Old Jul 23, 2012, 05:21 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
OH I see now, the top secret squirrel pics that give the true duct make up!!!! w
Waltjg is offline Find More Posts by Waltjg
Old Jul 23, 2012, 05:27 PM
Waltjg is offline
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
GLUE,,,i think I have tried about every kind of glue there is out there! And guess what my #1 goto glue is? Good old' 5min epoxy. For quick assembly andw sandability I do like the Elmer's rubber cement, but, it doesn't have the holding power of epoxy.. Depending on what I'm doing, I use 5 min, Elmer's rubber cement, white gorilla, brown gorilla, hot melt, and 3M 77 ... Ohyes, I forgot the 15, and 30 minute, but very rarely.. This game requires a whole arsenal of glues I think.... Happy gluin' w
Old Jul 24, 2012, 05:46 AM
sloperjoe is offline
Find More Posts by sloperjoe
sloperjoe's Avatar
United States, WA, Vancouver
Joined Mar 2012
alrighty then, this train is nearing the station rapidly
this morning I cut the nose parts and laminated them together to make the block, I cut the battery access hole into the center slabs ( I used 1/2" thick blue core I had laying around lookin to become something ), got home from work and stuck it on and started sanding....MMMmmmmm this is starting to look like it should
here are the progress pics for the night. none of the main componants are glued together yet, I just stacked them together, they fit so nice they dont even need tape to hold em together
Joe
sloperjoe is offline Find More Posts by sloperjoe
Old Jul 24, 2012, 05:50 AM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Wow ! Just......... wow !
Keenan smith is offline Find More Posts by Keenan smith
Old Jul 24, 2012, 06:57 AM
Waltjg is offline
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Man, looking really sweet now Joe!!! That made a world of difference when you got that nose on there! Gotta ask, are you going to do an exhaust duct on this one? I don't know if you are planning on it or have the room but it will help your performance a bunch... w.
Old Jul 24, 2012, 08:42 AM
i12flyrc is offline
Find More Posts by i12flyrc
i12flyrc's Avatar
Columbus, Ohio, United States
Joined Jul 2003
In one word "AWESOME" !
i12flyrc is offline Find More Posts by i12flyrc
Old Jul 24, 2012, 11:09 AM
vicentel is offline
Find More Posts by vicentel
vicentel's Avatar
United States, CA, San Diego
Joined Aug 2010
Originally Posted by sloperjoe View Post
woooops,
failed to add the pics showing the temp formers and rear ducting placement on the above "intake building" post..
so here ya go.
Now I understand...holding out on us Joe. I must know your secret techniques! Honestly, this A6 is looking great. Also, I agree with Walt, definitely add a thrust tube if you can.
Vic
vicentel is offline Find More Posts by vicentel
Old Jul 24, 2012, 02:52 PM
sloperjoe's Avatar
Joined Mar 2012
whats a thrust tube?....
here is one theory I have been testing for the last 4 or five jets I designed, at work I use alot of air blowers for getting chips/slag/dirt/ ect..off the work area. the blowers have vents allowing outside air to enter the pressurized air collum forming a venturi,
so if you plug the side vent holes off the air volume drops quite a bit, open them up and air volume increases, the apparent principal is that the moving pressurized collum of air sucks more air along with it as it exits the nozzle... none of my jets have thrust tubes on them and they will all easily do tail stands, I try to position the fan withing a few inches of the outlet and allow air to flow around the fan an mounts that seems to work so far like the venturi nozzles at work.
but thats just a theory...could just be my jets have way more thrust than weight
seriously I dont know...its a quandary...thrust tube, no thrust tube
probably wont have one on this one either
heheheee
Joe
Old Jul 24, 2012, 03:16 PM
Lt599 is offline
Find More Posts by Lt599
Lt599's Avatar
United States, WA, Shelton
Joined Feb 2012
@Lt599,
I try to use as little epoxy as possible on a joint, wipe any off that squishes out, and when sanding a joint round I start right on the epoxy line and carefully work out from there, sometimes you will have a raised line, but if the epoxy got squeezed really thin it sands off nice.
cant say if I have tried Ultimate RC Foam Glue, does it dry quickly? I tried some stuff from the craft store that was supposed to be specially made for gluing foam...glued up a test piece and waited, and waited,...set it aside overnight...let it set all day...the next morning it looked dry...did the pull test...came right apart and the inside of the glue joint was still "wet", after sniffing it I came to the conclusion that it was basically Elmers white glue
my whole thing on glue is:
#1 availability, if its hard to get I wont use it.
