Old Jul 17, 2012, 03:32 PM
Fokker DII is offline
Find More Posts by Fokker DII
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
New Ignition Much Better DLE 30
After damaging a wire, I replaced my stock DLE 30 #3 ignition module with a standard RCExl unit. A world of improvement.
After the first start of the day it always fires and runs on the first flip,. Idle is very smooth and the midrange burble is mimimal. Transition is crisp. All without needing to adjust the needles.
Fokker DII is offline Find More Posts by Fokker DII
Old Jul 17, 2012, 07:50 PM
BrianSmith is offline
Find More Posts by BrianSmith
<>< AKA W4BPS
USA, TN, Tullahoma
Joined Dec 2001
ignition change
Nice to know. Thanks for sharing that tid bit. Brian
BrianSmith is offline Find More Posts by BrianSmith
Old Aug 23, 2013, 06:33 PM
sailr is offline
Find More Posts by sailr
Land O' Lakes, FL
Joined Aug 2003
Are you saying you went BACK to an older version?
sailr is offline Find More Posts by sailr
Old Aug 23, 2013, 06:57 PM
Zor is offline
Zor
Find More Posts by Zor
Zor
Ontario,Canada
Joined Feb 2007
Soon going to gasoline
Fokker DII,
I am trying to save my nickels (no more pennies in Canada) to soon buy a gasoline engiine. I am trying to learn as much as available about their usage.
I would appreciate it if you would post your understanding of what caused the much improved performance.
I do not mean changing the ignition unit did it.
I mean is it a stronger spark provided by the new unit ?
Is it a better spark timing ?
Did the improvement use the same spark plug as before ?
Are you using the same fuel ?
Any other changes were done simultaneously ?
Your deductions and findings would be highly appeciated.
Thanks from Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old Aug 23, 2013, 08:12 PM
ahicks is online now
Find More Posts by ahicks
United States, MI, Waterford Charter Township
Joined Aug 2008
The # 3 module is much like the problematic # 4 module shipped with the early DLE20's in that it uses a single step to advance/retard the timing. The difference being it does it at a higher rpm (42-4400?), which masks the issue. As most of us with DLE 20's know, with the #4, that step was just off idle, creating quite the mess for those new to gas setup issues. So the #3 has a single "stepped" advance/retard, and replacement modules get a real timing curve, spreading the advance/retard out in multiple steps.
If Fokker DII's new module is the version that's now good for up to 6v input voltage, it's a total redesign of his original, and I understand that module offers a much hotter spark.
ahicks is online now Find More Posts by ahicks
Old Aug 23, 2013, 10:35 PM
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
Take note that my original post was over a year ago! And I purchased a RExel (sp) single cylinder module, not a DLE specific module.
Anyway, I have since replaced the carb with a Walboro and the DLE 30 has been in 3 or 4 different planes and still runs strong and starts in one flip.
And No Zor, I am not going to write a novel on this.
Old Aug 24, 2013, 01:25 AM
Zor is offline
Zor
Zor
Ontario,Canada
Joined Feb 2007
I did not ask for a novel.
Ahicks just gave some good clues. Thanks ahicks.
Zor
Old Aug 24, 2013, 08:19 PM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
I'm using the stock ign and I don't have a problem.
MX loose left aileron (12 min 12 sec)
kerwin50 is offline Find More Posts by kerwin50
Discussion Is the new AeroFly 5.7 that much better then AeroFly Pro videorov Simulators 3 Jul 07, 2012 01:00 PM
Question DLE-20 and DLE-30 have same Ignition? snoshoe62 Engines 17 Apr 22, 2011 03:52 PM
Help! New to gas, ? test DLE 30 ignition? JBAZ4 Engines 12 Apr 21, 2011 06:19 AM
Found DLE-30 Ignition Module snoshoe62 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Sep 03, 2010 08:30 PM
Sold DLE 30 New in box, with muffler, ignition, everything jongurley Aircraft - Fuel - Engines and Accessories (FS/W) 0 Aug 07, 2010 10:01 PM
