Old Jul 17, 2012, 11:18 AM
KillerCut is offline
Find More Posts by KillerCut
USA, NY, Brooklyn
Joined Jan 2002
SOMEONE is using Jammers or wayyyy overpowered 2.4ghz near my local park
I've flown in this park for years. This year I cant make it a block out of the park at like 200ft high without losing signal with 2.4ghz spektrum (dm8 on my futaba 9c, with ar6200 without remote, or ar6100)... Before, I could fly as far as possible without a single glitch (until it was seriously a moving dot in the sky)... This really really sucks, I actually lost a plane already (it was only worth $80 but still), what can be done about this?
KillerCut is offline Find More Posts by KillerCut
Old Jul 17, 2012, 11:22 AM
USA, NY, Brooklyn
Joined Jan 2002
I always test the waters of how far i can go, I'd slowly go further and further until I get a dropout and know the limit, but this PERSON must be spotting my plane and then puts on the jammer when I'm far out only. Complete loss of control, yesterday I was lucky enough that my last inputs caused the plane to come back down slowly towards me, and I recovered signal right before it was doomed to hit the ground like 200 feet away from me...
Old Jul 17, 2012, 11:30 AM
turbored21 is online now
Find More Posts by turbored21
USA, WV, Moundsville
Joined Oct 2006
if i had to bet... it sounds alot more like a bad antenna on the TX than a super jammer... might wanna check it out
turbored21 is online now Find More Posts by turbored21
Old Jul 17, 2012, 11:33 AM
USA, NY, Brooklyn
Joined Jan 2002
i took the dm8 apart, everything looks good. I'll test everything with an ohm meter in a minute...
Old Jul 17, 2012, 11:46 AM
USA, NY, Brooklyn
Joined Jan 2002
the antenna extension inside the dm8 is good, the antenna doesn't come apart but I'm sure its good. It seriously has to be someone with a jammer. I've flown to the clouds and back a few times, and then suddenly I'd get complete loss of signal a block away the same day? Has to be a jammer.
Old Jul 17, 2012, 11:54 AM
Trisquire is offline
Find More Posts by Trisquire
Intermediate Multi
Trisquire's Avatar
Columbus, OH
Joined Mar 2005
I've got a solution for you. 72 MHz.
Trisquire is offline Find More Posts by Trisquire
Old Jul 17, 2012, 12:03 PM
USA, NY, Brooklyn
Joined Jan 2002
I use 72mhz too, but I like being able to switch rxs from plane to plane, with 72mhz I have to tape down my antennas. I can fly glitch free wayyy past LOS with 72mhz (fpv)... And with 2.4ghz I'm not at risk from someone else turning on their transmitter on the same channel.....
My whole point is, that I know someone is using a jammer, just what can I do about it?
Old Jul 17, 2012, 12:10 PM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
So you think someone electronics genius had designed and built some sophisticated jammer (it would have to be very clever to jam the spread spectrum frequency hopping 2.4GHz signal) and is now spending all his time watching out for you going to the park (maybe following you ?) just to spoil your fun?
That's a little paranoid, no
IMHO its far more likely just a hardware fault, or momentary loss of control due to wind/turbulence/dumb thumbs.
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Jul 17, 2012, 12:11 PM
signflyer is offline
Find More Posts by signflyer
2^p - 1
signflyer's Avatar
United States, MO, Springfield
Joined Feb 2003
I realize you suspect a jammer, but you really should trouble shoot a bit more. Use a different TX or rx at that location, also try your current TX and rx at a different location.
signflyer is offline Find More Posts by signflyer
Old Jul 17, 2012, 12:19 PM
Mr. foambuilder is offline
Find More Posts by Mr. foambuilder
I fly 3-C Crash,Crunch,Crumble
Mr. foambuilder's Avatar
USA, NM, Clovis
Joined Feb 2010
Send or take your radio to a qualified technician, and have it completely checked out. As stated above, it would take a serious and sophisticated jammer with some serious power to jam your signal to the rx. When these two mate up(tx and rx) that is it, unless there is a problem with your rx, which I suspect. Seriously, I would rule out Jamming, and look for the real culprit. After 53 years f flying, I have only been shot down twice, and that was on 72, when a very close friend turned on his tx and was on the same freq as me Stuff happens. Spend the money on some insurance in the form of a good tech. Roy
Mr. foambuilder is offline Find More Posts by Mr. foambuilder
Old Jul 17, 2012, 12:37 PM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
You may be flying into a telecommunications microwave radio path.
May not have been there a while ago, and recently established.
Communications between cell towers, telephone company central offices, fire, police, etc.
The transmitter can be 20-30 miles from the receiver.
rick.benjamin is offline Find More Posts by rick.benjamin
Old Jul 17, 2012, 12:59 PM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
There is probably less than one in a million chance that you are being jammed by a jammer. You need to really check out your equipment, could be the transmitter, the receiver, the ESC, the battery etc. but almost certainly NOT a jammer.
Rodney is offline Find More Posts by Rodney
Old Jul 17, 2012, 01:11 PM
bartricky is offline
Find More Posts by bartricky
Shelter Kitty "Orange Death"
bartricky's Avatar
United States, FL, Monroe
2.4GHz is not a dedicated RC band. WiFi, cameras, even car alarms are using it. Are you flying over a parking lot?
bartricky is offline Find More Posts by bartricky
Old Jul 17, 2012, 01:25 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Likelihood of a radio issue = 99.5%, jammer = 0.45%, aliens = 0.05%. Like others are saying, it would take a serious device to mess up the communication between the transmitter and receiver.
If there IS some outside source causing the problem, it's almost certainly a commercial device and not a private person with a jamming device.
In any case, there's not much you could do about any outside source of interference. You'd have to figure out what it is, find its actual location, figure out who's responsible for it, and get them to shut it off. It would probably be easier to just find a new place to fly.
Piece is offline Find More Posts by Piece
Old Jul 17, 2012, 01:36 PM
bartricky's Avatar
+1 for aliens
Alert AT&T to use 2.3ghz for LTE, impact on 2.4ghz video gear? Adidas4275 FPV Talk 12 Aug 06, 2012 11:51 AM
Question For FPV, should I use a 2.4GHz or 72mhz radio? easystarfpv4 FPV Talk 2 Apr 30, 2012 12:23 AM
Sold Used Parkzone BNF Habu (local pickup near Torrance CA only) Inerratum Aircraft - Electric - Jets (FS/W) 5 Apr 19, 2012 01:11 PM
Discussion Can I fly 2.4GHz video near 2.4GHz RC TX ? sharonx FPV Talk 8 Nov 10, 2011 10:41 AM
Discussion 2.4Ghz question Someone please explain - 2.4Ghz question - give it to me strait BoboG Radios 2 Feb 18, 2007 06:45 AM
