Old Jul 17, 2012, 03:18 PM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
The tolerances in the sizes of the sockets and the tolerances on the sizes of the wrenches are such that it you have a dozen wrenches one of them will fit the best. And that is the one to use. There there is all of the other qualities like the quality of the steel each is made from, the heat treating, and just about everything else.
I probably have a bag of 20 1.5mm wrenches and various numbers of nearly every size I have. When I put a wrench in a socket I always twist it from side to side and check for play. The leass play you have the less likely you are to strip a socket.
And there are no rules as far as needed to use inch or metric wrenches on only inch or or metric sockets, if there is a rule it is that you need to use the one with the closest fit regardless of how it is marked.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Jul 17, 2012, 04:53 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Originally Posted by Bare View Post
'possibly' due to crappy grub screws,
but it's IMO far More likely that your Allen wrenches are the crap element. Especially incriminating when it happens on more than one grub screw. A tight fit into the hex hole IS critical.
Quality varies dramatically on those wrenches.. more so than in the screws actually..something I've learned over the years.
I agree 100% with you.....all my allen screws have been stronger than my wrenches so far. I've never owned an "Allen" wrench.....I see Sears carries them, maybe I'll treat myself......but, it's better to have the wrench fail than the screw, right?
hoppy is offline Find More Posts by hoppy
Old Jul 17, 2012, 05:09 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
Why do we even use these stupid things anyway? I know slotted setscrews exist; I have them in my GWS pinion pullers. They work excellent. (They're all over the Interwebs, too, after a quick search).
I see no advantage to hex hardware in this case.
What size are the ones normally used in our motors? Specifically, ~28mm outrunner bells? Seems like they're the same size across the board, so buying a minimum-order bag of slotted ones should have me covered.
Piece is offline Find More Posts by Piece
Old Jul 17, 2012, 07:21 PM
Jack
USA, ME, Ellsworth
Joined May 2008
They are 3mm diameter x 0.5mm pitch socket head set screws, generally about 4 to 5mm long. They would be called 3mm-0.5 x 4 or 3mm-0.5 x 5 in Eurospeak.
And I replace some of them with 6mm long 3mm button head socket head screws that have a 2mm socket instead of a 1.5mm socket. I've done that on a couple of motors that were a little on the "troublesome" side as far as staying tightened.
The 2mm socket will take quite a bit more tightening and general abuse than the 1.5mm sockets will.
You can find the screws I use in the Traxxas RC cars parts assortments in a LHS that carries that stuff.
You can see the screws and see them installed on a motor and also on the motor mount in the images.
I cut the screws to get rid of any excess length when I fit them. You can put a 3mm nut on first to set the cutting point, hold them in a plier, and cut them to length with the Dremel tool and abrasive disc.
Jack
Old Jul 17, 2012, 08:25 PM
AirBornOne is online now
Find More Posts by AirBornOne
I'm All Thumbs
AirBornOne's Avatar
S.F. Bay Area
Joined Aug 2002
Originally Posted by jackerbes View Post
And there are no rules as far as needed to use inch or metric wrenches on only inch or or metric sockets, if there is a rule it is that you need to use the one with the closest fit regardless of how it is marked.Jack
The rule is you start with the appropriate tool for the job.Afterwards comes the improvisation.
Most likely there is inferior metalurgy involved with the 'stripping' set screws.And possibly over torqueing as well.
Skies
J
AirBornOne is online now Find More Posts by AirBornOne
Old Jul 17, 2012, 09:21 PM
flypaper 2 is online now
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Maybe it's time to bring in the square Robertson screwdrivers. More flat surface area than the hex screws. Was at Home Depot a while ago and saw many different sized sheet metal screws with Robertson heads.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Jul 18, 2012, 09:10 PM
lennyk is offline
Find More Posts by lennyk
Joined Dec 2003
MIP Thorpe drivers have very hard tips and tight machining
they will often remove a set screw which mangled other drivers.
They are not that much more expensive and you really only need a couple in the very small sizes anyway.
lennyk is offline Find More Posts by lennyk
Old Jul 20, 2012, 05:06 AM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Thanks for all the advise guys.. So eventually i did get it sorted. I did it the brutal way I drifted out the shaft with the screws still in, this wasn't actually so difficult but I did take care to support the end of the can so as not to deform it.
I then tried to spin the screws out with a 2mm drill but this didn't work. Eventually I ended up drilling right through one set screw (by quenching the tip of the drill bit to make it glass hard and re grinding the tip several times). Even once drilled through it wouldn't budge so I tried a 2.5mm drill which got a better bite and spun the screws out without any problem leaving the thread in the motor intact.
All fixed now and ready to fly again... but it was a real pain.
Steve
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Jul 20, 2012, 05:45 AM
Julez is offline
Find More Posts by Julez
Proud to eat Kraut ;-)
Julez's Avatar
Germany
Joined Dec 2003
I was just about to propose to drive the shaft out directly. If the shaft has a slot where the screw sits, pushing it back and forth may loosen the screw a little.
Another method is to use metric hex keys at inch-sized screws and vice versa. The next bigger key that just won't fit can be driven in with a hammer, and can deliver more torque then.
There is also a compound called screw grab, it is like toothpaste with small diamond bits which increase friction.
I used this to get stripped screws from the maintenance hatches of real planes.
Whenever I insert new scews, I grind the bottom part flat, if there are shaped like a cutting ring. These rings are for axial fixing only, which we hardly need.
This way, my shafts get less scratches.
Julez is offline Find More Posts by Julez
Old Jul 20, 2012, 08:11 AM
43851E is offline
Find More Posts by 43851E
43851E's Avatar
College Station, TX
Joined Jul 2009
For some reason I'm seeing and hearing of so many oversized setscrews (drive hex) so I too have maintained an oversized wrench, which flyes in the face of my Bohndus sets of wrenches.
For slotting a stuck screw w/ a cutoff wheel, use a smaller diameter - worn out wheel to reduce the danage to adjacent material. All priceless responses RGC! I have nothing to add ~
Doug
43851E is offline Find More Posts by 43851E
Old Jul 21, 2012, 10:00 AM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Seems to me I read about a guy who dipped the end of his hex wrench in epoxy and glued it into the socket. Anybody ever try that?
Old Jul 21, 2012, 08:07 PM
Piece is offline
Piece's Avatar
Joined Aug 2009
I'd end up getting epoxy in the threads and then snapping off the wrench at the screw when trying to turn it.
Old Jul 22, 2012, 06:40 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Tried it a few days ago. Fail.
Dremelling a slot worked a treat
Odysis is offline Find More Posts by Odysis
Old Jul 22, 2012, 11:46 AM
Aberdeen
Joined Mar 2006
If you can take the corners of an alloy steel allen key then I'm afraid epoxy doesn't have a hope.
Old Jul 25, 2012, 06:17 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
If you use button heads as suggested earlier Torx type heads are more positive than hex,not sure if the go small enough for a grub screw at your size
Stuart
Stuart A is offline Find More Posts by Stuart A
Rant They wont rest untill everyone has one! UlteriorModem Life, The Universe, and Politics 15 Jul 17, 2012 02:00 PM
Sold Stand Offs with Screws and Nuts THEY ARE SOLD! Dave8888 Aircraft - Electric - Multirotor (FS/W) 1 Jun 25, 2012 09:23 PM
Discussion Will they ever come out with this plane?? madmikeyreturns 3D Flying 11 Aug 22, 2011 01:46 AM
Discussion The grup screws or set screws or whatever they are called kogibankole Electric Heli Talk 2 Jul 16, 2006 01:21 AM
