Old Jul 16, 2012, 09:52 PM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
Landing a tail dragger?
Hey guys. Im getting VERY close to the point where i am ready for my parkzone P47, but the problem i see is its a taildragger and i have no clue how to land a "large" taildragger. Ive landed micro tail draggers, but not "large" ones. So how do i land a taildragger on a grass runway?
electricrc68 is offline Find More Posts by electricrc68
Old Jul 16, 2012, 11:29 PM
RexSe7en is offline
Find More Posts by RexSe7en
Go Ducks
RexSe7en's Avatar
United States, OR, Milwaukie
Joined Feb 2012
Hopefully this will be helpful. Link
RexSe7en is offline Find More Posts by RexSe7en
Old Jul 16, 2012, 11:43 PM
Joined May 2011
Thanks. One question...what is a stick/yoke in RC terms? Im assuming that is a full scale term?
Old Jul 17, 2012, 12:24 AM
RexSe7en is offline
Go Ducks
RexSe7en's Avatar
Joined Feb 2012
Yup, the stick/yoke is what controls the elevator in a full scale plane. So think of it as pulling back on the stick of your transmitter in the r/c world.
I'm obsessed with taildraggers, but they can be a tricky beast. It seems like one day I will go out and grease all of my landings, and then the next trip I'm happy if it doesn't nose over. Some of this has to do with weather and landing strip conditions, but a good majority is definitely on me
Old Jul 17, 2012, 02:02 AM
Elios000 is online now
Find More Posts by Elios000
Elios000's Avatar
United States, MO, Springfield
Joined Jul 2010
landing is the easy part it lands like a trike you just hold the flare all the way to the ground
take off is the tricky part you have ease on the throttle to keep from ground looping
video of my Edge
Edge 540 9/9/11 (6 min 40 sec)
just keep the nose level or slightly down till you get to the runway and then ease off the power and slowly pull back to keep the nose up
the plane will settle down on its own
Elios000 is online now Find More Posts by Elios000
Old Jul 17, 2012, 09:57 AM
ChillPhatCat is online now
Find More Posts by ChillPhatCat
AMA 537620
ChillPhatCat's Avatar
United States, NY, Lafayette
Joined Oct 2008
They also control the ailerons; left and right on the stick controls ailerons, forward and back controls the elevator... so it's essentially the same as the right stick on a mode 2 transmitter. A yolk is basically a steering wheel and a stick is just a stick, like you'd mostly find on early planes and military aircraft. The yolk is being phased out (and mostly appears in small general aviation planes) as more and more planes come with "fly by wire" side sticks which can be programmed to feel however you want them to while flying with moderate to almost no physical pressure needed to control the plane as servos and other hydraulic systems actuate the surfaces.
ChillPhatCat is online now Find More Posts by ChillPhatCat
Old Jul 17, 2012, 11:08 AM
Joined May 2011
Okay thanks guys! By the way, what is ground looping?
Old Jul 17, 2012, 11:10 AM
E-Challenged is offline
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
Ailerons lose effectiveness during slow part of landing, use rudder to level wings. Slow to 1/2 throttle, trim for level fliight, reduce throttle and let model settle to runway.Do not try to flare a warbird until you really know it's stalling tendencies. Real fighters normally land with some speed, on the main wheels, reduce throttle until tail wheel touches down, then raise elevator to keep tail on the ground/prevent nose overs, as you slow to a stop. Don't force model down to runway with down elevator, it'll bounce one or twice and fall out of the air.
You didn't ask, but for takeoffs, hold up elevator to keep tail down until speed increases , then release elevator to let tail rise, control yaw to the left with well timed gentle nudges of right rudder, as speed increases. Let model lift off at 3/4 throttle with little or no up elevator, keep climb gradual to avoid stalling, trim for level flight at comfortable cruising speed, retrim for full throttle, retrim to return to cruise speed or to prepare to land.
E-Challenged is offline Find More Posts by E-Challenged
Old Jul 17, 2012, 12:08 PM
Joined May 2011
Thanks for the info E-Challenged!
Old Jul 17, 2012, 02:03 PM
rtbates is offline
Find More Posts by rtbates
Joined Mar 2010
spinning in a circle. In car terms you spun out or did a donut...
rtbates is offline Find More Posts by rtbates
Old Jul 17, 2012, 02:09 PM
Joined May 2011
Oh okay thanks.
Old Jul 17, 2012, 02:13 PM
600Bob is online now
Find More Posts by 600Bob
United States, OR, Canby
Joined Aug 2011
I find taking off to be more of a challenge than landing. That said some tail draggers are easier than others on the take off roll.
600Bob is online now Find More Posts by 600Bob
Old Jul 17, 2012, 02:27 PM
Gerry__ is offline
Find More Posts by Gerry__
Bye Bye VP Aug 2010 - Aug 2012
Gerry__'s Avatar
United Kingdom, London
Joined Jan 2005
I thought warbirds 'sickened' you?
http://www.rcgroups.com/forums/showt...0#post22001037
I just absolutely hate warbirds whether it be they killed the nazis or whoever...just sickens me. Theres something about those over powered propeller death machines that i hate....absolutely hate. I only have 2 warbirds and won't be buying any more.
So you bought a 3rd warbird then?
Gerry__ is offline Find More Posts by Gerry__
Latest blog entry: Eflite Gee Bee Racing
Old Jul 17, 2012, 03:36 PM
Joined May 2011
Nope. The two warbirds i have are the parkzone P47 and Micro T-28....as you can clearly see from the link below. And yeah they sicken me, but since i have it i might as well fly it.
http://www.rcgroups.com/forums/showthread.php?t=1693312
Old Jul 17, 2012, 04:15 PM
Gerry__ is offline
Gerry__'s Avatar
Joined Jan 2005
But you said
.i guess its just that military aircraft (except the P51 and EDF really don't interest me at all...theres just something about them that sickens me.
So, whatever.
Help! tricycle landing gear or tail dragger Telemaster 40 89 yotta Beginner Training Area (Fuel) 10 Dec 25, 2008 06:21 PM
Best landing gear type for Easy Star -- trike or tail dragger? JohnSoPA Foamies (Kits) 11 Aug 07, 2008 10:15 PM
Help! Best landing technique for tail dragger? rcgroupie Electric Plane Talk 16 Sep 07, 2006 01:56 PM
Discussion Warbird tail dragger landing technique Curtis Miller Beginner Training Area (Aircraft-Electric) 11 Mar 22, 2006 03:39 PM
