Old Jul 19, 2012, 08:19 AM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
Originally Posted by pigcop2 View Post
so I'll be back for more advise. Hope I don't get too annoying. Haha.
By all means ask away!
Also note you may get more than one way to do something... Both BMatthews and Thermalin have given very good advice in the past, but have 2 different approaches here.
rcav8r2 is offline Find More Posts by rcav8r2
Old Jul 19, 2012, 06:47 PM
pigcop2 is offline
Find More Posts by pigcop2
pigcop2's Avatar
United States, MI, Adrian
Joined Jul 2012
Yes, I figured that I would get several ways to solve a problem. Thats great with me. I've been a trainer of enough subjects to know that there is aways more ways than one to skin a cat. And what works for one may not work for another. So I am always up for hearing different points of view. The way I see it, the more info I can get the better.
So everyone feel free to throw out suggestions.
John
pigcop2 is offline Find More Posts by pigcop2
Old Jul 21, 2012, 11:27 AM
ddog is offline
Find More Posts by ddog
USA, NC, Pinehurst
Joined Oct 2010
GP Electricub
I have been looking at this plane for quite a time. As I recall the plans call for an electric motor with a gearbox. If I were to build this Cub i would most likely use a BL outrunner and LiPo batteries. What are you planning to use for a power plant and batteries? Thanks, DDOG
ddog is offline Find More Posts by ddog
Old Jul 21, 2012, 12:56 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot, 100 yrs too late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
The May AMA issue has a couple page aritcle on washout... just about all you want to know. Constant cord wings (four star, etc) can get way with the last one or two rib bays having some which is easy when building.
Thermalin is offline Find More Posts by Thermalin
Old Jul 21, 2012, 04:28 PM
pigcop2 is offline
pigcop2's Avatar
Joined Jul 2012
Thanks for the heads up. I'll definately read that.
Old Jul 21, 2012, 04:29 PM
pigcop2 is offline
pigcop2's Avatar
Joined Jul 2012
ddog
Not sure what I'll do for power as of yet. I do know if you search, there are a couple of build threads on here. They talk about what motors they were going to use. Sounded like they were both pretty successful.
Old Jul 21, 2012, 04:39 PM
pigcop2 is offline
pigcop2's Avatar
Joined Jul 2012
http://http://www.rcgroups.com/forum...ght=electricubddog.
Here are a few links.
Old Jul 21, 2012, 09:43 PM
pigcop2 is offline
pigcop2's Avatar
Joined Jul 2012
Ah heck. Those links didn't work. And this isn't the forum I saw the threads about motors.
ddog: On rcuniverse there are a couple of threads that talk about motors for the electricub. I'll try to post this link.
http://www.rcuniverse.com/forum/m_60...tm.htm#6235428
Old Jul 22, 2012, 01:25 AM
GravyBones is offline
Find More Posts by GravyBones
Walking with the Lord
GravyBones's Avatar
United States, OH, Tipp City
Joined Apr 2012
On a 39" wing with 15" chord, I put a 1/2" spacer block under the trailing edge near the root rib (near the fuselage) then weight the other four corners down on to my build board. The wing was top side down too. I then glued the underside balsa covering onto the wing ribs to hold it fixed. What you want is less angle of incidence out on the tips to help with stall speeds of the outer part of the wing.
GravyBones is offline Find More Posts by GravyBones
Discussion Quick Question...HK500GT washout control arms cracked? MOJOMOJO1 3D Electric Heli Flying 0 Jun 30, 2012 10:04 AM
Washout question locomoto Modeling Science 3 Jul 24, 2003 01:07 PM
Hobby lobby skimmer washout question. The Other Dave Electric Sailplanes 6 Aug 21, 2002 12:11 AM
Question on washout megawatt Power Systems 5 Mar 21, 2002 05:00 PM
Building Mark Rittinger Python -- Washout Question jet_jer Scale Kit/Scratch Built 11 Mar 10, 2002 02:01 PM
