Old Jul 20, 2012, 06:02 PM
kostuk is offline
Find More Posts by kostuk
Joined Nov 2003
Hi Lincoln,
Do you also have an arrangement with wire instead of rubber bands for the single servo arrangement like Craig's in post 9.
Ray
kostuk is offline Find More Posts by kostuk
Old Jul 20, 2012, 08:40 PM
lktroiani is offline
Find More Posts by lktroiani
"Get 'er Up"
lktroiani's Avatar
Wichita, KS
Joined Nov 2008
I've used both cable/string and direct wing servo methods for actuating spoilers and I much prefer the servo route. Servos in the wing provide a very positive and precise spoiler control movement which is very easy to adjust with end-point travel and trim adjustments from the transmitter. Another big plus is that plugging in the servos leads is much more convenient than connecting the strings/cable in the fuselage when attaching/removing the wing. Here's some pictures and a video of my typical setup. In this case I'm using a HS-55 in a Houston Hawk, which BTW, has worked out very well over the last few years:
http://www.rcgroups.com/forums/showthread.php?t=1637433
lktroiani is offline Find More Posts by lktroiani
Old Jul 20, 2012, 09:46 PM
Riserflier is offline
Find More Posts by Riserflier
Joined Jun 2004
Iktroiani has nailed it. Light weight servos (and low cost). Precise adjustments. Convenience. All worthwhile and superior to strings.
If light weight and low cost servos would have been available years ago, we may not have ever considered string acutaued spoilers.
Riserflier is offline Find More Posts by Riserflier
Old Jul 20, 2012, 09:55 PM
jdveirin is offline
Find More Posts by jdveirin
Zeus
Joined Jul 2006
I like that setup. I am building a Windlord flying wing (build log at www.rcgroups.com/forums/showthread.php?t=1680750). I am going to use your installation method for the spoilers. If the Hitec-55 is sufficient for the Hobby Hawk spoiler, it should be enough torque for the Windlord spoilers.
The blue Hitec HS-55 looks cool. But, due to the brown laser cut edges in my partial kit, I am going with opaque covering. So, I may use Futaba S3114 servos since they are about the same weight with a higher torque rating and a bit smaller, albeit $5 more per servo.
Futaba S3114 - .21 torque, .28 oz weight
Hitec HS-55 - .1527 torque, .27 oz weight
jdveirin is offline Find More Posts by jdveirin
Old Jul 20, 2012, 09:59 PM
VegasRay is offline
Find More Posts by VegasRay
VegasRay
USA, NV, Las Vegas
Joined Oct 2005
Fickle Flier - here's the link to a spoiler setup I first showed in RC Groups almost four years ago. There are many sailplanes using this linkage with great success. The photos show how to install. Easy, precise control, light weight and reliable.
http://www.rcgroups.com/forums/showthread.php?t=955499
My advice to you is to pick any of the versions described here either strings, springs, rubber bands, servos, etc.
Over the years I have tried all of them and finally developed the E/Z Links. To me it's a keeper.
Ray
VegasRay is offline Find More Posts by VegasRay
Old Jul 21, 2012, 09:55 AM
jdveirin is offline
Zeus
Joined Jul 2006
Ray,
Wow. That is about as easy a setup as you can get. That's clever.
Old Jul 21, 2012, 11:12 AM
kostuk is offline
Joined Nov 2003
Thanks for the setups! I have tried several with some success but am always looking for a better mousetrap!
Thanks!
Ray
Old Jul 24, 2012, 02:18 AM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
Originally Posted by kostuk View Post
Hi Lincoln,
Ray
Unless I'm missing something, the same arrangement ought to work.
lincoln is offline Find More Posts by lincoln
Old Jul 27, 2012, 08:31 PM
Mike-O is offline
Find More Posts by Mike-O
Mike-O's Avatar
Joined Aug 2010
Kostuk:
I haven't actually used spoilers on anything yet, so can't speak to how well what works, but have been collecting ways to do it - mainly with servos in the wing. They all came from RCGroups posts originally.
See attachments:
Mike-O is offline Find More Posts by Mike-O
Old Jul 28, 2012, 01:04 PM
ak79 is offline
Find More Posts by ak79
Flightcomp.com
ak79's Avatar
United States, CA, Torrance
Joined Apr 2006
If you want a super easy to install and very light spoiler set up try some simple torsion springs-
http://www.rcgroups.com/forums/showt...sagitta&page=7
ak79 is offline Find More Posts by ak79
Site Sponsor
Old Jul 28, 2012, 02:26 PM
onethermal is offline
Find More Posts by onethermal
LSF # 7390 IV
onethermal's Avatar
Sandy, Utah
Here is how I have done my spoilers for years http://www.rcgroups.com/forums/showp...4&postcount=59 and here is how I keep them closed with a magnet http://www.rcgroups.com/forums/showp...8&postcount=86
Hope that helps ... just keep every thing simple. small servos are a great way to go not strings and more linkages.
Clarence
onethermal is offline Find More Posts by onethermal
Old Aug 01, 2012, 05:56 PM
lincoln is offline
Joined Dec 2001
Just keep everything simple. Strings are nice and simple, not more wires, soldering and connectors! ;-)
I think that one's idea of "simple" probably depends on which way you've done it yourself. I've done both, and I don't think servos are easier. Unless the fuselage is so tight that you don't have room for the servo in it.
Maybe a miniature receiver and battery in a one or three piece wing and no wires or strings to connect at all!
Clarence
Old Sep 28, 2012, 03:27 PM
Fickle flier is offline
Find More Posts by Fickle flier
United States, NV, Reno
Joined Jun 2012
Still having trouble
I am still having trouble with my spoilers. I don't want to give up on them so I am asking here again. Can you guys see any alignment errors or something I am not noticing. I am using the method suggested by Vegas Ray but I have never build an aircraft so... I don't know.
Thank you for looking.
Fickle flier is offline Find More Posts by Fickle flier
Old Sep 28, 2012, 07:10 PM
LVsoaring is offline
Find More Posts by LVsoaring
Unrepentant Paragon addict
LVsoaring's Avatar
United States, OK, Moore
Joined Jan 2006
FF, if I'm seeing correctly, your set-up looks like it will bind. The servo arm will rotate, and thus be creating an arc. Your horn on the spoiler also rotates, the connection point also making an arc. But the arcs are in 2 different directions. I know, my explanation is probably not clear at all. May I suggest sending Vegas Ray a PM, I'm sure he can get you all squared away.
LVsoaring is offline Find More Posts by LVsoaring
Wanted Powered Cularis or other powered sailplane with flaps/spoilers. Billbor Aircraft - Sailplanes (FS/W) 3 Jun 28, 2012 05:56 AM
Wanted Powered Cularis or other powered sailplane with flaps/spoilers Billbor Aircraft - Electric - Airplanes (FS/W) 0 Jun 27, 2012 04:29 PM
Question Spoiler placement CO Hiker The Builders Workshop 11 Jun 24, 2012 08:41 PM
Discussion Flaps/Spoilers markminc Electric Plane Talk 10 Jun 20, 2012 12:53 PM
Discussion East rc spoiler? C_Heath Giant Scale Airplanes 3 Jun 17, 2012 07:44 AM
