Old Jan 29, 2013, 12:39 PM
Arr0wHead is offline
Find More Posts by Arr0wHead
United States, MA, Plymouth
Joined Jan 2013
A question -
I keep leaving my TX on, as this is the first tx and helicopter combo I have where it's procedure to turn the TX on first, then the helicopter. When done flying, I keep unhooking the helicopter battery before turning off the TX, but then I keep forgetting to turn off the TX.
Is there some kind of an alarm feature or sleep function that can alert me if I've left the TX on and unbound?
Arr0wHead is offline Find More Posts by Arr0wHead
Old Jan 29, 2013, 05:44 PM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
Not that I've found. The annoying this way that in the WK radios at least there was an LED to show that you've left the thing on instead of just a dark LCD screen with dark writing. Uses less battery maybe but for the sake of a couple of mAh I'd be happier with a LED there... user hack maybe?
thwaitm is offline Find More Posts by thwaitm
Old Jan 30, 2013, 02:58 AM
Xermalk is offline
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
With deviation you can set the LCD screen to be always on. Not sure if you can do that on the stock firmware.
Xermalk is offline Find More Posts by Xermalk
Old Jan 30, 2013, 03:43 AM
ITS ME DAVID is offline
Find More Posts by ITS ME DAVID
ITS ME DAVID's Avatar
Joined Apr 2011
How far away is deviation for the 7e?
ITS ME DAVID is offline Find More Posts by ITS ME DAVID
Old Jan 30, 2013, 04:12 AM
Xermalk is offline
Sweden, Helsingborg
Joined Jun 2012
The alpha is already out, but you have to build it yourself. Iv been running it for the past weeks.
Old Jan 30, 2013, 10:13 AM
Daryoon is offline
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
Seen the builds shared by others on the devo7 development thread.
Daryoon is offline Find More Posts by Daryoon
Old Jan 30, 2013, 07:45 PM
RoGuE_StreaK is offline
Find More Posts by RoGuE_StreaK
Caution: Noob in training
Australia, QLD, Redbank Plains
Joined Jun 2007
The clear "V" could be lit up like the devo6, there is a black board behind it that could just have a single hole drilled and LED installed as the V is designed for a single LED in it's centre. LCD backlight LED seems to be pins 17 and 18 of the LCD so could tap power there, but the V would only light up when the backlight is on, so you'd have to change settings to be permanently on. Haven't looked for an existing "always on" power source yet.
RoGuE_StreaK is offline Find More Posts by RoGuE_StreaK
Old Jan 30, 2013, 07:54 PM
Joined Jan 2013
When I got it, I just assumed it would light up when bound to something. I was bummed to find it didn't light up at all.
Old Jan 31, 2013, 04:14 AM
Joined Apr 2011
Sorry but what you mean by build it?
Old Jan 31, 2013, 04:37 AM
FDR_ is online now
Find More Posts by FDR_
Joined May 2011
Compile from source code...
FDR_ is online now Find More Posts by FDR_
Old Jan 31, 2013, 04:09 PM
brad24 is offline
Find More Posts by brad24
Joined May 2010
I went back and forth for a while between going with an NCPX and a DX6i or a Super CP with Devo 7e, but eventually settled on the Super CP 7E combo due to it being around $100 cheaper. After reading everything I'm less interested than I initially was in making it Blade / HH DSM2/DSMX compatible, as it seems the deviation firmware for the 7E messes with the range of the heli.
If I'm only planning on using it for the Super CP and maybe a Master CP down the road a little, is the range going to be adequate? I like to fly outside although I only have experience with an MSR. Will a 7E provide enough range for a Master CP?
brad24 is offline Find More Posts by brad24
Old Jan 31, 2013, 04:11 PM
Joined Jan 2013
The issue with Deviation was fixed in one day.
The underlying problem is that the 7e has a limited range. Deviation doesn't make it any more limited.
Old Jan 31, 2013, 04:18 PM
brad24 is offline
Joined May 2010
gotcha, well then let me revert to the 2nd part of my post, the actual question hahaah
If I'm only planning on using it for the Super CP and maybe a Master CP down the road a little, is the range going to be adequate? I like to fly outside although I only have experience with an MSR. Will a 7E provide enough range for a fast moving Master CP?
Edit: I know the Master CP is bundled with the 7E in RTF form but with all the range discussion on the 7E I'm wondering if thats just a cheap cop out on Walkera's part
Old Jan 31, 2013, 04:31 PM
BD Murdock is offline
Find More Posts by BD Murdock
Quad guys are 4x the fun :)
BD Murdock's Avatar
United States, CO, Longmont
Joined Mar 2012
Originally Posted by Arr0wHead View Post
A question - Is there some kind of an alarm feature or sleep function that can alert me if I've left the TX on and unbound?
Yes there is...
ENT
MODEL MENU
ENT
SENSOR SETTING
ENT
Sensor Staus - Active
No signal Warning - Active
This way when you unplug the battery on your model the Tx will lose it's signal and the alarm will sound. I have it set for the same reason, forgetting to turn off the Tx.
BD Murdock is offline Find More Posts by BD Murdock
Old Jan 31, 2013, 04:32 PM
Xermalk is offline
Sweden, Helsingborg
Joined Jun 2012
If you do get a 7E for a Master, be carfull when doing Fast Forward Flight. You can actually fly out of range with the devo 7E.
For the master i would recommend the 7 or better the 10.
New Product New Devo 7E Radio from Walkera!! thwaitm Radios 3 Jul 17, 2012 01:41 AM
For Sale $ 1.00 NIB Walkera Devo 12S Radio With Telemetry Module (WK-CTL01-D) Aurora9 Aircraft - General - Radio Equipment (FS/W) 4 May 10, 2012 11:07 AM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - General - Radio Equipment (FS/W) 0 Oct 06, 2011 12:33 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - Electric - Helis (FS/W) 0 Oct 05, 2011 11:38 AM
New Product Walkera V18G01 with optional Devo 12 radio zadaw Fuel Heli Talk 11 Jun 10, 2011 10:01 PM
