Hampshire, UK
Joined Jun 2002
They will say yes. 'Cos I have it running here on the bench.
You get slave control over any functions you define. I made a 'pitch' function with no stick/switch assigned. In the trainer menu you enable this function only and away you go. Any functions not assigned to the slave are controlled by the master. In the post above I thought it might only be the primary control functions. I used a model that only had primary functions so that was all it displayed. Got to say it is very freaky having two servos on the bench each being controlled by a different TX. I guess the head tracker outputs a couple of PPM channels of data if you can already plug it into a trainer port. Dave |
OK I am sold. Hope to plug my 1/8" ppm-out trainer plug from my goggles into this wireless buddy box, when it comes out. (I also have Futaba connector if needed) I plan to order a glider from Espirit anyways, so why not get this piece of fine furniture also! Very nice being able to turn the camera with my head, though only 1 of my 3 FPV planes have a panning camera.
Hmmm...I have been looking for a good tray radio, and was excited when I saw the Jeti many months ago. It's looking like a very real thing now.
But much of the discussion here is above my head. I have been flying JR for donkey's years now, and I'm wondering if the DC16 is compatible with the JR/Spektrum Rx's, or will they all have to be replaced with new Jeti Rx's? And, I have to admit I didn't understand the telemetry schematic back on post 103. I'm not sure which of those items was an actual receiver, and if servos plug into it, or into the 4-channel expanders. Do telemetry sensors take the space of 1 servo channel? So many questions... |
Wetafly - AFAIK, the DS-16 is a DC-16 in a different case.
Drice - Jeti Tx only works Jeti Rx - nobody is yet selling clone receivers. The servos plug into the servo outputs on the receivers. The sensors connect to the 'EXT' port. If you want to use more than the one sensor, you need to use an expander, into which the sensors all connect. PS - I love my DC-16
Joined May 2010
The receiver has dedicated EXT connector for telemetry output. All expanders can be daisy chained, like you can see on the picture. Expander = 4 Input or 3 Input + Next Expander -> Zb/Esprit Model http://www.espritmodel.com/jeti-dupl...telemetry.aspx
Joined May 2010
On the top of it, telemetry saved my $7000.00 scale composite Ventus 2cx sailplane. Retract servo got stock and drained both Rx packs. |
The interactive model is pretty nice. I'll have to spend some time doing more research, as my current project uses 16 servos. Currently using Matchboxes for some of the doubling on my JR11X for ail/flap/elev/retract/etc...but I need to get a better understanding of how the DC16 lets me use 16 channels, and if I still get Telemetry with 16 channels, and how I get 10's of Amps through the Rx to all 16 servos, and and and and and...
Research time... |
Hampshire, UK
Joined Jun 2002
One thing Jeti receivers are good at is emulating Matchboxes. The receiver outputs can be set to whatever input channel you want. Each output has endpoint, subtrim adjustment as well as reversing. Can also synch output channels should you wish.
I set two receiver outputs to my single elevator input. Set each servo up on the receiver. Makes transmitter programming a little easier if nothing else. Can also make 2 receivers into a single system. Have an 8 channel RX set to channels 1 to 8 and a second 8 channel RX set to 9 to 16. Can get receivers with external power connectors as well. Rather than having all the battery current coming through normal servo connectors it is attached to the power bus with thicker wires and a multiplex high current connector. Dave |
Joined Feb 2004
Took the plunge and ordered a DC-16 from Esprit. Got the R18rx with satellite too so I can eliminate the Powerbox as this is ultimately for my 42% Slick 360. Will use a current meter to monitor the rudder servo and temp sensors for the motor (DA200). Ideally I would use EGT sensors but the telemetry seems mostly aimed at Electric and gliders. Looking forwards to having a proper tray radio after all these years..
| Thread Tools | |
| New Product Jeti 2.4GHZ system with telemetry, easy-to-use sensors, and audio alarm! | Julez | Radios | 1814 | Sep 11, 2012 04:43 AM |
| Discussion Jeti Duplex DC-16 Radio & Profi Wireless Downlink. Monitor/Record A/V/mAh/Speed real | Esprit Model | Radios | 16 | Jun 16, 2012 08:11 AM |
| Help! Can I run a 2.4GHz Radio and a 2.4GHz FPV system? | MaNDoWn | Video Piloting (FPV/RPV) | 7 | May 06, 2012 01:22 AM |
| Help! Jeti Duplex / updating firmware to EX | VinceHaworth | Radios | 1 | Feb 07, 2012 05:04 AM |
| Question Official Jeti DUPLEX 2.4 Range? | Jose E Bruzual | Hobby Lobby | 3 | Jun 01, 2009 11:58 AM |
