Old Sep 28, 2012, 09:07 PM
VegasRay is offline
Find More Posts by VegasRay
VegasRay
USA, NV, Las Vegas
Joined Oct 2005
E/Z Spoiler Linkage
FF - I think I have the fix for your spoiler setup. First move the nylon horn back as near the trailing edge of the spoiler as possible. Just leave enough room for the spoiler to close down completely. You might need to cut down the length of the nylon horn - hard to tell from your pictures. Next you MUST move the servo as far FORWARD as possible - right up to the back of the spar. That's why I cut off the servo mounting ears/lugs. Using your transmitter, adjust the servo so the servo arm is pointing at the nylon horn when the transmitter stick is fully UP (spoiler closed). Move the stick about half way down then slid your wire thru all three links but use only one set screw - in any one of those three. You might need to lengthen or shorten the wire to clear the spar when the spoiler is closed.
That should give you a very nice spoiler operation.
Ray
VegasRay is offline Find More Posts by VegasRay
Old Sep 29, 2012, 12:29 AM
Fickle flier is offline
Find More Posts by Fickle flier
United States, NV, Reno
Joined Jun 2012
You guys are right. After looking again there is not enough clearance between the servo and controll horn. I will give it a shot after trimming the control horn.
Fickle flier is offline Find More Posts by Fickle flier
Old Oct 02, 2012, 04:40 PM
dwells is offline
Find More Posts by dwells
≡LSF8067≡
dwells's Avatar
Bedford, TX
Joined Oct 2007
I'm a fan of pull string (SpiderWire) because of the easy setup and weight savings. I would venture it's half the weight of servos/wires in the wings, less draw on the battery and easier to get them even.
Sailplane spoiler closing (1 min 11 sec)
dwells is offline Find More Posts by dwells
Old Oct 02, 2012, 09:20 PM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
Heretic! Luddite! You will cause the economy to collapse with that kind of parsimony. Consume! ;-p
http://www.youtube.com/watch?v=RtCiMBXMy8U
lincoln is offline Find More Posts by lincoln
Wanted Powered Cularis or other powered sailplane with flaps/spoilers. Billbor Aircraft - Sailplanes (FS/W) 3 Jun 28, 2012 05:56 AM
Wanted Powered Cularis or other powered sailplane with flaps/spoilers Billbor Aircraft - Electric - Airplanes (FS/W) 0 Jun 27, 2012 04:29 PM
Question Spoiler placement CO Hiker The Builders Workshop 11 Jun 24, 2012 08:41 PM
Discussion Flaps/Spoilers markminc Electric Plane Talk 10 Jun 20, 2012 12:53 PM
Discussion East rc spoiler? C_Heath Giant Scale Airplanes 3 Jun 17, 2012 07:44 AM
