I can't say for sure, but the easiest way would be to use shim stock under the TE. Shim the tip of the TE to 1/4" (for example) and the pin the root to the board. Use fill shims to keep the TE straight; i.e. no bow. Kinda hard to explain, but this would be the long edge of a 90 degree triangle if you drew it out on a piece of paper.
To warp the building surface you would have to replicate the twist desired in the wing, to the board... |
It's far, far simpler to shim the whole board. Trying to use just the right shim under each rib all along the span is going to pretty much guarantee that the final result will be wiggly like old McGee's walking stick. If the board is reasonably stiff but with enough flexibility so that it can be twisted and clamped down to form the twisted surface then the twist will be nicely and evenly graduated all along the span.
Because you are raising one corner the board will want to be "tippy". So on the two oppsite corners the idea is to either heavily weight them down so they are in contact with the bench top or to clamp or screw those two diagonal corners down to again ensure they are in contact with the bench. Note that for the other wing to get the proper twist you will need to move the shim and weights, clamps or screws to the adjacent corner. You can't build both wings on the board with the shim in the same spot or one wing will be washed in and the other wing washed out. And that's never a good thing....
Build in the washout using shims, it's not difficult. Washout is not a complete twist along the entire wing. Putting washout in after the build via twist and reheating covering is generally for the outer 1/2 of the wing anyways. Don't warp the board... that will be to difficult and then what.. you'll need another flat board. Cubs are gentle flying highly stable planes once in the air. Washout will help on slow speed during landing but is not completely necessary though I recommend it. Differential will be worthwhile to program in and you will need to fly with the rudder for nice turns and apply it on takeoff as well if you want nice scale ROG..
Hmmmm. Thanks for the input guys. I think I'll build the washout in. I have some time to think about and play with how to go about it as I have a Diehls free flight Typhoon to finish up. When I start this one I'll be sure to post it. As I'll need plenty more advise and guidance.
Simply put with a wing of this style there is just no need to shim the wing or the building board on this design to "lock in" the washout they suggest. Any covering suitable for a model of this size will easily be able to hold in the washout by you simply heating and shrinking in the washout desired. If there's any trick to it at all it's simply to ensure that you heat up and "shrink" both the top and the bottom covering evenly over a wide area to allow the covering to "take" to the warp you are putting in place. There should not be any need to go back for a follow up warping session. But if the covering you choose does require it then a second session to touch it up would be all it'll need. I've done a fair number of gliders and other models with open and flexible structures similar to the Electricub. I've never built in the washout in any structures of this sort. I've always relied on the covering and I've yet to be dissapointed or let down. |
| Thread Tools | |
| Discussion Quick Question...HK500GT washout control arms cracked? | MOJOMOJO1 | 3D Electric Heli Flying | 0 | Jun 30, 2012 10:04 AM |
| Washout question | locomoto | Modeling Science | 3 | Jul 24, 2003 01:07 PM |
| Hobby lobby skimmer washout question. | The Other Dave | Electric Sailplanes | 6 | Aug 21, 2002 12:11 AM |
| Question on washout | megawatt | Power Systems | 5 | Mar 21, 2002 05:00 PM |
| Building Mark Rittinger Python -- Washout Question | jet_jer | Scale Electric Planes | 11 | Mar 10, 2002 02:01 PM |