#2 ease of use.
#3 cure time, if it needs to set for hours I definitely wont use it. not that I am impatient, I just dont have the room available to let projects sit for long
so if its all 3 of these I'll try it..
@sashaNar,
sinse this is NOT a scale build it will not have scale exhaust.
@Vic,
Nnnnnnno...
@Walt,
I was wondering how I was gonna do them too..
thanks all!
Joe
Joe, the Ultimate RC Foam Glue has a quick dry time. What you do is apply a very thin layer to one of the pieces you are joining, push that piece into place, spreading the glue to the other surface, pull apart, you can do this once or twice then push and hold in place. The glue at that point will hold well enough that the parts usually do not have to be clamped. Totally dry in about 1 hour. Do a search on line for it, there is a video of its use. I happened to find some in stock at the HS in Olympia, so I picked it up to try. It works well. The only foam that I have had trouble using it on is the Dow blue XPS, you have to use a very thin layer or it will "melt" the foam. It does work good on DS, Depron and FFF. Thanks for the info on sanding. I use alot of epoxy, I just have some trouble getting a smooth joint when sanding. Lt
I tried the same Foam Glue "Elmers" in a different bottle! LOL.
Lt599 is offline Find More Posts by Lt599
Old Jul 24, 2012, 07:09 PM
Waltjg is offline
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Thrust tubes and theory... Joe, you have great flying planes for a number of reasons, probably the main one is that you are a very good builder and you are rebuilding them light so your thrust ends up probably at least 1 to 1. Now, if you would take that same plane power setup and add a thrust tube(exhaust tube?) using the 85%FSA calculation you should see your speed increase, it should be a significant jump but only trial would show that. Now, if you are totally happy with how your planes fly, then great,,, keep this on the back burner for a future test. w
Old Jul 25, 2012, 04:40 AM
sloperjoe's Avatar
Joined Mar 2012
Walt,
yeah I am very happy with the speed I get out of my jets, they already cover the span of 3 soccer fields in seconds at 3/4 throttle, the Phantom at WOT is crazy fast, If I had a little bit more open space to fly I might try bumpin the speed factor up, but right now they are plenty licketty splitty nuff for the schoolyard
Joe
Old Jul 25, 2012, 06:22 AM
sloperjoe's Avatar
Joined Mar 2012
here are the pics of the last two parts to make for this build, the turtle deck and canopy. both sliced out of some slabbed out blue core I had, and then laminated together. tomorrow morning I with sand them both out to shape and fit them in place.
did a wing cutting demo vid and posted it on Walts build and will post it here too, the pics show the two part templates I use that have 1/16th" copper wire epoxied to them to smooth out the cut
enjoy
Joe
wing cutting demo (3 min 24 sec)
Old Jul 25, 2012, 07:03 AM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Joe,
What kind of wood/material did you use for the template?
Eric B.
AirX is offline Find More Posts by AirX
Old Jul 25, 2012, 07:17 AM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
Thanks for posting the video. I really like how both the top and bottom templates sit down square and flush to the work surface. A little more work building the templates but well worth it. I will certainly give this a try. I can see where it will work much easier and more accurately then my single male templates and trying to do the cutting by myself. Thanks, Greg
Old Jul 25, 2012, 08:35 AM
Hover or die is offline
Find More Posts by Hover or die
it wasn't me flying that plane
Hover or die's Avatar
United States, NC, Wilmington
Joined Mar 2011
Joe,
The work is stunning..man all I can say is wow..the detail is just all one could ask for..really like the vertical/detail!!You really captured this one for sure!
Really enjoying all your builds..
Take care and please keep the pics rolling...........Chris
Hover or die is offline Find More Posts by Hover or die
Discussion A-6 Intruder Profile, Kf-2 PLANS sugas182 Foamies (Scratchbuilt) 10 Jun 18, 2015 02:55 PM
Wanted A-6 Intruder Orion Pax Aircraft - Electric - Jets (FS/W) 2 Apr 30, 2012 08:26 PM
For Sale A-6 Intruder EDF Angelo Aircraft - Electric - Airplanes (FS/W) 2 Mar 21, 2012 09:10 PM
For Sale A-6 Intruder Angelo Aircraft - Electric - Jets (FS/W) 0 Mar 21, 2012 07:15 PM
For Sale Kyosho A-6 Intruder, Chicago area Angelo Aircraft - Electric - Airplanes (FS/W) 2 Feb 26, 2012 12:04 PM
