Old Jul 17, 2012, 01:40 PM
airraptor is offline
Find More Posts by airraptor
Joined Mar 2011
GWS ME 262 fans??
I was given two GWS 262 foam kits. i would never done a GWS kit but since free why not. I would like to run two Change Sun 70mm 12 blade fans on a low power set up. the main reason it to keep it quite.
Questions. it will tak a bunch of work to make them fit.
has anyone put 70mm in these? stock is 64mm
Does CS make a 10-12 blade 64mm fan?
Where to buy these fans?
I think the 70mm would give me what i am looking for. thrust and no to little noise on low power (scale) I think i would only need around 20-28 ounces of thrust out of each engine for great performance. they wouldnt be high RPM so i think the stock housing would work great in a 400 watt set up? Thoughts everyone?
airraptor is offline Find More Posts by airraptor
Old Jul 17, 2012, 01:44 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Haoye makes a 7 blade 64mm fan that's REALLY nice at lower RPM settings...the haoye fan take more time to balance but can give some nice power...I think there are a couple of 3mm shaft outrunners on HK that will run with the fan..they're in the EDF motor section.
The 64mm fan is under EDF System & Parts under hardware
erh7771 is offline Find More Posts by erh7771
Old Jul 17, 2012, 01:56 PM
Joined Mar 2011
are they quite and have that jet sound like the CS 70?
Old Jul 17, 2012, 03:59 PM
erh7771 is offline
Joined Nov 2005
They have slightly more tip whine but we're not talking about a factor of 2...
Here's the 7 blade 90mm in an F18
90MM Starmax F 18 Maiden Flight (2 min 36 sec)
Old Jul 17, 2012, 08:15 PM
Joined Mar 2011
where do i buy the CS 70mm 10 blade fans at?
Old Jul 17, 2012, 08:40 PM
erh7771 is offline
Joined Nov 2005
X-flight and HK
Old Jul 17, 2012, 10:42 PM
Slaanesh is offline
Find More Posts by Slaanesh
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
Using CS10s on the GWS ME-262 is going to lead to a much heavier plane. Consider that the GWS 64 EDFs are very light - possibly as light as 85-90g per EDF with motor. CS10s weigh around 70g in themselves, with a light motor you are looking at 150g each. Larger motors, ESCs and batteries. End result will be a model that will weight many 100 grams more than what it should with a light 64mm setup.
If anything you would probably want to drop a size - down to 55mm EDFs.
Slaanesh is offline Find More Posts by Slaanesh
Old Jul 17, 2012, 11:29 PM
Joined Mar 2011
well i was trying to not have the high motor and fan noise like the small ones do. i was going to run a shorter can motor with lower kv and 3 cell pack. keep rpm down and amp draw to around 25-30 amps per motor. i have two of these kits so i can try it one way and then another on the second one.
Sold GWS fans, motors and accessories from ME-262 hole digger Aircraft - Electric - Jets (FS/W) 5 Nov 23, 2008 07:36 PM
Sold Gws Me 262 With Fan/motor's And More pulsery2k1 Aircraft - Electric - Jets (FS/W) 3 Jun 30, 2008 01:08 PM
Help! GWS ME 262 --------------- WOOBLY Fan Question?????? willey GWS (Grand Wing Servo) 67 Nov 16, 2007 03:47 PM
Sold NIB GWS ME-262 w/fans and brushless motor bruff Aircraft - Electric - Jets (FS/W) 2 Jul 16, 2007 12:53 PM
Discussion GWS ME-262 fan model..anybody? mlee8249 Foamy EDFs 6 Mar 02, 2007 09:18 PM
