Old Jul 17, 2012, 02:06 AM
aalavandhaann is offline
Find More Posts by aalavandhaann
Newbie
Chennai
Joined Oct 2007
Help!
DIY brushless motor
Dear Friends,
I would like start the thread with an apology if this post has been made at the wrong place and will gracefully retire if so.
I am simply fascinated by the videos on youtube showing different small brushless motors achieving an high rpm which are often home made. Getting interested into this I looked at varying resources and finally was able to understand the theoretical part of it. Since I am not from the electrical or electronics domain certain things are stopping me from doing my own as shown in the below video
Micro Brushless Motor (1 min 9 sec)
Saying having understood the theoretical part of it, I am not able to know how to build one practically. Like the steps involved in wiring the stators, the type of magnet to be used as a rotator, or the way the sensor has to be connected to the coil ends to detect the angular movements etc., Can someone point me to a step by step layman type guide to building a simple brushless motor and the components involved please. If the terms "layman" and "Brushless motor design" does not go side by side then kindly forgive me. I wish to make a motor as in the above video. And thank you all for your time.
Also I wish to share the video that taught me about brushless motors.
How the Brushless motors are made (BLDC) (7 min 43 sec)
Regards,
Ashok Srinivasan.
aalavandhaann is offline Find More Posts by aalavandhaann
Last edited by aalavandhaann; Jul 17, 2012 at 02:14 AM. Reason: changed the thread title type to help from discussions
Old Jul 17, 2012, 03:33 AM
Veteran is offline
Find More Posts by Veteran
Mc-Fly
Veteran's Avatar
Melbourne-Australia
Joined Mar 2008
You need to take alook at this thread, it is based on the motor you have posted here.
http://www.rcgroups.com/forums/showthread.php?t=596219
Veteran is offline Find More Posts by Veteran
Old Jul 17, 2012, 03:41 AM
Newbie
Chennai
Joined Oct 2007
Thank you for sharing this.
Veteran,
Thank you for having shared this. With a lot of posts in this forum and due to my bad searching abilities did not come across this thread. But still I have started reading it. Though the information is a bit textual but still useful to start with. Thank you once again for having shared this.
Regards,
Ashok Srinivasan.
Old Jul 17, 2012, 02:10 PM
Heliman420 is offline
Find More Posts by Heliman420
Like a Boss
Heliman420's Avatar
Canada, BC, Celista
Joined Jun 2006
Here's another thread on another site that has heaps of good information started by a fellow rcg member
http://www.westknoxrc.com/index.php/...0d97942767ef77
Heliman420 is offline Find More Posts by Heliman420
Old Jul 17, 2012, 05:00 PM
Faethor is offline
Find More Posts by Faethor
Minneapolis, Minnesota
Joined Jul 2007
Thanks for posting those vids! I had only a vague and theoretical concept of how BL works, nice to learn the practical side!
Faethor is offline Find More Posts by Faethor
Old Jul 17, 2012, 10:19 PM
msurguy is offline
Find More Posts by msurguy
Max
Joined Jul 2006
Micro brushless build
Hey, check out my blog post for a practical side of it :
http://maxoffsky.com/maxoffsky-blog/...ushless-motor/
Feel free to ask questions,
Good luck!
msurguy is offline Find More Posts by msurguy
Old Jul 17, 2012, 10:40 PM
Newbie
Chennai
Joined Oct 2007
Thank you guys.
Thank you veteran, heliman and msurguy,
So far your resources have been very useful to understand and i am on my way to make my first brushless motor. Wish me good luck and for sure i will bother you my friends in case i stumble upon any difficulties.
Regards,
Ashok Srinivasan.
Old Jul 17, 2012, 10:46 PM
Newbie
Chennai
Joined Oct 2007
Hello Msurguy,
Can you list some details like
* what is the spec of the magnet used.
* the wire you used in your version of motor.
* finally the wiring to the sensor could be a bit explanatory
But ultimately your motor looks very great.
Regards,
Ashok Srinivasan.
Old Jul 25, 2012, 02:25 AM
Newbie
Chennai
Joined Oct 2007
What is the tiny board on the top?
I have a couple of questions.
* If I make 200 turns of a coil then I will be left with two ends ultimately. Does supplying with the supported rating of power and voltage rotates the motor?
* So with a single coil winding is it known as Single phase motor?
* I am still not able to understand the controller part of the motor in the above video. The tiny board is a kind of sensor (maybe halleffect?) In another site this part has been mentioned as the Allegro A1442. I see that it has a VCC, GND and two Vouts and one Sleep. So do we need an external microcontroller to control the orientation and speed of the motor?
I agree that there is enough information out there and unfortunately the problem is that it is sometimes overwhelming either lacks good explanation. But after reading up a lot I was able to find and understand that A1442 is the magic control needed to run Brushless motors. Do we have any alternative IC's to achieve the same?
Kindly apologize me if the post is unclear for it shows the state of my mind
Regards,
Ashok Srinivasan.
Old Jul 25, 2012, 12:17 PM
msurguy is offline
Max
Joined Jul 2006
Regards,
Ashok Srinivasan.
Hi !
I will provide you with some answers.
Yes, this is a Single phase brushless motor since there is only one coil.
The magical chip from allegro is indeed a hall effect + IC all in one, so you don't need a separate microcontroller to take care of sensing the magnet rotation.
The wiring is very simple, take a look at the photo of the Allegro chip and the wiring on my blog and do exactly the same. The Sleep pin and VDD should be connected together so make sure you do that.
I don't remember the exact details of the coil, but I believe it was something like 150-200 turns of 46-48 gauge coil.
The magnet was taken out of existing brushed pager motor and repurposed for my application.
I believe this could also be achieved by sandwiching two magnets around the shaft and gluing them, please take a look at this thread as it has very precise information about micro brushless motors : http://www.westknoxrc.com/index.php?topic=625.0
Help! DIY Brushless ESC Theory h_e_c Multirotor Electronics 267 Dec 05, 2014 08:17 AM
Help! DIY Brushless ESC Theory h_e_c Electric Motor Design and Construction 9 Jul 08, 2012 04:54 AM
DIY Ikarus Shock Flyer Brushless Motor doberman Power Systems 7 Jan 26, 2004 07:36 PM
Brushless motor DIY lots of parts, cd-rom stators, extra stator materail, Magnets stealthy Aircraft - Electric - Airplanes (FS/W) 13 Nov 29, 2003 07:58 PM
FW Ta 400, 4.35m, six lrk-torquemax diy homebuilt brushless motors Ron van Sommeren Scale Kit/Scratch Built 0 Jan 13, 2002 02:52 PM
