMB for like $5 or $6 or something would work just fine in this plane. (that is what I put on my 44" Extra Slick and they are working great). (Note: They claim 9grams but they are really more like 11g with the metal gears and ball bearings).
KTMRacr is offline Find More Posts by KTMRacr
Old Aug 02, 2012, 12:21 AM
skarface is offline
Find More Posts by skarface
Fly low or fly home.
skarface's Avatar
United States, PA, Dover
Joined Aug 2011
Haha short stories that start off with "Hi, I am an addict", are great. Have fun!
skarface is offline Find More Posts by skarface
Old Aug 02, 2012, 03:32 AM
Eagle34 is offline
Find More Posts by Eagle34
TEAM HILLBILLY
Eagle34's Avatar
Pass Christian, MS
Joined Jan 2010
Scott
Thank you for your insight. I am sorry if my post offended you, not my intent at all. I was not sure you knew that the ailerons on the 34 Edge were controled by one single servo. I agree with you about durability. I am pretty rough on my planes too. If there was a quality 9 gram metal geared servo that didn't cost almost as much as a 65MG I would go with that just for the weight savings. I have been thinking about InoLab HSD-202MG's as I've heard good things about the brand but haven't tried them yet. The only thing is they still cost $20 each, for that price I'd spend a bit more and get something I know is good to go (HS-65MG) for the tail surfaces at least, even though they weigh a bit more.
Again didn't mean to offend and I apologize.
Eagle34 is offline Find More Posts by Eagle34
Old Aug 02, 2012, 08:25 AM
nickelbn1 is offline
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
Wow those $6 new power servos from epbuddy have a ton of torque. Look really good for the money. Have to keep those in mind.
nickelbn1 is offline Find More Posts by nickelbn1
Old Aug 02, 2012, 12:59 PM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
4 more days!
Old Aug 02, 2012, 01:02 PM
Park_aviator is offline
Find More Posts by Park_aviator
3D, 1D at a time!
Park_aviator's Avatar
United States, TX, Plano
Joined Aug 2010
Originally Posted by nickelbn1 View Post
4 more days!
Sweet if only 3dhs was in Texas still.... Mine would be here on the 7th...
Park_aviator is offline Find More Posts by Park_aviator
Old Aug 02, 2012, 01:46 PM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
They are in PA now right? Probably wont get mine till the 9th or 10th
Sold ... hosam Aircraft - Electric - Airplanes (FS/W) 1 Jul 17, 2012 09:23 PM
Sold 47" 3D Hobby Shop Edge 540.. LPU SteveT. Aircraft - Electric - Airplanes (FS/W) 1 Mar 11, 2012 06:58 PM
