Old Oct 01, 2012, 02:42 AM
Natesh is offline
Find More Posts by Natesh
PA Team Pilot
Natesh's Avatar
Australia, SA, Adelaide
Joined Jul 2012
hi guys.
Hiya Nickelbn.. i was thinking about your conclusion about bendy ailerons being part of the unresponsive ailerons.. if they are being blown back by the air, the in ner part which is still fully deflected at 35 degrees should roll the plane pretty well still. so I don't think it is part of the problem. Many people are having no probs at all with the edge - the ailerons being too thin and bendy has been ruled out IMO. There's got to be something else wrong if the ailerons have zero authority at 50% throttle.
.... Your choice, though, that you're done continuing.. you've been at it a while. Best of luck with the EF plane when you get it.. sounds great. I'm almost finished the KMX build.. check out some of the flight vids for it (youtube, precisionaerobatics.com).. UNBELIEVABLE!! check out the bandit too if you're looking to compare the EF edge with it's competitors.. the bandit is about the sexiest plane ever made IMO.
Chopper.. I don't think it's helpful telling people to throw away their planes.. you called it a piece of ... have you seen this little plane hard at it? it's awesome.. lots of guys at the field want one now. doesn't that speak for itself? I don't know how you could bin a plane that you couldn't get to fly right, and want to post a bad review of it on 3dhs site, while you know and have seen others out there flying it SUPERBLY.. wouldn't you want to question your setup and want to find out what isn't working properly first? this plane is not very complex.. VERY straightforward build. or should be anyway
JSSmith's post seems like a polite and diplomatic was of saying that if you set this plane up properly I'll fly perfectly. I agree
Natesh is offline Find More Posts by Natesh
Old Oct 01, 2012, 03:53 AM
Jboy90277 is offline
Find More Posts by Jboy90277
United States, CA, Palos Verdes Peninsula
Joined Dec 2011
Flew my replacement plane this weekend (Omega 103g, HS 65MGs, straightened wing, and no extra hinges). I have to admit, I'm not taking good care of it as I promised.
Windy Day Flying with my 3DHS 40" EPP Edge 540 (5 min 8 sec)
Sunday fun with my 3DHS 40" EPP Edge 540 (5 min 38 sec)
Jboy90277 is offline Find More Posts by Jboy90277
Old Oct 01, 2012, 06:29 AM
Natesh is offline
PA Team Pilot
Natesh's Avatar
Joined Jul 2012
http://www.youtube.com/watch?v=j-LJNAfe0h0
http://www.youtube.com/watch?v=P27gmuQhbxM
nice flying! it's fun in the wind too hey.
I've not been taking care of my second one either! it's so tempting to spend a lot of time a foot off the ground.. so I've repaired a SFG a few times and foam safe CA'd a wing tip back on.. oops. I did almost a whole battery in low inverted harrier the other day. really fun.
I did my first one roll loop today in the edge.. worked VERY well with the edge ..seems all sorts of rolling tricks are great.. I like how it's easy in this one to transition from rolling harrier to torque roll with nothing but a tiny bit of extra throttle.
Old Oct 01, 2012, 09:19 AM
nickelbn1 is offline
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
Teshiecat, when you keep making statements about how straightforward and easy this plane is to set up you are only making those of us who have had problems or are having problems feel that much dumber. You are essentially saying "we are just that dumb" if we are having problems. And i do not believe everyone on here who has had problems is that dumb.
nickelbn1 is offline Find More Posts by nickelbn1
Old Oct 01, 2012, 10:25 AM
Da Big_G is offline
Find More Posts by Da Big_G
"Get off the runway!"
Da Big_G's Avatar
United States, TX, Hutto
Joined May 2012
Originally Posted by nickelbn1 View Post
Teshiecat, when you keep making statements about hoe straightforward and easy this plane is to set up you are only making those of us who gave had problems or are having problems feel that much dumber. You are essentially saying "we are just that dumb" if we are having problems. And i do not believe everyone on here who has haf problems is that dumb.
Teshiecat is one of the few out there that is completely happy with this pos plane. A 3DHS plant?
Da Big_G is offline Find More Posts by Da Big_G
Old Oct 01, 2012, 10:28 AM
jsmith285 is offline
Find More Posts by jsmith285
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
No not a Plant, Sorry to disappoint you. Just someone who enjoys the plane.
jsmith285 is offline Find More Posts by jsmith285
Old Oct 01, 2012, 11:39 AM
Da Big_G is offline
Da Big_G's Avatar
Joined May 2012
Not dissapointed at all. Actually, I have a couple of hundred flights on mine. I enjoy it between the required wing twists.
Old Oct 01, 2012, 02:36 PM
grimbeaver is offline
Find More Posts by grimbeaver
United States, MN
Joined Feb 2011
I enjoy mine but I don't fly it fast, I have bigger nitro planes for that.
grimbeaver is offline Find More Posts by grimbeaver
Old Oct 01, 2012, 03:13 PM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
You just called this a pos plane and then said you have flown it a hundred times and enjoy it???
Old Oct 01, 2012, 03:18 PM
Draven is online now
Find More Posts by Draven
Infinite Zenith
Draven's Avatar
United States, TX, Arlington
Joined Sep 2006
Man, all this negative talk is bumming me out before my edge has arrived. I understand this is EPP but c'mon, way more than I'd like to hear.
I guess I won't be able to do high speed passes like I did in my 41" buck huck.
Draven is online now Find More Posts by Draven
Old Oct 01, 2012, 03:54 PM
Da Big_G is offline
Da Big_G's Avatar
Joined May 2012
Currently it's the only plane small enough to fly at home. My statement stands.
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
Sure you will
You'll even be able to turn it too.
Old Oct 01, 2012, 04:06 PM
Da Big_G is offline
Da Big_G's Avatar
Joined May 2012
Sorry...but if 3DHS was honest, they would have allowed reviews on this plane, and you would have been able read the reviews and make a confident decision. The plane is fine if you correct the wing twist every so often. I found out the hard way coming out of a split S over some trees. The ailerons were ineffective turning to the left. The tree stopped my plane. Maybe you will get one of the "perfect" ones.
Old Oct 01, 2012, 04:45 PM
Infinite Zenith
Draven's Avatar
Joined Sep 2006
Sure you will
hmmm
Hopefully I will. If not, I won't mind having to correct the wing twist. But still, It'd be nice if 3DHS planned on fixing the issue.
Old Oct 01, 2012, 04:51 PM
bigbookfrank is offline
Find More Posts by bigbookfrank
bigbookfrank's Avatar
United States, TX, Dallas
Joined Mar 2004
I finished mine yesterday and couldn't determine much if any twist. My chop sticks didn't line up perfect but within a half inch and that could have been from not being able to set them both exactly the same way on each wingtip. There is a slight visual curve up in one wingtip leading edge but it is so slight I hate to mess with it until I fly it as I might make it worse the other way. I will be interested to see how it flys Wednesday Am (next opp with no wind) but I am pretty confident mine is OK.???
bigbookfrank is offline Find More Posts by bigbookfrank
Sold ... hosam Aircraft - Electric - Airplanes (FS/W) 1 Jul 17, 2012 09:23 PM
Sold 47" 3D Hobby Shop Edge 540.. LPU SteveT. Aircraft - Electric - Airplanes (FS/W) 1 Mar 11, 2012 06:58 PM
