Old Jul 17, 2012, 07:40 AM
Mike_Then is offline
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
Question
Best frequency for ground-based vehicles?
Good morning, been watching several videos of folks using FPV for R/C ground vehicles. That looks like a lot of fun and I'm kicking around the idea of picking up a cheap off-road car and putting something together. I know this board is really for FPV aircraft, but I wanted to pose a question to see if someone can help: What would be the best frequency to use FPV on a ground-based vehicle? I'm assuming I'd need something other than 5.8 GHz for traveling around a neighborhood and/or any other obstructions? Any suggestions are appreciated - thank you!
*zips up flame suit*
Mike_Then is offline Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Old Jul 17, 2012, 07:09 PM
Bluestreak007 is offline
Find More Posts by Bluestreak007
Bluestreak007's Avatar
Australia, ACT, Canberra
Joined Dec 2011
No flame retardend apparell needed! It's a good question!
OK, so from what I have learnt the lower the frequency the better for ground. 5.8ghz will really struggle with any sort of obstacle and to get the same range as a lower frequency system you will need a much more powerfull transmitter. So 910mhz would be good - only problem is that there can be interference from other things on that frequency so maybe 1.2 ghz may be more interference free depending on the area you are in. If you already have a receiver you can flick around the different channels to see if there is interference around - you want "clean' static.
Higher power is good for longer range Circular polarised antennas also good for ground (dealing with obstacles and interference)
Also check out: http://www.rcgroups.com/forums/showt...88665&page=217
and http://fpvlab.com/forums/forumdispla...ROUND-POUNDERS
Also don't get a small car - Big is good and speed doesn't matter so much (things happen real quick on FPV) My favourite vehicle for FPV is my big slow (and cheap) 1/8 HSP Crawler (same as Maxstone). It only goes at a fast walk but on rough terain that is all you need.
Bluestreak007 is offline Find More Posts by Bluestreak007
Old Jul 17, 2012, 08:03 PM
Martin Y is online now
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
If you can find a 434mhz video tx/rx then distance should be no problems.
Martin Y is online now Find More Posts by Martin Y
Old Jul 17, 2012, 09:06 PM
Mike_Then's Avatar
Joined Apr 2001
Thanks so much for the replies everyone. The links are great; I'm gonna read them in-depth when I have more time tomorrow. Looks like I can do a 1.3 GHz setup for ~$300 after you factor in transmitter, receiver, upgraded antennas, and camera. I also like the fact that most of the recievers I quickly looked at can easily plug into my FatShark googles.
Gotta read and research, and resist the urge to buy!
Old Jul 19, 2012, 07:25 AM
Mike_Then's Avatar
Joined Apr 2001
My friend and I tried his setup with a brushed Evader truck and a 100mW 5.8 GHz transmitter. It was fun bashing around his street but as soon as you started to turn the corner or got behind a bundle of trash, the video dropped off quickly. We tried again with the 600mW transmitter but his antenna pipe for the truck got lost, so we couldn't test the range. If I did this, I'd stick with 5.8GHz due to the fact I'd only need a transmitter. There are a couple of wide-open places in town that we shouldn't have a range issue with 5.8.
Old Jul 19, 2012, 02:13 PM
LexusFPV is offline
Find More Posts by LexusFPV
TBS Crossfire or DragonLink?
Joined Feb 2011
....Mike_Then.....
Get Circular Polarize (CP) antennas' and its night and day difference:-)
LexusFPV is offline Find More Posts by LexusFPV
Old Jul 19, 2012, 02:27 PM
Mike_Then's Avatar
Joined Apr 2001
Originally Posted by LexusFPV View Post
....Mike_Then.....
Yup, that's what we were using.
Old Aug 21, 2012, 09:38 PM
RaptorAP is offline
Find More Posts by RaptorAP
Gainesville, FL
Joined Nov 2005
Thats what Id recommend.. any updates?
RaptorAP is offline Find More Posts by RaptorAP
Question Frequency control for surface vehicles Andy W SEFF 2012 6 Mar 12, 2012 04:00 PM
Discussion Ground Vehicle FPV, Whats Best? bluegizmo83 FPV Talk 7 Nov 08, 2011 01:05 PM
Help! Best video frequency for FPV ground vehicle? saucisse FPV Talk 5 Oct 21, 2011 04:23 AM
Discussion The Sumit has to be the best FVP ground vehicle zooman FPV Talk 10 May 19, 2011 05:33 PM
Discussion Best equipment for long range ground based FPV? hogfarmer FPV Talk 0 Nov 28, 2010 09:39 AM
