Old Sep 13, 2012, 06:10 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Cool Mike!! Will be great if you can make it to SEFF next year!! Rita's,,, Hummmm,,, I've been known to make a few here and there!!:
Will be lookin forward to your pics! W
Waltjg is offline Find More Posts by Waltjg
Old Sep 13, 2012, 09:25 PM
i12flyrc is offline
Find More Posts by i12flyrc
i12flyrc's Avatar
Columbus, Ohio, United States
Joined Jul 2003
Okay so here's a few pics of my start on the fuse. I made the fuse sides top and bottom (double layer of 6mm depron), formers (single layer) and temp formers.
Joe, does the excess portion of fuse formers 1 and 2 look normal? I can't tell from your build pics if this is how it is before fleshing out the bottom. Do I need to fill in the sides to be flush with the bottom?
I also pinned the wing, stab and rudder to the fuse to get an idea of the size.
i12flyrc is offline Find More Posts by i12flyrc
Old Sep 14, 2012, 04:54 AM
sloperjoe is offline
Find More Posts by sloperjoe
sloperjoe's Avatar
United States, WA, Vancouver
Joined Mar 2012
hey Mike,
I did have excess formers sticking out of the bottom, after glue-up I sanded the bottom along with the formers flat for adding the bottom planking, dont remember quite that much hanging out though..think you found a flaw in the plans...where'd ya get those anyway
I think you should be fine just sanding them and the fuse sides down flat, probably didnt notice it as much on mine cause its quite a bit smaller, the bottom planking adds quite a bit of thickness and they are sanded to match the angle of the sides so you should be good to go.
wont be too long now you're almost there
Joe
sloperjoe is offline Find More Posts by sloperjoe
Old Sep 18, 2012, 04:44 PM
i12flyrc is offline
i12flyrc's Avatar
Joined Jul 2003
I have permanently glued on the wing and installed formers 3 and 4. I have also cut and glued the top sheeting on the fuse. Working on sanding and rounding the corners. Will tackle either completing the aileron installation or the inlet section and fuse bottom next. Pics soon.
Old Sep 19, 2012, 07:44 PM
i12flyrc is offline
i12flyrc's Avatar
Joined Jul 2003
Below are some pics of the work on the fuse to date and the nose. I think I am going to do some of this differently than Joe at this point. Instead of the wax paper method he used to be able to remove the entire bottom section so that he wouldn't have to do a hatch, given the size of this version, I will be building the bottom section with a hatch for the fan. As such I am going to attach the nose at this point and round to shape, work on the splitter next followed up with the rear fuse sides for the fan area, skin the inlets and the bottom of the fan and tailpipe areas.
I have been looking at this for a bit and think its very doable. Joe's method makes perfect sense for the original size he built and I would do the same. But at this size, it has plenty of room to build it out hatch and all.
Old Sep 19, 2012, 10:30 PM
sloperjoe's Avatar
Joined Mar 2012
holllly molllly!!!!! kinda hard to get a good grasp on the size from the previous pics....but with your hand in the photo it really brings out just how big it is...WOW that is COOL! very nice work Mike!
Joe
Old Sep 21, 2012, 12:52 PM
Lt599 is offline
Find More Posts by Lt599
Lt599's Avatar
United States, WA, Shelton
Joined Feb 2012
Joe, I have a question about the HK 50mm's I just ordered 2 of them in the 3s version for an A10 build. How is your holding up? I ordered the Red brick 30 amp ESC,s, they where out of the 20 amp version. I am thinking I might try to run the twin set up on 3s 2200. Any input? Thanks, Greg
Lt599 is offline Find More Posts by Lt599
Old Sep 21, 2012, 05:18 PM
sloperjoe's Avatar
Joined Mar 2012
hey Greg,
they are both holding up just fine, the 30amp ESC's should be fine they dont weigh but 5gs more I think, as far as the batt I wanna say the 2200mah weighs just about as much as 2 X 1000mah 3s batts, so you should be ok there too, if you can get an AUW of 20oz's it should fly awesome, 20-25ozs should fly no prob, just a rough estimate of your equipment weight will be about 11oz's, if you can do the airframe at 9oz's you would be sitting pretty good, about a 35" wingspan size or there abouts, I think it could be done if you can refrain from the urge to add anything more than a wing spar for strengthening.
keep us posted on your progress
Joe
Old Sep 22, 2012, 12:20 AM
Lt599 is offline
Lt599's Avatar
Joined Feb 2012
Thanks Joe, I started building this afternoon. I am trying very hard to go as light as possible. i will start a build log, I got the wing done tonight. Greg
Old Sep 25, 2012, 08:40 AM
i12flyrc is offline
i12flyrc's Avatar
Joined Jul 2003
Joe,
I have the inlet diverter completed as well as the F4 temp former and fan fuse sides on. Looking at getting the nose and the inlet sides done next. You don't have a template for those on the plans. Did you just free form it til you got the right shape or is there a template you can post?
Old Sep 25, 2012, 01:01 PM
sloperjoe's Avatar
Joined Mar 2012
sorry Mike, no template, I cut two layers per intake, layer #1 was 4 1/8" X 8" and layer #2 was 4 1/4" X 8", used spray adhesive and epoxy both to add them one layer at a time, kinda why I did the wax paper thing while building it...case I didnt like how it came out I could remove it without tearing anything up
you should be able to scale those dimensions up and that should give you an idea on if you need to make them bigger or smaller..they are rectangle shape so nothing fancy about them.
Joe
Old Sep 25, 2012, 02:03 PM
i12flyrc is offline
i12flyrc's Avatar
Joined Jul 2003
Thanks Joe! That helps. I have a method for rolling depron using a pipe or broom handle. I think I picked it up from one of J Morgan's threads maybe. Anyway, I should be able to get the shape before gluing anything. Stay Tuned.
Old Sep 25, 2012, 08:50 PM
Waltjg is offline
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Good luck Mike, rolling that foam is easy, I use a piece of PVC put foam against the front of me then apply pressure with the PVC and roll,, works great... Heading for HHAEFI in two weeks... W
Old Sep 26, 2012, 07:21 PM
i12flyrc is offline
i12flyrc's Avatar
Joined Jul 2003
Got the nose attached and carved ( it will get a light coat of spackle then sand it off again). I put the stab and rudder on again to get a look. She's taking shape.
Joe, I'm still stuggling a bit trying to get started on the inlets. I can't tell from the views if there is a bottom section from the fan area to the diverter or if the rolled inlet sections make up the bottom as well. Do you have any more pics that might show that section of the build beyond what has bee posted already?
Inlets, fuse bottom and fan section are next. Then I will complete the flying stab,turtle deck and canopy.
Walt, what's HAEFI ??
Old Sep 26, 2012, 07:28 PM
D_FAST is online now
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
get r done all ready gees
Just kidding. Awsome work
D_FAST is online now Find More Posts by D_FAST
Discussion A-6 Intruder Profile, Kf-2 PLANS sugas182 Foamies (Scratchbuilt) 10 Jun 18, 2015 01:55 PM
Wanted A-6 Intruder Orion Pax Aircraft - Electric - Jets (FS/W) 2 Apr 30, 2012 07:26 PM
For Sale A-6 Intruder EDF Angelo Aircraft - Electric - Airplanes (FS/W) 2 Mar 21, 2012 08:10 PM
For Sale A-6 Intruder Angelo Aircraft - Electric - Jets (FS/W) 0 Mar 21, 2012 06:15 PM
For Sale Kyosho A-6 Intruder, Chicago area Angelo Aircraft - Electric - Airplanes (FS/W) 2 Feb 26, 2012 11:04 AM
